2010 CM have 5100s need smoother ride
Discussion in 'Suspension' started by MacCTD, Jan 24, 2018.
  1. Jan 24, 2018 at 8:27 AM
    MacCTD
    MacCTD [OP] New Member
    2010 CM 4x4
    5100s
    First post, I have a 2010 CM 4x4 I have had since new, put 5100s on it right after I bought it, fronts on the middle setting, for the last 8 years I have used the truck pretty sparingly I only have 41k miles on it. I am starting to use the truck more now and I am finding the ride really jarring especially the front when I hit bumps in the road, I would like to change out the suspension for a smoother ride. I have a Jeep also and put Rancho 9000s on it which I have found to be softer when set on the lowest setting. Any suggestions for a smoother ride? Thanks.
  2. Jan 24, 2018 at 8:37 AM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    Welcome from Ca. I didn't find the 5100s to be too bad personally. But, Bilsteins are digressively valved. You might prefer a progressively valved shock.? Tire weight, type and tire pressure are huge factors when it comes to comfort also.
    DalTee likes this.
  3. Jan 24, 2018 at 8:47 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. Lots of info on suspension and lifts are available on this site - lots of recommendations for the Bilstein 6112 front shocks along with comments about the ride quality. I can't comment personally since I haven't done the install myself but there's a pretty comprehensive thread about suspension and lifts with a lot of good info here: https://www.tundras.com/threads/guide-different-types-of-lifts.546/
    Good luck
  4. Jan 24, 2018 at 8:55 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    You hit the nail on the head. I was thinking tires immediately!
    831Tun likes this.
  5. Jan 24, 2018 at 9:03 AM
    MacCTD
    2010 CM 4x4
    5100s
    Thanks for welcomes, I am running a set of stock take off RW wheels and tires, I am running 38psi front and rear.
  6. Jan 24, 2018 at 10:23 AM
    Steve6
    Steve6 New Member
    Tucson
    I have an SUV that I don't drive much. The tires on that vehicle are now 8 years old and I've noticed that the rubber seems to be stiffer and that the tires have significantly less traction on pavement than they did when they were new. Could the stiffer ride be due to the old tires rather than the suspension? I've read that some shops won't repair tires that are over seven years old. Something to think about.
  7. Jan 24, 2018 at 10:31 AM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Generally, shops won't repair a tire that's more than 5 yrs old.
    I would imagine the stiffer ride could be part tire but the suspension could've "settled" a bit too.
  8. Jan 24, 2018 at 10:47 AM
    MacCTD
    2010 CM 4x4
    5100s
    Thanks for the feedback, I don't think it is the tires, I had Michelins on it until '13 and the ride was the same, the RW wheels and tires are from a '13 RW.
