2004 Tundra Lower Ball Joint Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by cammiller, Dec 27, 2019.
  1. Apr 16, 2020 at 11:19 AM
    Cassiooohh
    Cassiooohh New Member
    2005 Salsa DC 4x4
    Thanks Speedtre! I'll call my local dealership first and then look into online options.
    I'm looking forward to seeing more photos of your rig. I know you've been teasing us for some time now.
    speedtre[QUOTED] likes this.
  2. May 17, 2020 at 4:00 PM
    Skoolieman
    Skoolieman New Member
    Chattanooga, TN
    02 Tundra Limited V8 4x4 trd offroad package
    Can I use grade 8 hardware for the 8 bolts? I bought the Moog kit that comes with all the hardware but the bolts are shorter. I really can't wait to mail order the hardware. Thanks
  3. May 17, 2020 at 6:01 PM
    Blueranger501
    Blueranger501 New Member
    Moog is absolute shit. Do not put that garbage on your truck.
    mine lasted 10k miles. And that was AFTER I had to replace one when installing. The nut provided deformed when torquing to final specs, the metal was just soft junk. Used the oem bolt after I swapped out. 10k later garbage. Back to OEM. Not worth it to go cheap on this component.
    MrAristo, revtune and FrenchToasty like this.
  4. May 17, 2020 at 7:36 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Do you already have everything disassembled? If not, return the moog LBJ’s and get OEM.
  5. May 17, 2020 at 9:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    On topic.
    For those who are just starting to get into servicing their own vehicles like me.
    What are the warning signs?
    Odds are I will end up replacing these soon anyway as I have new coilovers to install eventually.
    Just curious for future reference, and others like me who do not know. :) Thanks in advance.
    (Just guessing, but I would say its either an excessive "vibration" or noise?)
    Cheers.
    Edit: According to Service records my LBJs were replaced in 2006 when there was 29K on the clock.
    312,900-ish now...
  6. May 18, 2020 at 4:33 PM
    Blueranger501
    There is no early warning if red lite was not used on the 4 bolts, it will spontaneously fail and is well documented. In your case I think your’re fine based on miles but replace asap.
  7. May 20, 2020 at 7:13 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    I replaced lbj from factory, but I didn't do shit with the 4 bolts. I re-used originals. Torqued to book. I have an 04. I have checked the bolts when I do any tire or brake work, they have been solid. Should I be worried?
  8. May 20, 2020 at 8:17 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Nope.
  9. May 20, 2020 at 8:23 PM
    10 blue trucks
    04 4WD RCLB
    so the loctite thing on all new bolts on the 4 unders is a different year or a myth?
  10. May 20, 2020 at 8:27 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Did you end up installing the moog LBJ’s?
  11. May 20, 2020 at 8:28 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    If the 4 bolts are torqued to spec, pretty sure you’re good to go.
  12. May 20, 2020 at 8:32 PM
    10 blue trucks
    04 4WD RCLB
    they dont budge, at 280K I got other concerns , so I'll just move forward on every other abused component, and check that they dont spin if I'm under there. Thanks.
  13. May 21, 2020 at 3:49 AM
    Skoolieman
    Chattanooga, TN
    No I broke down and ordered Toyota lbjs. They came in last night.
  14. May 21, 2020 at 8:42 AM
    Blueranger501
    Great call on OEM. You will sleep and drive better knowing it’s a quality part. To complete your good decision and hard work I would jack up, remove, locktite and re torque bolts. Should take you 30 min tops I’d you have a jack, socket, torque metal wrench and locktite. No way in leaving that to chance. Seen too many postings of random failures. Luckily it seems to happen in parking lots most of the time.
  15. May 21, 2020 at 12:54 PM
    Skoolieman
    Chattanooga, TN
    I plan to use blue locktite. Is that what you recommend?
  16. May 21, 2020 at 1:31 PM
    Blueranger501
    I would use red personally. Stronger.
    revtune likes this.
  17. May 21, 2020 at 1:54 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I second the red stuff. The truck will probably be a cube by the time they need to be addressed again:D
  18. May 22, 2020 at 1:37 PM
    Skoolieman
    Chattanooga, TN
    Awesome, thanks y'all.
  19. May 26, 2020 at 10:37 AM
    #49
    ToyotaJim
    ToyotaJim New Member
    Tagged and will be inspecting mine. Thanks!
  20. Jun 11, 2020 at 4:42 PM
    #50
    10 blue trucks
    04 4WD RCLB
    The red is tight, but if you have to get into other front end work its a bitch. if you have your front end serviced you should probably let the tech know you are red locked. If you do your own its fine. I have 10k on my original bolts, reused. and they arent red or blue. They are just torqued to spec. But my front end is destroyed so I constantly get to check them. They are holding for now.
  21. Jun 11, 2020 at 8:28 PM
    #51
    10 blue trucks
    04 4WD RCLB
    Sorry, not 10k on the original truck, but 10 k after a 275,000 service. So everyone gets to gorilla glue their bolts as wanted. But I don't.
  22. Jul 16, 2020 at 4:00 PM
    #52
    fhorton50
    fhorton50 New Member
    2003 Tundra Access Cab
    air helper
    I did my whole suspension with AC Delco Pro, very high quality, made in Japan, looks and installs like OEM, at about 1/3 the cost
    AgitatedGopher likes this.
