2004 Tundra Lower Ball Joint Replacement
Discussion in '1st Gen Tundras (2000-2006)' started by cammiller, Dec 27, 2019.
  1. Dec 27, 2019 at 9:54 AM
    cammiller
    cammiller [OP] IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    I did this last night/this morning in my drive way, and other than the joints being stuck in the LCA and the tie rod end, it was pretty straight forward.
    1: Chock wheels, engage ebrake, jack front end of truck up
    2: remove tires
    3: remove cotter pin from tie rod bolt and remove nut.
    4: I used a pitman arm puller to remove the tie rod from the ball joint. I watched multiple YouTube videos of people just hitting the ball joint with a sledge hammer and the tie rod just popped out, but this did not work at all.
    5: remove 4 bolts from back of wheel to lower ball joint, and move wheel out of way
    6: remove cotter pin and nut from bottom bolt on old ball joint. use pitman arm puller to pop ball joint out of LCA.
    7: repeat steps in reverse order to install new ball joint. Torque bottom nut to 106 ft lbs and install new cotter pin. torque 4 bolts behind wheel to 53 ft lbs, and torque the rod nut to 67 ft lbs and install new cotter pin. Put tires back on and lower truck and you’re good to go.
  2. Apr 3, 2020 at 5:20 PM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Any recommendations on ball joints? I know OEM is king, but anyone got other solid options? Gotta do mine soon.
  3. Apr 3, 2020 at 6:10 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Just get OEM. Seriously. They aren't that expensive.
    @speedtre didn't you buy the "kit" they sell that comes with new bolts?
  4. Apr 3, 2020 at 7:01 PM
    speedtre
    speedtre New Member
    Inland Northwest
    BubbaW, revtune and MrAristo like this.
  5. Apr 3, 2020 at 7:09 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
  6. Apr 3, 2020 at 7:13 PM
    speedtre
    speedtre New Member
    Inland Northwest
    No...the only reason the 05-06 has a kit is because the lbjs were recalled on them, so the kit is actually a recall kit. If I remember correctly the two lbjs for your year cost less than the kit for 05-06. But make sure you get 8 new bolts and two new cotter pins...they aren't expensive.
    MrAristo[QUOTED] likes this.
  7. Apr 3, 2020 at 7:30 PM
    cammiller
    Cameron
    Sulphur, Louisiana
    47F1B4D2-C6C9-43FD-8B29-44868F2AC128.jpg Whatever you do, don’t get 1A-Auto. I had one fail on me a couple weeks ago. After that I got Napa Chassis. $158 out the door with my corporate discount.
    Pucks18, MrAristo and MS22 like this.
  8. Apr 3, 2020 at 7:53 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    I like Moog ! I’ve never had an issue as far as stock replacement parts , been a mechanic for over 20 yrs . I’m sure there is better parts for lifted trucks , but for stock that’s all I use . Besides factory oem .
    theBIGnaud and 773_eddie like this.
  9. Apr 3, 2020 at 8:03 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Ouch :eek2: Glad to see your okay
  10. Apr 3, 2020 at 8:12 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    yea, ive seen this all to much to not buy quality ball joints. glad your ok!
  11. Apr 3, 2020 at 8:21 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Are the Mooges that much cheaper than oem? I’d much rather pay the 20$ extra per, not to have to deal with a lbj failure that could be deadly
    MrAristo likes this.
  12. Apr 3, 2020 at 8:28 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Well there are generally plenty of warning signs before a failure . A complete failure with no warnings is generally from abuse or off-roading and that stuff is just part of the deal . Haven’t priced ball joints for a tundra so I don’t know the price difference.
  13. Apr 3, 2020 at 8:32 PM
    empty_lord
    05 rollover special
    I paid 178 for both my oem ball joints.
    Ordered the recall “kit”
  14. Apr 3, 2020 at 10:26 PM
    cammiller
    Cameron
    Sulphur, Louisiana
    I did do some moderate off roading, but had no signs of lower ball joint failure before it happened. Luckily I was only going 15 mph
    empty_lord likes this.
  15. Apr 4, 2020 at 3:48 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    In case 2004 owners like myself run across this thread, the recall was for certain 2004 through early 2007 Model Year Sequoia and 2004 through late 2006 Model Year Tundra vehicles.
  16. Apr 4, 2020 at 3:52 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    ivbyiv, MS22, speedtre and 3 others like this.
  17. Apr 4, 2020 at 5:04 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
  18. Apr 4, 2020 at 5:12 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    You need to hit the Ball Joint knuckle a lot harder and the tie rod will pop out. Your replacing it anyways, so what if it gets banged up. You also must of got lucky on the 4 small bolts, or live down south......that ain't happening in the North East unless you heat the metal surrounding the bolt to red hot. So they finally do a recall, not saying the previous years were crap as well. So unless Toyota made better ball joint for the early ones, why buy another set of Toyota Ball joints. Beck Arnley $40 a piece.
  19. Apr 4, 2020 at 8:06 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    The recall was 13 years ago in 2007 o_O
  20. Apr 4, 2020 at 8:14 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Right there skippy...........it took until 2007 for them to have a recall. :ohsnap:
  21. Apr 4, 2020 at 12:21 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Just like anything , it has to happen to the right person before they do anything .
  22. Apr 4, 2020 at 2:38 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    It appears when you buy the ball joints they come with a new castle nut and cotter pin. The 4 bolts that come up from the bottom of the joint should be these:
    https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-bolt-w-washer-9011910933/?c=YT10b3lvdGE=
    Please provide your VIN# to whatever online dealer you use and they should point you in the right direction if the link above is incorrect.
    speedtre and MrAristo[QUOTED] like this.
  23. Apr 4, 2020 at 3:25 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
  24. Apr 4, 2020 at 3:29 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
  25. Apr 4, 2020 at 6:40 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Thanks @speedtre for the link to the cool springs free shipping code. Here is a screen shot I generated with the parts @MrAristo was asking about.
    MS22, MrAristo and speedtre like this.
  26. Apr 5, 2020 at 5:08 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    How much is it recommended to do control arms when doing LBJs? Also I hear UBJs tend to last much longer, anyone got input on that and if/when to change?
    AgitatedGopher likes this.
  27. Apr 6, 2020 at 4:39 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Nice job man. But specifically talking about uppers here, I know the lowers tend to be a weaker point on our trucks.
  28. Apr 6, 2020 at 5:59 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    My 2 cents on the uppers. If you're pulling it all apart anyway to do the lowers you might as well do the uppers if you don't know when they were replaced.
  29. Apr 16, 2020 at 10:02 AM
    Cassiooohh
    Cassiooohh New Member
    2005 Salsa DC 4x4
    Can someone help me verify the part number for the "kit"?
    I found: 04005-04134
    It is indeed much cheaper than ordering the parts individually but it doesn't seem to include the 8 bolts or the lock nuts for the LBJ. This would be for my 2005 DC
  30. Apr 16, 2020 at 10:47 AM
    speedtre
    speedtre New Member
    Inland Northwest
    That is the wrong part number...that is for this service campaign...
    http://media.fixed-ops.com/Toy_Campaigns/50Jdeal.pdf
    You need part number 04006-62134 for this recall (see attachment).
    I originally ordered new castle nuts and cotter pins when I ordered the ki but I was contacted by McGeorge Toyota with the following:
    "Hi,
    We noticed that you ordered part number 04006-62134 for the ball joint kit, but also ordered castle nuts and cotter pins. The kit above actually already comes with the castle nuts and cotter pins included, so it's not necessary to purchase them separately. Would you like us to remove and refund the extra castle nuts and cotter pins from the order and proceed with the rest?
    Thank You
    Toyota online parts
    Be sure bookmark our new url
    toyotaparts.mcgeorgetoyota.com"
    Order your kit from Cool Springs while they are doing there free shipping and it will be the cheapest you will find and you can confirm with @Roman (their parts guy here on the forum) that your kit has those nuts and cotter pins as well, but mine did.
