2004 Toyota Tundra Water Leaks!
Discussion in '1st Gen Tundras (2000-2006)' started by bpack7, Jul 19, 2018.
  1. Jul 19, 2018 at 6:35 PM
    bpack7
    bpack7 [OP] New Member
    Hey Guys!
    I just bought a 2004 Toyota Tundra and it's my first truck ever and couldn't be happier to be a Totoya Truck owner cause I LOVE IT!
    I bought the truck from a private dealer and he didn't point out a couple things..
    I live in FL and it's hurricane and rainy season, it rains almost everyday. Couple days ago I noticed some water leaks.
    First leak - Up under the dash on the front passenger is leaking in multiple spots and looks like it's coming from the blower? Does anyone have a fix for this? Seems to be dripping from the screws on the blower...
    Second Leak - Behind the back passenger in the access cab against the frame water is leaking in the corner, can't find the source of it all..please see pics for details.
    Third Leak - This is close to the second leak, along the door frame in front of the second leak..not sure if it's just an access of so much from second leak or this leak is coming from a seal from the passenger door not being sealed properly?
    I have taken pics of everything..if anyone can help in anyway please let me know! I'm sure someone out there is having the same issue as I am?
    Thank you all!
    First Leak:
    Second Leak:
    Third Leak:
  2. Jul 19, 2018 at 6:36 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Does it have a sunroof?
  3. Jul 19, 2018 at 6:39 PM
    bpack7
    no sunroof
  4. Jul 19, 2018 at 6:52 PM
    Blueknights75
    Ron
    Clayton, NC
    Check to ensure that the rubber grommets are not missing in the floorboard under the carpet. Also check seals around windshield and windows, might have dried out seals around the glass. Do you have any roof clearance lights by chance?
  5. Jul 19, 2018 at 6:56 PM
    Casper421
    In the woods
    06 DC
    I had the same leak as your first one. I think this is the thread I used to fix it, pretty straight forward: For leak 2 and 3, I would start pulling side panels and investigate more. Could be from the rain “gutters” on the roof. The weather stripping could have deteriorated and now allowing water into the cab.
  6. Jul 19, 2018 at 7:36 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I had the same issue with my 03. Drove me nuts and could never pinpoint where it was coming through the rear window. Used to soak up into the seatbelt. :mad:
    Surfbeach and Black Wolf like this.
  7. Jul 19, 2018 at 11:00 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    For leak #2 maybe check the seal around the third brake light above the back window. If water is getting in it could be running down the top of the window and straight down to the floor.
  8. Jul 20, 2018 at 5:32 AM
    Professional Hand Model
    Hand Protectors
    This. Unscrew the brake light and visually inspect. Clean it up and reinstall. Use some caulk on the backside of gasket. Or, tape off and caulk the top and two sides but leave the bottom of light housing uncaulked for drain purposes.
  9. Jul 20, 2018 at 5:41 AM
    Hand Protectors
    Not sure if its related but check your sides (forgot the name) above the mud flap behind front tires. Open doors and look for the little plastic flap below door hinge. Leaves and debris get trapped in there. You need a long stiff wire with a hook and some patience.
    Also, open your engine hood and see if debris is clogging the drain ports near the windshield corners. This drains down into the mud flap area mentioned above.
    Run your water hose to flush everything. The water hose can be used to test for leaks as well.
    Could be the cowl? (Thingy at base of windshield) leaking as well? Maybe a/c drain clog?
    Xsnrg2006 likes this.
  10. Jul 20, 2018 at 7:21 AM
    bpack7
    So I took the four screws out and took off the front plastic face of the third brake light off, the whole thing won't come out cause it's sealed to the truck but there's space on the top where water can get in?? Is it supposed to be super tight against the truck or little space for water to go around? I put the face back on with screws and tightened it down really good, see if that helps?
  11. Jul 20, 2018 at 7:22 AM
    bpack7
    i'll check that, thank you!
  12. Jul 20, 2018 at 7:23 AM
    bpack7
    I took it off and cleaned it but the seal around the plastic face is flappy and falling off. I put back on and put four screws back on see if that helps? May need to seal up or order new third brake light.
  13. Jul 20, 2018 at 1:52 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    My 2004 leaked in the same place as your leak #1, and removing the cowl under the wipers revealed some rubber grommets which held the cowl screws in place had dry rotted. The first posters linked repair directions are a great place to start for leak #1 I ordered new grommets and no more leak. My 04 does not leak in the back though. The 3rd light would be my first guess though.
  14. Jul 20, 2018 at 3:21 PM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    My son's truck 2012 Colorado leaked around the gasket for the third brake light above the back glass. Silicone took care of it.
  15. Aug 18, 2018 at 8:21 AM
    TGattis
    TGattis New Member
    Troy
    02 Limited x-cab
    The first leak that's on the passenger floorboard is coming from the cowl screws under the cover, remove the wiper arms, remove the cover, you'll see the screws under there. They have little plastic washer things that dry rot and leak directly onto the blower motor. Use some silicone sealant on the threads and around the head to cure that nuisance. The drivers side rear leak is likely from the weatherstrip running the length of the roof, again use black silicone sealant if you can find the exact spot.
  16. Jul 5, 2019 at 4:48 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Any thoughts on removing the clips without breaking them? I'm 0 for 1 at the moment...
  17. Jul 5, 2019 at 5:08 AM
    abcinv
    Tommy
    South of ATL
    Please disregard, I'm good with the other 5 clips.
  18. Jul 9, 2019 at 11:08 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I also had the the first leak. Here's my thread with the fix.
    Filthyphil likes this.
