2004 Toyota Tundra Frame Rust
Discussion in '1st Gen Tundras (2000-2006)' started by chazimm, Dec 18, 2018.
  1. Dec 22, 2018 at 8:23 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    If they don’t do anything, I would pursue possible repairs like @rustbuckit did. A shop could probably fix it for a LOT cheaper than getting a new frame.
  2. Dec 24, 2018 at 6:19 AM
    rustbuckit
    rustbuckit New Member
    05 tundra limited 4x4
    I can help with advice it's free. More on what needs to be used what needs to be cut loose
  3. Dec 24, 2018 at 6:23 AM
    rustbuckit
    All back together now. Now to fix the bed
    bmf4069 and classiccat like this.
  4. Dec 24, 2018 at 6:25 AM
    rustbuckit
    Plastic bed liners suck
    classiccat likes this.
  5. Dec 24, 2018 at 7:19 AM
    Professional Hand Model
    Hand Protectors
    What are your thoughts on how to bang this dent back to a point where I can do some body filler work?
    I’m open to suggestion. I saw on another thread Potoghi took off the side quarter panel. I’d rather not do that unless it comes down to it. Also, I’d rather not remove the bed from frame and do a bed swap.
    I’d rather do some body work a few hours at a time rather than wrenching and searching junk yards for countless hours for the proper part. I do not have a welder or body shop tools. I can do very good finish work whatever the medium.
    Special tools needed? Tricks instead of special tools? Thoughts anyone?
  6. Dec 24, 2018 at 7:45 AM
    rustbuckit
    For getting dents out (not quite that bad) see if you can fit a rod with a 90 degree angle about an inch and 1/2 end on it. Then with visegrips try to twist the other end to push it out. If the steel is creased it probably won't work. Other than that see if you can rent or borrow a small stud welder or pick one at harbor freight. Some dent pullers are just small stud guns.
  7. Dec 24, 2018 at 7:48 AM
    rustbuckit
    Yeah Harbor freight has one for $98.00
  8. Dec 24, 2018 at 7:52 AM
    rustbuckit
    Sorry its called a stud welding dent puller
  9. Dec 24, 2018 at 7:57 AM
    Hand Protectors
    The steel is creased and I think this is the big hurdle. I may try your steel rod 90° trick. Also, I’ve considered grinding a relief cut along the crease axis to relieve the pressures before bending back out. Then, grinding the loose metal edge (after popping things back) back to factory as best possible to give me the straight lines needed to start filling.
    Thanks for your input.
  10. Dec 24, 2018 at 8:13 AM
    Hand Protectors
    Also now that the creative juices are flowing, I’ve considered this as an option. Cut out the crease along the blue lines to remove section. Bend crease back as best as possible on the work bench with the persuader. Pop out the doinks on the quarter panel now that its opened and relieved. Reinstall section back on using two part epoxy. Wait a few days.
    Grind down to achieve a straight edge on everything. Prep. Fill. Sand. Prime. Paint. Clear coat. Etc.
    This will let me do the thing in stages and have an operable vehicle. Parts (mostly paint) $150.
    NUDRAT likes this.
  11. Dec 24, 2018 at 10:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That's too much work. Just fill it with bondo and call it good. :D
  12. Dec 24, 2018 at 10:27 AM
    Hand Protectors
    And say it looks good from your house?
    bmf4069[QUOTED] likes this.
  13. Dec 25, 2018 at 9:54 AM
    rustbuckit
    Fiberglass kit is a little stable. I think maybe cutting it out not a good idea unless you can have it welded back in. Maybe rent a port a power and some wood blocks would do tomorrow
  14. Dec 25, 2018 at 10:22 AM
    rustbuckit
    Done with the bed
    bmf4069 likes this.
  15. Dec 25, 2018 at 12:04 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Call a paintless dent removal place and get a quote. They're usually pretty reasonable and you don't have to do any of the work!
  16. Dec 30, 2018 at 5:05 AM
    rustbuckit
  17. Dec 30, 2018 at 6:30 AM
    Hand Protectors
    Super Heavy Duty frame now! Hows she riding?
  18. Dec 30, 2018 at 12:13 PM
    rustbuckit
    A little stiff but pretty good
  19. Apr 12, 2019 at 6:48 AM
    #49
    lsaami
    lsaami Let ‘er buck
    Minnesota
    If you never had the recall performed, then it is still open, and they must address it. Type your vin under Toyota.com/recall and if the frame recall is listed, they’ll fix it.
  20. Apr 12, 2019 at 6:54 AM
    #50
    Nick04Tundra
    Nick04Tundra New Member
    Nick
    04 Tundra SR5 Ext Cab
    none
    Note: There was no recall notice sent out. It was a "limited service campaign" by Toyota which has since expired. I called Toyota customer service about this several times. They stated that I should have received a notice in the mail to have my frame spray coated. I did not receive a notice. They said they are not responsible for what happens with the mail. They also said, if I had my frame sprayed and it still rusted out, it would be covered by the frame replacement campaign. What to do with the large paper weight in my driveway?
  21. Feb 16, 2020 at 8:21 AM
    #51
    Rottedframe2004tundra
    Rottedframe2004tundra New Member
    2004 black tundra limited 4x4
    3" level kit
    Contact Jim lentz at corp.he's the head honcho! Bombard him with emails day after day
  22. Feb 16, 2020 at 8:29 AM
    #52
    3" level kit
    I'm bored all these clowns at corporate with emails everyday
  23. Feb 16, 2020 at 8:30 AM
    #53
    3" level kit
    Lombard all the Clowns with emails
  24. Jun 7, 2020 at 6:24 AM
    #54
    Yourrealdad
    Yourrealdad New Member
    Hello,
    I know this is an older thread, but I am looking at getting a first gen Tundra. Is the recall still open and is it open to any owner or does/did it have to be the original owner?
    Also is there a way to distinguish between normal rusting of a 15 yr old truck vs the kind that is going to cause the truck to split in half?
    Thank you
  25. Jun 7, 2020 at 11:39 AM
    #55
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    There was no recall , basically it was an extended warranty on the frame which has expired . You might want to call Toyota and ask if they’ll still do something for you . Just look at the frame closely or better yet have a mechanic put it on a hoist and inspect it for you .
  26. Jun 7, 2020 at 12:28 PM
    #56
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    No manufacturer would replace a 15 year old truck frame for free. Anyone who expects a free frame on a 15+ year old vehicle is not being reasonable and will be disappointed. Anyone who thinks that this only happens to Toyota trucks is not being honest.
    https://www.youtube.com/watch?v=fOnI7iK3Dpo
    https://www.youtube.com/watch?v=ww1EDsGvh-A
    https://www.youtube.com/watch?v=YfQ7VrSSPd0
    https://www.youtube.com/watch?v=BV5pLFEjcuY
    https://www.youtube.com/watch?v=MsnsQJRAh4M
    https://www.youtube.com/watch?v=9vt4b5FYgRk
    onesojourner likes this.
  27. Jun 8, 2020 at 8:31 AM
    #57
    tvpierce
    tvpierce Formerly New Member
    Maine
    According to the sticky at the top of this forum, there was a limited service campaign AND a recall.
    It’s my understanding that a safety recall can never expire. But I’m not an attorney and I didn’t stay a a Holiday Inn last night.
    bmf4069 likes this.
  28. Jan 4, 2021 at 6:14 PM
    #58
    DavidC96
    DavidC96 New Member
    David
    04 Tundra Double Cab 4WD
    So question not related to if I can get Toyota to do anything about my 04 Tundra. I am going to check with my local dealer but from what I have found cannot purchase a frame from Toyota new for my VIN. My question is I have found a clean frame from a 05 Tundra but the 04 is a solo year for exact fit. Does anyone know what the differences are for the 05-06 frame compared to the 04? From what I can find it might be the trans mount and maybe carrier bearing crossmember which both I am not afraid of moving/modifying to make work with my 04 driveline. All the other suspension and body parts appear to be the same. Any input would be appreciated.
  29. Jan 4, 2021 at 6:28 PM
    #59
    Festerw
    Festerw New Member
    04 Tundra DC
    Here's the list of things the dealer replaced on my 04 DC if that's what you have. The frame shows still available.
    https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-359#post-1451105
  30. Feb 6, 2021 at 5:53 AM
    #60
    DavidC96
    DavidC96 New Member
    David
    Update and will see where it goes. My local dealership recommended I call Toyota customer care and explain the situation to them before proceeding with a used frame swap. Truck goes in next week to have frame inspected at the dealer and see what Toyota will do. I will update with the response I get from Toyota.
    speedtre likes this.
