2004 Double Cab 4WD Tundra
Discussion in '1st Gen Builds (2000-2006)' started by 805Tundra, Mar 1, 2022.
  1. Apr 5, 2022 at 7:10 PM
    805Tundra
    805Tundra [OP] New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Finished up my install of the Toytec Aluma 2.0 coilovers as well as the Camburg UCAs. Overall the install went pretty smooth, but there was definitely some challenges. Experienc below (Warning Pic Heavy):
    Here is how it started:
    I sprayed all the bolts a few times over the course of a week with PB blaster, that made removal of all the hardware easy. I didn't have one bolt/nut give me a hard time. Removing the coilover and UCA was a breeze and took about 20-30 mins tops, I thought I was on a roll and that this whole project was going to be a piece of cake. WRONG! I got to the notorious ball joint that needed to be pressed out.
    Even with the ball joint press that i rented from autozone it was still difficult and awkward. But with determinition i got it out. Pressing the new one it was just as challenging even with it sitting in the freezer before hand. By far the hardest part of this whole operation and took about 85% of the install time.
    Old vs New:
    Had to remove the sway bar link in order to get the new coilovers in since they were longer. Ordered some extended sway bar links. Coilover bolted right in:
    Got the Camburg ball joint pressed in:
    Greased up the UCA and installed that, put everything back in and boom im done!
    Just had to repeat that on the other side and the total install took about 4-6 hours.
    Off to the aligment shop and then out to give it a test ride.
    Right now im measuring at about 23" hub to fender, hoping it settles a little bit because its a tad squatty and I want it to be level. Can't wait to see how it feels!
  2. Apr 8, 2022 at 3:44 PM
    805Tundra
    Ben
    Central Coast
    Coilovers settled to about 22.5" on the passenger side and 22" on the driver side, adjusted the driver side coilver up 1/2" for the lean and now sitting at 22.5" on both sides. These things are insanely smooth and ride great, loving them so far.
    Toyotoholic and FrenchToasty like this.
  3. Apr 11, 2022 at 4:31 PM
    805Tundra
    Ben
    Central Coast
    More goodies
    HBTundra likes this.
  4. Apr 12, 2022 at 8:18 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Clean ride and nice upgrades !
    805Tundra[OP] likes this.
  5. Apr 12, 2022 at 9:05 AM
    805Tundra
    Ben
    Central Coast
    Thank you!
  6. Apr 12, 2022 at 10:26 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Nice work.
    Truck is looking awesome!!!
    I really like the wheels with the white... Super clean.
  7. Apr 12, 2022 at 11:10 AM
    805Tundra
    Ben
    Central Coast
    Thank you sir! It has been a fun project to work on and really loving how its turning out
    Toyotoholic[QUOTED] likes this.
  8. Apr 12, 2022 at 5:25 PM
    805Tundra
    Ben
    Central Coast
    Extended links installed
    kodyquist21 likes this.
  9. Apr 16, 2022 at 9:59 PM
    2005tundra_nopayments
    2005tundra_nopayments 1st gen Tundy
    Jr
    Central Ca
    2005 tundra double cab 4.7
    Nice build! What is your leaf pack plan? I need me some but wondering what you were going with
  10. Apr 18, 2022 at 9:39 AM
    805Tundra
    Ben
    Central Coast
    Thanks! Right now im plannig on getting the Deaver leaf pack which should lift about 1" above stock, smooth out the ride and increase travel.
  11. Apr 18, 2022 at 9:42 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Beware with Deavers. Not saying they're bad but they're not made to hold hardly any weight. So with your shell and anything in the back, you'll definitely see a drop in height.
    805Tundra[QUOTED][OP] likes this.
  12. Apr 18, 2022 at 9:43 AM
    805Tundra
    Ben
    Central Coast
    I have also hear that as well, which is holding me back at the moment...I have read about others have the same issue. I'm 99% sure im keeping the shell so the leaf pack plans could change in the future. I wonder if the could custom build a pack to handle weight or just go with Alcan??
  13. Apr 18, 2022 at 9:48 AM
    2006Tundra
    Lou
    Long Beach, CA
  14. Apr 18, 2022 at 10:11 AM
    805Tundra
    Ben
    Central Coast
    2006Tundra[QUOTED] likes this.
  15. Apr 18, 2022 at 11:23 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    tacoguybill and 805Tundra[OP] like this.
  16. Apr 18, 2022 at 12:29 PM
    805Tundra
    Ben
    Central Coast
    I have heard of these but haven't looked into them too much, but I definitely will check them out. thanks!
  17. Apr 19, 2022 at 4:10 PM
    805Tundra
    Ben
    Central Coast
    Found this little wrench in the garage while doing some clean up, perfect fit for the suspension maxx extended links.
    011D6357-7F5D-4812-A191-C4838DE9C0A4.jpg EF5FE424-8B6A-46A2-AF21-6BCA22F6F1C2.jpg
    2006Tundra likes this.
  18. Apr 27, 2022 at 5:20 PM
    805Tundra
    Ben
    Central Coast
    Current profile, sitting mostly level.
  19. Nov 11, 2022 at 6:47 PM
    #49
    2006Tundra
    Lou
    Long Beach, CA
    Black Friday deals are going on over at ToyTec. How are you liking their coilovers? I might pull the trigger. I'm due for some shocks.
  20. Nov 11, 2022 at 8:18 PM
    #50
    805Tundra
    Ben
    Central Coast
    Love them!
  21. Nov 14, 2022 at 9:51 AM
    #51
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    clean setup
  22. Nov 14, 2022 at 12:15 PM
    #52
    zoomspeed05
    marc
    awesome bro, which 5160s did you go with? i mean for what application?
  23. Nov 14, 2022 at 8:51 PM
    #53
    805Tundra
    Ben
    Central Coast
    Thanks dude, got them mainly for a better ride and slightly more travel. Hopefully upgraded my rear leafs here soon
  24. Mar 3, 2023 at 8:54 AM
    #54
    805Tundra
    Ben
    Central Coast
    Little update. Added flush center caps, really like the look. Put on some roof racks and built a platform in the bed.
    612DF357-BDD6-44AF-81BC-D78D7E166B16.jpg B9FA3FDF-DF90-45BD-A349-560D0CE2A4E3.jpg 828D2BA7-175F-4306-9D3F-62A085BF6189.jpg
    kodyquist21, sn_85 and des2mtn like this.
  25. Mar 3, 2023 at 8:56 AM
    #55
    805Tundra
    Ben
    Central Coast
    Archive MD springs have arrived, looking forward to putting these on
    sn_85 likes this.
  26. Apr 5, 2023 at 8:34 PM
    #56
    805Tundra
    Ben
    Central Coast
    Finally got around to getting the @Archive garage MD springs installed. Pretty straightforward install with no problems. Definitely recommend a buddy or two, these things were heavy.
    988CBC3D-BE25-4988-8392-5D475B213E1C.jpg AE942888-8C89-4D5E-841B-E19819C69AAA.jpg 65D7336A-FD2F-40E5-AE45-60633310C0D2.jpg 7B6C5FEB-8C2A-42C0-B541-D5F8E41EB81C.jpg 98A3AC17-FB53-4C3A-9125-117AB9C55555.jpg 8A85715C-0E4D-4E43-8AE2-E2ED32816C25.jpg
    Overall these things rock ride well and flex incredible. They hold weight extremely well too. Have 300lbs+ in the rear and still gave me about 2” of lift. Overall sitting at 24” hub to fender. Axle to frame is 11.5” (stock height is 9.5”)
    6B621CA6-993D-4362-ADB8-9D98A9976691.jpg 72304505-1E45-40FA-9FBE-FAF648E43A4D.jpg
    Shocks are the limiting factor now for droop.
    G_unit3000 and kodyquist21 like this.
  27. Apr 6, 2023 at 8:51 AM
    #57
    805Tundra
    Ben
    Central Coast
  28. May 11, 2023 at 5:47 AM
    #58
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Those leaf packs look real beefy - nice quality. The overload is much closer to stock thickness compared to my ATS HD setup.
    Did you reuse your stock shackles?
  29. May 12, 2023 at 10:37 AM
    #59
    805Tundra
    Ben
    Central Coast
    Super beefy, these are only medium duty and got 2” of lift with about 300lbs in the back. Ya I reused my stock shackles
  30. Jun 19, 2023 at 9:38 AM
    #60
    805Tundra
    Ben
    Central Coast
    Built a bracket to raise my lspv up a little. Helped improve braking after the rear lift
    Casper421 likes this.
