2003 Supercharged Tundra 4x4
Discussion in '1st Gen Builds (2000-2006)' started by imDementeD, Jun 27, 2019.
  1. Mar 7, 2020 at 2:58 PM
    #91
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Automatic rear window button?
  2. Mar 7, 2020 at 3:00 PM
    #92
    imDementeD
    imDementeD [OP] New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    The rear window is powered.
  3. Mar 7, 2020 at 3:21 PM
    #93
    Professional Hand Model
    Hand Protectors
    Was it painful?:D
  4. Mar 7, 2020 at 3:39 PM
    #94
    Hand Protectors
    When you putting those sweet brake lines?
  5. Mar 7, 2020 at 3:47 PM
    #95
    imDementeD
    I'll do those when I upgrade to the 14wa calipers ;)
  6. Mar 7, 2020 at 5:14 PM
    #96
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Incredibly
  7. Mar 7, 2020 at 11:11 PM
    #97
    jImmegart
    Jonah
    California
    what the heck is that factory
  8. Mar 7, 2020 at 11:12 PM
    #98
    imDementeD
    Yes sir!
  9. Mar 7, 2020 at 11:31 PM
    #99
    because_wumbo-truck
    Jon
    Houston, Texas
    Yep I think it was an option for 03+ and standard on limiteds. I know my buddies 01 limited doesn't have it but my 06 limited does.
    jImmegart[QUOTED] likes this.
  10. Mar 8, 2020 at 1:53 AM
    #100
    jImmegart
    Jonah
    California
    Damn Im sad. Wish there was an easy way to install one
  11. Mar 8, 2020 at 7:31 AM
    #101
    because_wumbo-truck
    Jon
    Houston, Texas
  12. Mar 8, 2020 at 1:58 PM
    #102
    jImmegart
    Jonah
    California
    oh shit, actually doesnt look too expensive. Im not much of a fabricatior but this doesnt seem half bad, and I dont need to drill into the window or anything
  13. Mar 8, 2020 at 3:04 PM
    #103
    Blueranger501
    Blueranger501 New Member
    Here’s my solenoid mount.
    trucks looking good! Might need to refinish those spindles. All that surface rust makes me nervous!
    imDementeD[OP] likes this.
  14. Mar 8, 2020 at 3:10 PM
    #104
    Blueranger501
  15. Mar 15, 2020 at 4:03 PM
    #105
    jImmegart
    Jonah
    California
    Did you install add a leafs when you did this?
  16. Mar 15, 2020 at 5:07 PM
    #106
    imDementeD
    I had a 1" block in the back already with the 2.5"lift/ level.
  17. Mar 15, 2020 at 7:07 PM
    #107
    jImmegart
    Jonah
    California
    Ah ok, I was looking at the old emu kit and it one came with a 1.5" add a leaf but Id rather go with just a 1" in the back.
  18. Mar 26, 2020 at 9:11 AM
    #108
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Delayed response. Most folks report getting less than the advertised lift with either type of AAL. Our springs are older and have sagged a bit. I did the progressive 3 leaf AAL and elft the overload spring in so I should have been around a 2 inch lift, but I got just under 1.5 (totyec AAL)
  19. Mar 29, 2020 at 1:52 PM
    #109
    imDementeD
    I finished my roof rack installation today.
    Overall, I like how it turned out. The wind noise seems pretty low to me but my truck isn't super quiet like the LX470. First test drive with windows down I couldn't hear it at all but the second test drive was a bit longer and I felt there was a slight change but not bad at all.
    Now for the issues! I did drill through my headliner in the back when the drill got away from me. It was the 6th hole in a row with a bad bit and I was just being impatient. The second issue I found today. As I mentioned, the bit wasn't in great shape and was sliding around a little until it finally grabbed. The downside to this is not all of the holes were perfectly centered which I didn't think was a big deal because there was adequate play in the rack itself to adjust. The issue was the nutsert tool wouldn't fit when it was too close to the edge. This was a huge pain where I had to bend/wedge the tool in and on the 2nd to the last nutsert, I broke the 1/4-20 bit. So, I just tossed the last nutsert in with the silicone and let it dry. It will get fixed in the future but it's going to rain Wed. so I just wanted it to get finished and let the silicone dry for at least a couple days. The third issue was the alignment. I am out of square about 1/4" which lead to the last (2) bolts not lining up to install. I modified the bracket to make it work. It's very solid but I will need to adjust the rack when I fix the nutsert in the future.
    Lastly, I should have washed the truck beforehand but I am very happy with how this is coming together. I have a 4 gallon rotopax and (2) knock-off maxtrax that will get installed onto an aluminum panel then to the roof rack since the bars don't align with the mounting points on either product (at least not in the orientation I want to run them). This will probably have to wait until Corona is over as I will knock this out at my work. Hopefully, by then, I will also have the pelican case I plan to use for future recovery gear/air compressor.
  20. Apr 4, 2020 at 9:25 AM
    #110
    imDementeD
    Installed the 14WA brakes today. After having them milled 3.5mm on the ears to align the rotors, it was a very straight forward installation. I had a little trouble aligning the brake line but more so because it was my first time messing it and I didn't quite realize how it worked. Once I figured it out, the driver's side took about 30-45 mins. I still need to bleed the brakes and top them off but it's my little girls 3rd birthday so trying to make the most of it during quarantine...
    Anyway, grabbed a few pics to show the difference from 13WE to 14WA and the final product.
    20200404_090949.jpg 20200404_091102.jpg 20200404_091109.jpg 20200404_104005.jpg 20200404_104459.jpg 20200404_111531.jpg
    Cane Skretteburg, Darkness and MS22 like this.
  21. Apr 4, 2020 at 9:39 AM
    #111
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Any driving yet?
  22. Apr 4, 2020 at 9:42 AM
    #112
    imDementeD
    Not yet! Taking a break to spend time with the daughter. Probably won't get back to it until she naps (if she naps)...
    Darkness[QUOTED] likes this.
  23. Apr 4, 2020 at 12:45 PM
    #113
    imDementeD
    Finally, bleed the brakes and took her for a quick spin.
    My initial thoughts are:
    • Normal stopping slow speed - Little change
    • 40mph to 0mph - I had my daughter with me because she was begging for a "ride in daddy's truck", but I do feel there was a definite enhancement here.
    Overall, I do feel I need to bleed more as the pedal still feels a bit mushy but I also feel like it's always been like that but now I'm really trying to pay close attention. I didn't start in the back when doing the bleed as I only removed the fronts but I think I need to re-bleed from the back then pass. front then driver front. Overall, the fluid is definitely clean that's coming out but still nervous I might have air in the system. I will need to get more fluid and maybe do this tomorrow.
    Overall, very happy with the upgrade, especially for $155! ($80 for the calipers/rotors/pads, $60 for machining and ~$15 for a can of caliper paint and steel brush)
  24. Apr 4, 2020 at 1:15 PM
    #114
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Hey totally off the topic of brakes , but did you ever service the super charger since you bought the truck ??
  25. Apr 12, 2020 at 3:49 AM
    #115
    NMR@ider76
    NMR@ider76 New Member
    Jesse
    2006 DC Tundra
    5 inch tuff country 35” coopers on mayhem wheels TRD CAM exhaust K&N JET flash
    Is that a Victory roof rack for an 05+ Tacoma? Can you please tell me if you got the one for the access cab like yours or the DC?
  26. Apr 12, 2020 at 4:26 AM
    #116
    imDementeD
    Nope, it's @toyotech2016 rack. You can PM him and he'll give you a shipped price. He sends you the hardware and the raw aluminum brackets that attach to your roof but then you order the extrusion crossbars separately. He helps get you the right stuff and it worked out well.
    My advice, if you go this route, make sure all the holes you drill are very centered in the track otherwise you will have a hell of a time getting the nutsert tool in there!
  27. Apr 12, 2020 at 4:58 AM
    #117
    NMR@ider76
    Jesse
    2006 DC Tundra
    Thank you.
  28. Apr 12, 2020 at 4:58 AM
    #118
    imDementeD
    Sorry I missed this comment! I did not service it yet. I'm trying to think back to when I did all the preventative maintenance what my mechanic and I talked about. I believe it was "looked over" but nothing was done to it.
    This is something I have on my list of things to do.
  29. Apr 13, 2020 at 2:53 PM
    #119
    imDementeD
    Rotopax installed, (1) of the (2) Pelican 1520 cases installed and everything mocked up. Need to order more bolts for the pelican cases and the maxtrax mounting kit for the knockoff maxtrax.
    Cases were a bit higher than expected but feel the depth is needed for storage.
  30. Apr 15, 2020 at 10:41 AM
    #120
    toyotech2016
    toyotech2016 New Member
    2016 Tundra 1794 2004 Tundra TRD 2004 Sequoia Limited 1988 4Runner LT
    Love seeing my racks outfitted. Our gutter channel is slim compared to the newer vehicles so the nutsert is a tight fit. You can make your own nutsert tool using some bolts and nuts. But you’ll have to be able to get a wrench into the gutter area. I did get a few holes in my headliner but I can’t even tell where they are.
