2003 Corolla "Virus"
Discussion in 'Other Toyota Vehicles' started by Tundra2, May 23, 2021.
  1. Jul 16, 2021 at 4:29 AM
    #181
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    134,034 miles.
    4,773 miles on both fluids below.
    Changed engine oil, and Trans fluid after peniscola trip.
    Engine oil: Drained out 2.5 quarts of oil + filter. Put in 4.5 quarts of oil + new filter.
    ATF: Drained out 3 quarts. Put in 3.5 quarts. Checked level hot. Right at top hot tick on dipstick.
    Old shift juice came out, dark, and smelt burnt. Peniscola trip was rough on the little car. Will do another drain, and fill on Trans next oil change as it all should be routine driving with nothing insane like flo-rida ride.
    NUDRAT likes this.
  2. Jul 18, 2021 at 5:57 AM
    #182
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Parents bought ‘02 Camry yesterday 4cly. Going to keep an eye on this thread for tips. Other than a valve cover gasket and lock actuator it’s clean and nice. I will do all the maintenance
    @empty_lord i tagged you in a post yesterday in a different thread but wanted to find this one. Appreciate all the info fellas and knowledge of anything to look out for
    Tundra2[OP] and NUDRAT like this.
  3. Jul 18, 2021 at 9:32 AM
    #183
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    OH someone did tag me! It disappeared yesterday for me!
    those are good little cars. Biggest issues are power steering racks leaking, power steering return lines leaking, valve cover gaskets and timing chain tensioner leaks. Past that. There’s not a whole lot that goes wrong with them
    Tundra2[OP] and DaBoro54[QUOTED] like this.
  4. Jul 18, 2021 at 10:39 AM
    #184
    DaBoro54
    Lol yeah sorry man deleted that one to put it somewhere it made more sense. Thanks for the info.
    @Tundra2 thanks for all the great maintenance information. I will be going through this one too to get it up to snuff
  5. Jul 24, 2021 at 5:23 AM
    #185
    Tundra2
    Noah
    Western Kentucky
    Oil sample was not included in my email report from Blackstone Labs. I've sent a reply to them to see what's up. Here is the ATF report from them.
    If you recall from a few posts up when I took the sample for BSL, the ATF smelled burnt, and shitey. Here's a quote.
    DaBoro54 likes this.
  6. Aug 5, 2021 at 5:21 AM
    #186
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    So - how is Dad enjoying that Corolla you bought him? :eek2:
    and what are you fixing for him meanwhile?
    Tundra2[OP] likes this.
  7. Aug 12, 2021 at 3:36 AM
    #187
    Tundra2
    Noah
    Western Kentucky
  8. Aug 12, 2021 at 10:10 PM
    #188
    NUDRAT
    NUDRAT 6 lug life
    SW CT
  9. Aug 13, 2021 at 4:34 AM
    #189
    Tundra2
    Noah
    Western Kentucky
  10. Aug 13, 2021 at 4:37 AM
    #190
    Tundra2
    Noah
    Western Kentucky
    He liked the corolla while I was in Knoxville. Spoke highly of it probably because he didn't buy it. Complimented the light bar saying "when you hit that toggle switch its like you're driving in the daylight again. I like it." When I told him I was putting a light bar on it he was completely against it. Funny how that works...
    NUDRAT[QUOTED] and TundraGirl2 like this.
  11. Aug 22, 2021 at 3:26 AM
    #191
    Tundra2
    Noah
    Western Kentucky
    Was stopped on the western ky parkway for a semi truck wreck. It was gnarly.
    Parked on the parkway for about 20 minutes. Let the car idle for 10 of that before I realized I'd be there awhile. Finally got rolling and then thus little light cane on, and my butthole got real tight.
    Still about 30 minutes out from petrol and 25 miles. Puckerin'
    des2mtn likes this.
  12. Aug 22, 2021 at 3:48 AM
    #192
    Tundra2
    Noah
    Western Kentucky
    A glimmering ray of hope!
    Pushing it a little much for my taste with my teenie weenie little 13.3 gallon tank.
    Butthole restored.
    MTRock and NUDRAT like this.
  13. Aug 22, 2021 at 5:31 PM
    #193
    Tundra2
    Noah
    Western Kentucky
    @empty_lord shifted to park at a drive thru in the car, and then shifted back to drive. Shifter suddenly got all loosey goosey. Think the cable came off inside the center console or at the transmission.
    What are the odds that the cable broke?
  14. Aug 22, 2021 at 5:46 PM
    #194
    Tundra2
    Noah
    Western Kentucky
    Found the problem. Used field expediency, and car tools to remove parts and pieces in the drive thru line.
    Looks like the little ball joint retainer clip thing is worn out. I stuck it back on for now just to get home.
    Anyone got a link for the cable? I'm really not looking forward to running that. I think it would be easier to drill out the stud on the shifter and put a bolt on it.
    I remember I ran the shift cable on the chevy. That job fucking sucked ass.
  15. Aug 22, 2021 at 5:46 PM
    #195
    empty_lord
    05 rollover special
    I’ve never seen that happen before
    Tundra2[QUOTED][OP] likes this.
  16. Aug 23, 2021 at 1:43 AM
    #196
    Tundra2
    Noah
    Western Kentucky
  17. Aug 25, 2021 at 1:02 AM
    #197
    Tundra2
    Noah
    Western Kentucky
    So after thinking about it, eye balling this video a time or two, and thinking on it some more. I've got a new plan.
    All I really need to fix this issue is to retain the cable on the stud. Several ways of doing it, but I don't like the method used in the video. My original method seen in the quote was way too complex.
    New plan!
    1.) Drill a hole straight down as seen in this screenshot from the video that I edited.
    2.) Install hitch pin from assortment at work. The .062 diameter was the smallest "big one" we had. I'm taking five of them so I can cut one down if there is a fitment issues with items near the shifter.
    3.) Button the interior back up. Should be easy peasy. Will take center punch, and drill bits with me from work.
    Below are pictures of the measuring process completed just a few minutes ago.
    Here's my pilot bit. I'm taking two of these.
    Here's the real bit I'd like to use if I have enough room on the shifter pin.
    The assortment of bits. I put blue paint on the ends of the two 1/16" (pilot) bits for easier ID once in the car.
    NUDRAT likes this.
  18. Aug 25, 2021 at 6:28 AM
    #198
    Tundra2
    Noah
    Western Kentucky
    Started out pulling the center console out. Should have cleaned this nasty thing up, but I was tired. So meh.
    That allowed me access to the shifter. I did vacuum up the carpet some before final reinstall. The shifter has four 12mm bolts, two wire clips, two wire loom clips, and two cables. No pics of each step, sorry.
    I removed the shifter, and used the trunk as work bench to drill the first hole with my pilot bit. I reinstalled the shifter, and tried it out. I decided there was too much slop, so I removed it again. I drilled another hole pointed out by the dot with an arrow. This was much better.
    While the shifter was out, I gave it a mediocre wipe down, and painted the shift indicator light blue. Paint Pens Rule.
    Did clearance testing. All shift positions pictured below. I know that "Low" looks like the hitch pin is hitting the plastic, but it isn't. Just the angle of the picture. Also observe the over drive switch wire going up the shift handle with each change in position. It's that dark gray one going up.
    Did a test drive before reinstalling the center console. All shift positions work. Overdirve button still works too. :D
    @TundraGirl2 will be happy that we aren't putting the cable back on mid drive-thru :rofl:
    NUDRAT and TundraGirl2 like this.
  19. Aug 25, 2021 at 6:39 AM
    #199
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Kramer would not be impressed….it’s not on the line :stirthepot:
    Tundra2[QUOTED][OP] and NUDRAT like this.
  20. Aug 25, 2021 at 6:42 AM
    #200
    TundraGirl2
    TundraGirl2 New Member
    Kaitlyn
    Western Kentucky
    Amen!! Talk about a heart attack! Super proud that you thought quick and came through with a solution. Even though that meant taking the whole thing apart in a drive through line :rofl:
  21. Aug 25, 2021 at 7:04 AM
    #201
    That method works for sure. And is very, very bulletproof. But two questions.
    One - shouldn't you stack some washers between the pin and eyelet to reduce some of the slop and play? Wouldn't want that plastic eyelet piece to crack.
    Two - I feel you could've achieved a similar goal using a regular washer against the plastic piece, and a starlock washer towards the outside, pushed on until it locked. Only say this b/c it would've saved time and effort. Solid option, definitely not as bulletproof as what you chose.
    Starlock washers are used all over in the automotive and electronics industry. These are often used to hold bed topper latches intact. A-Zon sells variety packs of them cheap, super handy to have on-hand. Essentially, you push the washer onto any post slightly larger than the hole in the washer, and the tension and direction of the cut flanges prevent the washer from sliding back off.
    Like this:
  22. Aug 25, 2021 at 7:06 AM
    #202
    PS - Simple Green and a medium-stiff-bristle larger brush and toothbrush will have your interior parts gleaming with minimal effort. Just hose off after and you're golden. Also works on carpet stains if you remove the carpet from the car.
  23. Sep 27, 2021 at 2:08 PM
    #203
    Tundra2
    Noah
    Western Kentucky
    Slightly overdue oil change today. Discovered that my adapter I made for the V6 works on the virus.
    TundraGirl2 and NUDRAT like this.
  24. Oct 1, 2021 at 3:14 AM
    #204
    Tundra2
    Noah
    Western Kentucky
    Must have hit 140K today because I know I drove about 70 miles today.
    Katblackdiesel and TundraGirl2 like this.
  25. Oct 29, 2021 at 3:15 AM
    #205
    Tundra2
    Noah
    Western Kentucky
    The corolla virus claims another mammalian victim. A racoon. It was scared shitless as a semi had just passed over him. It got its tail sqaurshed by the semi and was panicking.
    I tried to hit him square, but he was all over the place. Caught him on the drivers side. I heard him rip out the last of my splash shields.
    Oncoming traffic prevented me swerving. Not to mention the driving rain.
    https://youtu.be/W1LaQ68tkDg
  26. Oct 31, 2021 at 8:47 PM
    #206
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    You need a diverter/air dam
  27. Nov 12, 2021 at 2:51 PM
    #207
    Tundra2
    Noah
    Western Kentucky
    Almost time for new tires for the corolla. Never bought tires for a car before so open to suggestions.
    Starting to get wetter, and potentially icy sooner than later.
    FrenchToasty likes this.
  28. Nov 12, 2021 at 11:30 PM
    #208
    empty_lord
    05 rollover special
    I ran copper cs5 tires on the 06. They were good. I have yoko avid assends on the 09. They’re good but loud
  29. Nov 12, 2021 at 11:37 PM
    #209
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
  30. Nov 13, 2021 at 4:31 AM
    #210
    Tundra2
    Noah
    Western Kentucky
    I'm assuming the window track/roll up mechanism is similar to the Tundra.
    Drivers side window rocks forwards/backwards when rolling up or down. Will need to take the door panel off, and see what's up.
    Last thing I need is for my window to come off the scissor mechanism, and fall down into the door at this time of year.
    Any advice on what to expect or to look for is welcome.
