2002 Sequoia P0300, P0302, P0304, P0306, P0308 and flashing check engine light
Discussion in '1st Gen Tundras (2000-2006)' started by ehowitzer, Jul 7, 2022.
  1. Sep 27, 2022 at 8:50 AM
    ehowitzer
    ehowitzer [OP] New Member
    So it's been a while since I posted about this issue. With the changes I made, the behavior changed slightly in how often it occurred but was still there. The engine was still periodically running rough/missing and then it would go away. Once I got a blinking CEL, which also went away and stored no OBD codes. Based on the suggestions on this thread and some info from my reader suggesting bank two catalytic converter/O2 sensor anomalies, I decided to go ahead and replace the O2 sensors and catalytic converter on the passenger side. I had done the other side about 18 months ago. Well she runs smooth as can be now and I haven't had another episode.
    NyCSnEaK and shifty` like this.
  2. Dec 20, 2022 at 2:50 PM
    illtww
    illtww New Member
    T
    What brand Catalytic converter did you go with?
  3. Dec 20, 2022 at 9:12 PM
    ehowitzer
  4. Dec 21, 2022 at 7:29 AM
    Let us know if you ever end up throwing any codes with those. There's been a quiet push to figure out non-OEM which cats will work without ever throwing codes (so far only Magnaflow, Summit Racing's store brand, and one other I don't recall). A few people have gone aftermarket, spent a pretty penny to boot, only to constantly throw codes on them. The ECU on these trucks apparently isn't fond of a few different aftermarket cats.
