1st Gen Won’t Start
Discussion in '1st Gen Tundras (2000-2006)' started by Hary Gahtoe, Jan 4, 2025.
  1. Feb 6, 2025 at 4:23 PM
    Hary Gahtoe
    Hary Gahtoe [OP] New Member
    4W 4 door sr5
    After lengthy talks with about all of the things that are going on, decided going ahead with this one.
    Old engine is out and will replace all hard parts and electrical components that go at advanced mileage.
    There’s no rust so the bulk of the problems are age/wear related and the damage caused by bad repairs.
    G_unit3000 likes this.
  2. Feb 6, 2025 at 5:55 PM
    Hopefully you can find a new motor and bring this truck back to life. I have no idea why you would have tried to start it without inspecting anything after being told the motor was bad….
  3. Feb 6, 2025 at 6:59 PM
    Hary Gahtoe
    4W 4 door sr5
    Onwards and upwards
    G_unit3000, Sirfive and KNABORES like this.
  4. Feb 6, 2025 at 7:03 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Start a build thread to document the work you put into it.
    G_unit3000 and TET1 like this.
  5. Feb 6, 2025 at 7:57 PM
    Hary Gahtoe
    4W 4 door sr5
    "Hopefully you can find a new motor and bring this truck back to life."
    I bought replacement motor before I actually bought the truck
    "I have no idea why you would have tried to start it without inspecting anything after being told the motor was bad"
    I did "inspect it" oil; up to level coolant; up/clean-pink I ran OBD, pulled all the plugs.
    Finally as we were turning the engine over to pull the torque converter bolts (showing it wasn't seized, no scored bearing noise) so WTH, I used a bore scope and found a snapped rod. The cost to fix the damage was more than the it was worth
    "Tried to start it? " Why not? I didn't know what was hurt yet. and It wasn't like I was going to hurt it anymore. It needed to come out regardless.
    It wasn't like it could be usable with some TLC, this was salvage regardless
    Footnote;
    Today is my 2nd 6th Bday! I survived a heart attack 6 years ago today !!!
  6. Feb 6, 2025 at 8:01 PM
    Fitting you’re doing a heart transplant on your Tundra! You’re gonna crush it.
  7. Feb 6, 2025 at 8:02 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Happy 2nd 6th bday! Party hearty!
    Hary Gahtoe[OP] and G_unit3000 like this.
  8. Feb 6, 2025 at 8:04 PM
    Well then I completely misunderstood your original post or missed all of that info in it. Good luck in the swap and congrats on the 6 years of second life! Helping save the lives of heart attack patients was my job for many years, one of my favorite times in my career.
  9. Feb 7, 2025 at 1:28 PM
    Hary Gahtoe
    4W 4 door sr5
    Really, thanks for the kind words. If a friend of mine (who's a volunteer fireman ) wasn't right there I wouldn't have made it. No previous symptoms I just collapsed
    If your >50 /or have family history/high stress; please for the sake of your loved ones get a checkup before it's too late.
    Dealing with truck;
    The electrical system needs a total refresh. Maybe even a donor harness. Two ground straps were cut and respliced and the fuse box needs attention.
    To improve longevity, even though the replacement motor is in great shape it's going to get fresh parts that are tough to replace in car
    The starter, exhaust manifolds, H20 pump, timing belt, oil pump and pickup, injectors and fuel pump plus.... whatever it needs.
    That saying nothing worthwhile is easy definitely applies here
  10. Feb 7, 2025 at 2:20 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    If you keep updating, I'll definitely be following along
  11. Feb 10, 2025 at 1:52 PM
    Hary Gahtoe
    4W 4 door sr5
    When I pulled the motor out I realized how the truck was done wrong. In photos earlier it shows only some of the damage done to the electrical system. The main power to the main fuse bank was butchered and not the only problem. When I removed the manifold a ground strap had been hacked up and taped over really bad.
    Looking to replace some of the damage I found a pretty solid looking replacement specifically for Gen I Tundra.
    It has Alternator, battery, ground straps, starter and relay you can also get in better 1/0 GA.
    The bonus is better cables with top notch fittings and are shrink wrapped is a blessing.
    If anybody is using these, by all means reply
    https://www.jeepcables.com/products/toyota-tundra-big-7-battery-cable-kit-gen-1-2000-2006
