1st Gen Slider Options
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jul 2, 2019.
  1. Oct 14, 2022 at 1:21 PM
    #121
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    Maybe for rock crawling. But I for sure don't need the kickout. This truck won't be rock crawling, and no tight forested trails around here (generally speaking), and i dont need a big ole step either. Just want a good rocker protector for that "just in case". I've had other trucks with sliders. These all stick out way too far for what I need.
    Honestly, if I could get the white knuckle or brute force without the kickout, I'd prob just do it and be done. But that kickout is a big fat no from me.
    I guess I'll start looking for a local fabricator that could just do custom.
  2. Oct 14, 2022 at 1:51 PM
    #122
    daveeasa
    David
  3. Oct 21, 2022 at 1:01 AM
    #123
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    I'm doing a set of non kickout bolt ONS for the crewmax now. With no kickout they can be angled a good bit more than normal. The first gens frame cause the legs to be real tight to the pinch weld which makes the angle less than my usual standard angle on sliders.
  4. Oct 22, 2022 at 7:11 AM
    #124
    digitalferg
    First Gen technically didn't use the nomenclature "Crewmax"... that came about with the 2nd Gen. So just want to make sure --you're talking about the First Gen DoubleCab still here? Cause if you are, consider me very interested, and let's see some pics. :)
    BashFab[QUOTED] likes this.
  5. Oct 22, 2022 at 1:21 PM
    #125
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    I haven't done them for the 1st gen access/double cab yet only the 4 door quadcab/crewmax etc. However if you're local to SC and can drop it off for a few hours I can test the CM/DC plates and see if they'll work on the AC
    Here's the pic I took as he was pulling away yesterday.
    BigSkyGuy likes this.
  6. Oct 22, 2022 at 2:00 PM
    #126
    digitalferg
    Looks great on that Crewmax. Something like that would be great.
    As for dropping by.... wish I could... but I'm in Southern Utah.
  7. Oct 22, 2022 at 2:55 PM
    #127
    Casper421
    In the woods
    06 DC
    That is a 1st gen double cab. There’s no quad cab or crew max 1st gen. Regular cab, access cab with half doors and the double cab with 4 full doors.
  8. Oct 22, 2022 at 3:05 PM
    #128
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Thanks for the clarification, I knew they weren't technically called the same thing... but Same thing in my mind, as long as no other cab configuration has 4 full doors I consider it a crewmax. The half door is access cab which is what my Tacoma is. They also only came.in "double cab" form as the largest option.
  9. Oct 22, 2022 at 3:06 PM
    #129
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    I ship, just need an AC to test it on. I'll come across one eventually local though. Untill then weld on is best I got for the single and AC
  10. Oct 22, 2022 at 4:05 PM
    #130
    digitalferg
    Haha. I feel like all this different cab talk is mixing up the convo a little... cause I've got a DC... A 1st Gen DoubleCab.
    But ya, if you make a non-kickout version for it, I'm very interested. And I'd take weld on too. I can have them put on here easy enough.
    Elevatorguy likes this.
  11. Oct 22, 2022 at 4:54 PM
    #131
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Weld on is no problem at all just lmk when you're ready!
    shifty` and digitalferg[QUOTED] like this.
  12. Oct 25, 2022 at 6:42 PM
    #132
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
  13. Oct 25, 2022 at 6:44 PM
    #133
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Why no kick out? They are super handy
    Krewcial and BashFab like this.
  14. Oct 25, 2022 at 6:45 PM
    #134
    digitalferg
    Those are perfect. Show me where to sign.
    mcharfauros likes this.
  15. Oct 25, 2022 at 7:05 PM
    #135
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Agreed, I've never ran into a situation where I wish I didn't have it but I have been making more standards recently
  16. Oct 25, 2022 at 7:23 PM
    #136
    FrenchToasty
    Mo
    Bone stock
    Before I had them, I definitely watched my rear tire get sucked into a rock, and scraped the rim all kinds(it’s a truck who cares)
    I’ve now watched my kick outs bump me away from many obstacles that I thought I had enough clearance around. And they are nice to stand on it and the tire to do stuff ontop of the camper shell.
  17. Oct 25, 2022 at 10:37 PM
    #137
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    I also really enjoy just using them to my advantage when not able to see the other side of the truck if I don't have a passenger, Knowing they're there I can hug things tighter on my side and do exactly as you said and kick the ass end away from whatever it is
  18. Oct 26, 2022 at 5:20 AM
    #138
    I swear I read (maybe in this thread, maybe in the Lunch thread) some folks don't want the kick-out either for looks, shin-whackability, or what. Those are the two reasons that are ringing in my failing memory.
  19. Oct 26, 2022 at 5:45 AM
    #139
    FirstGenVol
    FirstGenVol [OP] Recovering mangler
    East TN
    2002 AC TRD 4x4 V8
    I think it's mostly looks. Some people like the simple high and tight sliders. I can understand that.
    Personally, I'm really happy with my White Knuckle sliders. They were expensive but there are so few options for our trucks it's hard to complain. I'm on the shorter side so being able to use them to access the roof is nice.
    I don't think they stick out too far.
  20. Oct 26, 2022 at 8:14 AM
    #140
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    Is your front bumper BFF or Coastal?
  21. Oct 26, 2022 at 9:22 AM
    #141
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    BFF.
  22. Oct 26, 2022 at 11:52 AM
    #142
    tokolosh
    J
    SF Bay Area
    new driver
    Cool, thanks. I like em both but think i'm leaning towards Coastal.
  23. Jan 12, 2023 at 8:05 AM
    #143
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Some hybrid standards were finishing up! Got a set going out to Utah first thing next week too!
  24. Jan 12, 2023 at 9:54 AM
    #144
    digitalferg
    Those are lookin bitchin! Can't wait.
  25. Oct 4, 2023 at 9:11 PM
    #145
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Any new slider options? I really like the ones that @daveeasa is running here
  26. Oct 5, 2023 at 5:36 AM
    #146
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    @shmellmopwho Any interest in building first gen Tundra sliders?
    shmellmopwho likes this.
  27. Oct 5, 2023 at 7:24 AM
    #147
    dirtnsmores
    Southern CA
    Oh snap. I didn't realize he was on this forum. Also. I already contacted him over at Tacoma world :thumbsup:
  28. Oct 9, 2023 at 8:51 PM
    #148
    shmellmopwho
    shmellmopwho New Member Vendor
    Ryan
    Lomita CA
    I’ve built a couple sets. Definitely down to build some for @dirtnsmores
    Haven’t done any for a 1st gen Double cab. Only the AC
    But after a couple measurements should be very similar
  29. Jan 2, 2024 at 10:58 PM
    #149
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Anybody running Rocky Road? Good response through email but, see they mave have had some unhappy customers in the past ( non slider related) really very few options for 1gr reg cab guys...TIA
  30. Jan 4, 2024 at 11:12 AM
    #150
    inv3ctiv3
    inv3ctiv3 New Member
    Jim Bob
