  1. Jul 26, 2020 at 6:39 AM
    #6181
    Professional Hand Model
    Hand Protectors
    mcharfauros likes this.
  2. Jul 26, 2020 at 6:45 AM
    #6182
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I feel your pain.
    Just run a lead from the battery to the cab. You can wire in a new plug specifically for your fridge, that way you don't need to worry abut the dash cam.
  3. Jul 26, 2020 at 6:49 AM
    #6183
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I appreciate the suggestion but I don't see how this helps me? I still need to convert the outlet to constantly be hot. The fridge cord is plenty long to reach. I don't need an extension. None of the three 12v sources supply power with the truck off.
    theblurry1 and Casper421 like this.
  4. Jul 26, 2020 at 6:56 AM
    #6184
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    You need more width on those high beams, like a light bar with a flood pattern wired to your high beams would help with seeing what’s lurking in the stix
  5. Jul 26, 2020 at 7:00 AM
    #6185
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Camera doesn't do it justice. I'll agree its more "spot light" than what was advertised, but I like it. I think if I had my fogs on at all times instead of just the low beams it would be a GREAT improvement.
    Hooptytrix[QUOTED] likes this.
  6. Jul 26, 2020 at 7:11 AM
    #6186
    Casper421
    In the woods
    06 DC
    I have a few hot plugs, 15a for the fridge. You’re planning for a plug in the bed or cab?
  7. Jul 26, 2020 at 7:12 AM
    #6187
    Hand Protectors
    Your cig lighter doesn’t work with the key out?
  8. Jul 26, 2020 at 7:13 AM
    #6188
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'd like to make one of the cab plugs work. The fridge fits real nicely in the back seat area. I just need to build a little platform for the slide.
  9. Jul 26, 2020 at 7:15 AM
    #6189
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    No sir. I thought one of the 3 outlets would have power with the key out but none did.
  10. Jul 26, 2020 at 7:17 AM
    #6190
    Hand Protectors
  11. Jul 26, 2020 at 7:19 AM
    #6191
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Doesn't solve his issue of running the fridge without running the engine?
    CodyP likes this.
  12. Jul 26, 2020 at 7:20 AM
    #6192
    Hand Protectors
    I’ll have to go out and see if my cig lighter works with ignition off. Pretty sure it does, but I’ve been saving it for the Smithsonian Museum when she gets retired. :rofl:
  13. Jul 26, 2020 at 7:21 AM
    #6193
    Casper421
    In the woods
    06 DC
    I replaced the existing cig plug in the rear of the center console with a 15a from Amazon. It fits snug and looks factory. Have it wired through my fuse block to the battery for constant power. I can snap some pics if that helps.
    NUDRAT[OP] likes this.
  14. Jul 26, 2020 at 7:27 AM
    #6194
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Access cab does not have a rear seat plug. At least mine doesn't.
  15. Jul 26, 2020 at 7:28 AM
    #6195
    Hand Protectors
  16. Jul 26, 2020 at 7:29 AM
    #6196
    Casper421
    In the woods
    06 DC
    Easy fix, hole saw.
    bmf4069 and Tundra2[QUOTED] like this.
  17. Jul 26, 2020 at 7:30 AM
    #6197
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes please. I may try to covert the cig lighter on mine as it's least likely to get used for it's original purpose.
  18. Jul 26, 2020 at 7:33 AM
    #6198
    Casper421
    In the woods
    06 DC
    I’ll go snap some but make sure the plug is rated for the fridge. The 15a gives me some peace of mind over the factory plug. But @bmf4069 will have better knowledge.
    bmf4069 likes this.
  19. Jul 26, 2020 at 7:34 AM
    #6199
    Hand Protectors
    I’ll have to interrupt my coffee time and go check my cig lighter. My assumption is, with ignition off, the cig lighter still works when pushed in. Thus, buy a car power inverter and plug it in and the power is hot constantly even with ignition off? Plug the refer into the inverter and your refer is running constantly with ignition off?
    Long cable is good if you want to remove refer to have it near the tent or power up devices inside tent. :rofl:
  20. Jul 26, 2020 at 7:38 AM
    #6200
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  21. Jul 26, 2020 at 7:41 AM
    #6201
    Casper421
    In the woods
    06 DC
    @FirstGenVol Just a simple plug that fits in the factory spot and I ran the wires down the center console and through the firewall. In line fuse and you’re all set! $20 tops, if you already have wire. No need to waste money on an inverter or extension cord that won’t help you.
  22. Jul 26, 2020 at 7:42 AM
    #6202
    lsaami
    lsaami Let ‘er buck
    Minnesota
    There’s a slot in the factory fuse block under the dash.
    https://www.amazon.com/JABINCO-Circ...ild=1&keywords=fuse+tap&qid=1595774358&sr=8-7
    but one of these guys, and run a power lead to one of your cigarette lighters. Should be good to go.
    you may need to double check that the fuse block gets full time power. I can’t remember if it does or not.
    bmf4069 and FirstGenVol[QUOTED] like this.
  23. Jul 26, 2020 at 7:49 AM
    #6203
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I just checked the cig lighter. It doesn't work with the truck off.
    Accessory is a 15A. I'm assuming this covers the cigarette lighter and the 2 separate 12V?
    NUDRAT[OP] and YardBird like this.
  24. Jul 26, 2020 at 8:01 AM
    #6204
    Casper421
    In the woods
    06 DC
    Yes, that’s why I ran the new plug independently with thicker wire and it’s own fuse.
  25. Jul 26, 2020 at 8:02 AM
    #6205
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Sorry if im misreading but why did disabling daytime lights stop people from pulling in front of you? And i have have no answer for your question sorry
  26. Jul 26, 2020 at 8:04 AM
    #6206
    Pucks18
    Local farm raised meat is more carbon friendly, my great forum friend!
  27. Jul 26, 2020 at 8:04 AM
    #6207
    Hand Protectors
    @FirstGenVol I checked my cig lighter and it does NOT work with key out/off either.
    NUDRAT[OP], FrenchToasty and YardBird like this.
  28. Jul 26, 2020 at 8:06 AM
    #6208
    Pucks18
    I know jack shit about vehicles besides working on mine and stuff. But i will bet 100 bucks that the frame for all engines are the exact same
  29. Jul 26, 2020 at 8:08 AM
    #6209
    Hand Protectors
    Not more carbon friendly than growing ‘E. Coli free’ Spouts in my Underground Bunker! :yes:
  30. Jul 26, 2020 at 8:08 AM
    #6210
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
