How to make 12 volt charger stay on all the time.
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaredmillerdvm, Apr 14, 2018.
  1. Sep 12, 2018 at 7:05 PM
    #61
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Thanks, so your running wire out.
    With that, are both circuits protected independently or tied together?
  2. Sep 13, 2018 at 2:46 AM
    #62
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Independently. You have a fuse for each circuit.
  3. Sep 13, 2018 at 5:10 AM
    #63
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes but from what I have read elsewhere, depending on how its installed they are dependent. If installed correctly they are independent.
  4. Sep 13, 2018 at 7:16 AM
    #64
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes, my point/question though is being missed. Let me find what I was reading and post a link.
  5. Sep 13, 2018 at 7:25 AM
    #65
    14burrito
    2014 SR5 CM 4x4 5.7
    So the way jaredmillerdmv installed it means main is inside and accessory wire is outside. See picture. Just trying to get an idea before I get in there and get working.
  6. Sep 13, 2018 at 9:36 AM
    #66
    14burrito
    2014 SR5 CM 4x4 5.7
    Easy to do over text lol, no worries :)
    Thanks!
  7. Jul 21, 2019 at 1:09 PM
    #67
    EfreeTex
    EfreeTex New Member
    2019 SR5 TSS
    Resurrecting this old thread with some more questions. So, I’m thinking to use an “add a circuit”, and plug into an always hot fuse position. From there, I’m wondering if I can just connect the wire into the existing Power Outlet fuse slot that has a 15 amp fuse currently. Perhaps that’s what others have suggested, but this way I wouldn’t have to pull apart the dash. Though, as my truck has 4 separate power outlets (two on the dash, one in the box and one in the back), I’m dependent on them all using this same circuit.
  8. Jul 21, 2019 at 1:30 PM
    #68
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    If the goal is to make the two cig lighter sockets underneath the climate controls hot all the time, it is a simple fix.
    Under the hood, pop the large fuse/relay cover off and look for the relay titled "P/OUTLET NO.1" (see red rectangle in picture below):
    Pull the relay and fashion a jumper as shown in the photo below and the two outlets will be hot all the time. No risk to the circuit, the relay being jumped just activates the circuit when the key is on. It is still protected by a fuse.
    hagrid and Wallygator like this.
  9. Jul 21, 2019 at 1:36 PM
    #69
    EfreeTex
    EfreeTex New Member
    2019 SR5 TSS
    Thanks for the response. I thought I saw where it wasn’t split out anymore on the Tundras, but perhaps that was incorrect. Does this same relay cover the power ports in the box and in the back?
  10. Jul 21, 2019 at 1:38 PM
    #70
    Bergmen
    Bergmen New Member
    Ukiah, California
    I have not checked but I don't believe so. I never use the rear ones so that wasn't on my radar screen. BTW, my Tundra is 2018.
  11. Jul 21, 2019 at 1:48 PM
    #71
    EfreeTex
    EfreeTex New Member
    2019 SR5 TSS
    Just answered of my questions. Popped the box and see a separate relay. See pic below. Am I correct that I just need to pull the relay and add a jumper wire?
    Will need to test to see if the same circuit covers all of the ports. E9591A09-F362-4EF4-A5D9-C61067D16C19.jpg
  12. Jul 21, 2019 at 1:52 PM
    #72
    Bergmen
    Bergmen New Member
    Ukiah, California
    Very well may be true (if you are referring to "BACK P/W No.1" relay) but mine doesn't have a relay in that slot.
  13. Jul 21, 2019 at 1:56 PM
    #73
    EfreeTex
    EfreeTex New Member
    2019 SR5 TSS
    And...I am quickly wrong. That is for the powered back window. Going to look for a test relay that can bypass vs just a wire. Will see what I can find.
  14. Jul 21, 2019 at 2:00 PM
    #74
    14burrito
    2014 SR5 CM 4x4 5.7
    I believe all outlets are on one fuse, no?
    That trick should make all hot then.
  15. Jul 21, 2019 at 2:18 PM
    #75
    EfreeTex
    EfreeTex New Member
    2019 SR5 TSS
    Just did a quick check. That relay “P/Outlet No. 1” only supplies the dash mounted outlets under the climate control. Need to find which relay covers the back two.
  16. Aug 6, 2019 at 2:31 PM
    #76
    DigitalFusion
    DigitalFusion New Member
    MN
    '15 Platinum Crewmax
    My 2015 crewmax platinum doesnt have a relay labeled "P Outlet 1" anywhere. In the place that is circled in the above pic, there is a relay for "Deicer"?
  17. Aug 6, 2019 at 4:05 PM
    #77
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  18. Aug 6, 2019 at 4:12 PM
    #78
    DigitalFusion
    MN
    ¯\_(ツ)_/¯
    I just finishing tapping into the power wire for the radio, which was a pain in itself because nothing I read matched with my connectors (It ended up being a lavender colored wire). I would have much rather just made a jumper. Oh well, its done and now the two fronts has constant at least
  19. Dec 26, 2019 at 6:39 PM
    #79
    Joeystjean
    Joeystjean New Member
    Joey
    2014 Platinum crew max
    TRD intake/exhaust/light bar/bullydog
    Any reason I cannot jump off a hot fuse to the cig fuse?
  20. Feb 15, 2020 at 1:18 PM
    #80
    azs406
    azs406 New Member
    Cig fuse is before the relay.
  21. Apr 13, 2020 at 3:42 AM
    #81
    Wallygator
    So much conflicting info here. Some have the relay, others don't, etc. No detailed writeup for the other ways...I just need to have constant on to the 12V plug in the back seat. This used to be so easy with a simple jumper. Reading this thread I don't know what to do? Why Toyota doesn't change some things for years but changes this???:notsure:
  22. Aug 16, 2020 at 11:42 PM
    #82
    Itmustbeaduck
    Itmustbeaduck New Member
    2013 Tundra
    What about 2013?
  23. Aug 17, 2022 at 8:29 AM
    #83
    Spotman
    Spotman New Member
    Bob
    Virginia Beach, VA.
    2018 DC White SR
    So far, Weather Tech Front mats and new FOB with auto start and key less entry.
    I just did this to my 2018 DC and works perfectly for two front 12v plugs but not the one in back seat!:monocle: Thank you. At least I can power my Alpicool Fridge. :thumbsup:
