  1. Feb 16, 2024 at 3:23 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Those V70 Rs are awesome. I'd love to have one, but they're pricey for good ones.
  2. Feb 16, 2024 at 6:35 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    A good way to check the current value on your vehicle is with 2 different websites.
    1) Kelley Blue Book
    2) NADA guides
    To top on what Shifty said, Carmax is a good choice as well. You can get a pre-quote on their website but it's a grain of salt estimate as like Shifty said, they will nickle and dime you. I was able to sell mu 21 Tacoma to them in 2022 for $4,000 more than I financed it for. Turned around and put 2k of it into preventative maintenance in this 98 Camry and have been rocking it as my daily driver ever since.
  3. Feb 16, 2024 at 6:44 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Honda is gonna be a good choice if you’re looking for something that higher mileage but still unbelievable reliable. Anything with a k-series motor will last damn well near forever, the parts are very available and are not too expensive. They’re easy to work on/DIY and come with all the modern creature comforts/ features.
    Im currently sitting on a element SC 5spd (needs motor refresh since it’s been sitting cause trans needs to be looked at something broke not allowing me to go into gear and I just gave up on it cause I enjoyed driving the truck so much) and a CRV that’s mint minus some cosmetic things but has 200k and runs like a champ.
  4. Feb 16, 2024 at 6:53 AM
    FishNinja
    Lee
    06DC2wd
    I forgot to mention I even thought about getting one of these and retro-fitting it
  5. Feb 16, 2024 at 6:53 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's beefy compared to my OEM
  6. Feb 16, 2024 at 6:58 AM
    FishNinja
    Lee
    06DC2wd
    yea I got a shitty tube thing too. I mean it gets the job done but if you’re hooning around and making that rack/PS pump work. Something with fins would definitely be a better option. Those are kinda light duty and I wouldn’t recommend for off-road use. For something a little more rugged, I’d look into what that truck had that you pointed out.
  7. Feb 16, 2024 at 7:21 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    @Tundra2 Just don't buy the wife a Navigator. Just put new tires on this morning to the tune of $1700! Not to mention 22 inch wheels help it to ride like complete and utter shit.
  8. Feb 16, 2024 at 8:12 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I helped two good friends of mine purchase cheap, reliable, safe used cars recently. There are lots of deals out there. When they asked me what kind of car they should buy, I straight up said "you are going to buy a 5-20 year old Honda or Toyota, period." Sticking to that rule really helped us out. I would recommend doing the same.
    There is honestly a stunning amount of sub-$4k cars on marketplace that would be safe buys. We believe in you!
  9. Feb 16, 2024 at 8:35 AM
    FiatRunner
    Jack
    I'd like to do this. I've purchased a new-used OEM pump because mine is on it's last legs. The dipstick in my reservoir is all melted because the fluid has gotten so hot. It had been run low long before I got the truck, but one time I was doing a lot of hooning in the snow and the pump started getting really loud. The lines and reservoir were way too hot to touch.
    Being an 00, I don't think mine has the "cooler" that the later trucks do. I figure if the fluid can get that hot in below-freezing temps then it's probably pretty easy to overheat it in the summertime. Where would you put it? Can the lines be long enough to stick it in front of the condenser?
  10. Feb 16, 2024 at 9:07 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Correct
  11. Feb 16, 2024 at 9:20 AM
    daveeasa
    David
    Just noticed my D bulb is out. P, R, N, 2 all good. Funny.
  12. Feb 16, 2024 at 9:26 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  13. Feb 16, 2024 at 9:31 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Quick fix is to swap it with the low ‘L’ gear bulb but if you’re OCD about it, it may be best to buy a new one.
    The Black Mamba likes this.
  14. Feb 16, 2024 at 9:32 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  15. Feb 16, 2024 at 9:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  16. Feb 16, 2024 at 9:54 AM
    FishNinja
    Lee
    06DC2wd
    Not entirely sure where the 00’ lines would be but mine is right here in front of the radiator/ac condensor. It’s a pretty simple unplug/plug in. I couldn’t imagine it being that much more difficult on your truck. You’ll just have to figure out a decent mounting place and extend/make hoses as necessary
    des2mtn likes this.
  17. Feb 16, 2024 at 10:01 AM
    daveeasa
    David
    Thanks, there is a thread for everything.
    I have a ton of bulbs for this ready to go. I think I’m going white and no green but I do have some condoms too IIRC. Guess this is good incentive to do this sooner rather than later. Maybe try to get the RS3000 antenna up the pillar too for better range.
    Let’s hope it’s a chill day at work.
  18. Feb 16, 2024 at 10:04 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Even with white LEDs, the gear indicator is still green. The color for those is on the cluster itself.
  19. Feb 16, 2024 at 10:08 AM
    daveeasa
    David
    Thanks, cool tidbit.
    for the speedo and tech, consensus is white wins? Or blue is also liked? Or split and some like the green?
    des2mtn[QUOTED] likes this.
  20. Feb 16, 2024 at 10:09 AM
    des2mtn
    SW
    Tonto cover
    I personally run amber because they're easy on my eyes.
    PenderBen and FrenchToasty like this.
  21. Feb 16, 2024 at 10:13 AM
    daveeasa
    David
    Also, if I get to this, what’s the vote? Remove airbag bulb permanently or leave it?
  22. Feb 16, 2024 at 10:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought that was only for the newer first gens? My drive bulb had a green rubber condom over it.
    Unless I'm confusing this with another one I swapped. I know the clusters changed at some point because some people chose to sand theirs down.
  23. Feb 16, 2024 at 10:22 AM
    des2mtn
    SW
    Tonto cover
    This is for the older first gens. My original bulbs had the green condom too, but the cluster still has color on it.
    daveeasa likes this.
  24. Feb 16, 2024 at 10:36 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    My ‘D’ light is out too, since this has come up now I’m looking for the bulb; the incandescent replacement is pretty expensive (best I can find is like $30+ for 1), but I could get a pack of LEDs for less, I don’t really want to switch to LEDs, but would there be any problem switching just one of the gear indicator lights to an LED?
    I’m thinking I could do what @Jack McCarthy suggested and swap the ‘L’ bulb to the ‘D’ location and stick the LED in the ‘L’ location (which rarely sees use, but I don’t want burned out). I can’t think of any reason this shouldn’t work, but LEDs can do funny things.
    txagg and NUDRAT[OP] like this.
  25. Feb 16, 2024 at 10:50 AM
    Dakillacore
    Georgia
    I like the green, personally. I think that the white is almost too bright at night. It's not like I have a choice in the matter since mine is soldered into the cluster so I'm glad that I do like it.
  26. Feb 16, 2024 at 10:53 AM
    Jack McCarthy
    Bill
    North of Boston
    Someone posted a link of an incandescent for $12+ the other day, was it you @The Black Mamba ?
  27. Feb 16, 2024 at 11:02 AM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, it’s like $12 on Amazon.com, best I can find, but I’m in Canada, so they want like $15 for shipping and duties, with the exchange rate it’s like $36 :-(
  28. Feb 16, 2024 at 11:07 AM
    Jack McCarthy
    Bill
    North of Boston
    You should ship it to an Amazon locker just over the border and pick it up next time you’re in the area unless you’re way up North in BC.
  29. Feb 16, 2024 at 12:57 PM
    daveeasa
    David
    Ok, any tips on getting polarity correct without trial and error?
    txagg and 455h0le_dachshund like this.
  30. Feb 16, 2024 at 12:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nope.
    daveeasa[QUOTED] likes this.
