1st Gen Exhaust Clips
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Jan 18, 2020.
  1. Oct 14, 2021 at 12:31 PM
    #121
    Casper421
    In the woods
    06 DC
    I think I’m sold. Center in/out and 2.5”? Gonna weld it in till headers and full exhaust in the future.
    Darkness[OP] likes this.
  2. Oct 14, 2021 at 12:45 PM
    #122
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Fixed it for ya
    Center in/out 2.5 works well.
    Casper421[QUOTED] likes this.
  3. Oct 14, 2021 at 12:59 PM
    #123
    Casper421
    In the woods
    06 DC
    My only hesitation to date is the volume at idle. Is it pretty tame? Don’t want my neighbors hating me even more than they do by waking them up at 5:30am. I’ll keep the spintech but now need to decide on long or short tube headers.
    Darkness[QUOTED][OP] likes this.
  4. Oct 14, 2021 at 2:49 PM
    #124
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    @Darkness and @jImmegart you guys are running JBA shorties, Spintech Prostreet muffler, no resonator and the stock pipe dumped right after the rear axle to the side correct?
    My question is I'm assuming you guys reused the factory cat and all the factory piping?
    In my case my exhaust is pretty rusted and I would like to change it up. What would be theist cost effective way to replace everything from the cats back? Not sure if I would like to go with headers yet. I see mostly everyone goes with jba shorties but why not longtubes and some hi flow cats?
    jImmegart and Darkness[OP] like this.
  5. Oct 14, 2021 at 2:54 PM
    #125
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Why not long tubes with no cats!!! MEOW!!!
    Unless you can weld and bend pipe in your garage, it would be best to just take it to a exhaust/muffler shop and let them take care of it all.
    FirstGenVol and Darkness[OP] like this.
  6. Oct 14, 2021 at 3:21 PM
    #126
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Cold starts are a bit loud outside the truck. Quieter than say a duramax diesel but for sure louder than what you're used to. If low rpm is a concern then a resonator would be smart. When mine still had the stock resonator it was more quiet at idle and low rpm. The stock resonator is actually straight through, it doesn't hinder anything at wide open throttle and helps to muffle resonance at low rpm. I cut mine out because I like to party.
    @jImmegart doesn't have headers but the rest is true. We have almost the same setup except I have short headers.
    The topic of long tube vs short, if I lived where long tubes were legal to pass inspection I would have them. I'm in California so I'm stuck with shorties (still considering going to long tubes and pointing out my carb sticker to the ref).
    For your exhaust, if the piping is rotted out your best bet is to find a GOOD exhaust shop and have them fab up the pipes from the cats back, using your muffler of choice and resonator if needed. I would run 2.25" pipe from the cats to a Y and run 2.5" pipe from the Y out. Stock pipe seems to be in metric, 60mm I believe which is roughly 2.39" but stepping up to 2.5 won't hurt. I have a long section of 2.5 in mine.
    For cats, I haven't seen anybody successfully run high flows without a cel, most either run a simulator or keep stock cats in. I haven't gone down any of those paths and can't be sure what works. Maybe spacers on the O2 work, it does on other cars but Toyota makes smart computers.
    jImmegart and Casper421[QUOTED] like this.
  7. Oct 14, 2021 at 3:37 PM
    #127
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I love learning so I ask alot of questions. So im in NJ and you can have long tube I have them on my ZL1 with hi flow cats, so for knowledge purposes. Best system would be JBA long tubes which have a 2.5 collector, 2.5 hi flow cats, y pipe to a Spintech Prostreet muffler existing to the back where the stock exhaust ends.
    If you do the same setup as I explained but with factory cats I'm assuming no CEL would be on correct?
  8. Oct 14, 2021 at 3:42 PM
    #128
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If going long tube I would run 2.5 pipe all the way from the cats back. The collectors on those are 2.5" so dropping to 2.25" right after the cats might hurt. What you described is what I would run if I didn't have smog checks every 2 years. With factory cats I don't think a cel would show up. They don't really seem to "care about" flow, just metering the input and output. So if they're cleaning the exhaust you shouldn't see a cel.
    @FrenchToasty has this kind of setup with dual exhaust, he is experimenting with a reducer to 2.25 at the tips. I like single exhaust myself.
    Casper421 and FrenchToasty like this.
  9. Oct 14, 2021 at 3:46 PM
    #129
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I have smog every 2 years also but as long as no CEL I'm good to go. I like single exhaust also, now for argument sake. Does are truck gain any power from short or long tubes? Does @dirtydeeds do exhaust for are 1st gens?
  10. Oct 14, 2021 at 3:53 PM
    #130
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    He does. They aren't cheap but most customers are happy. You're paying for all the research and taking away any guessing.
    For short headers it's a very hot debate. Some say power is gained, some say nothing happened, some say power is lost. I didn't go doing any dyno runs but my pulls on the freeway felt stronger after putting shorties on. Long tubes on the other hand have no debate, definite power increase. I have only seen one guy say his truck ran worse with long tubes and those weren't the JBA long tubes, it was a brand you can't get anymore.
    FrenchToasty likes this.
  11. Oct 14, 2021 at 3:57 PM
    #131
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Do you know if our trucks need to be tuned to run long tubes or shorties? Or it doesn't make no difference. I tow a decent amount in the summer and any extra TQ or HP I can get will help.
  12. Oct 14, 2021 at 4:07 PM
    #132
    Casper421
    In the woods
    06 DC
    I plan on running the stock resonator to keep idle somewhat quieter. Sounds like JBA long tubes will be the pick. Appreciate it Luis!
  13. Oct 14, 2021 at 4:45 PM
    #133
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    Here we go, got me thinking about headers again :spending:
  14. Oct 14, 2021 at 4:57 PM
    #134
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    I'm adding it to my list just dropped $$$$ on rebuilding front and rear suspension, but I'm asking now so I now what I should start ordering for the future. It would be nice if @dirtydeeds dropped in to see what he offers.
    jImmegart[QUOTED] likes this.
  15. Oct 14, 2021 at 7:15 PM
    #135
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You don't need a tune. You may get an extra couple horses from one but unless you know somebody who can give a great deal its too expensive for what you'll get. You'll get the power without a tune.
  16. Oct 14, 2021 at 7:19 PM
    #136
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    So do you think shorties and long tube will be pretty close to each other HP,TQ wise? I'm wondering how much a full system fro dirtydeeds run. Do they use JBA headers also or do they make there own.
  17. Oct 14, 2021 at 7:31 PM
    #137
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    No, long tubes will be ahead. Maybe 20hp ahead. He uses jba long tubes
  18. Oct 15, 2021 at 4:45 AM
    #138
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The initial start up will be a bit loud because of how high our trucks idle at start but once the RPM's drop it's surprisingly quiet. I left the stock resonator in place.
  19. Oct 27, 2021 at 8:39 PM
    #139
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    It purrs. Following directly behind him, I can hear his truck over mine until about 45 MPH.
  20. Nov 4, 2021 at 6:31 PM
    #140
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    So bringing this topic up again snice I have a hole on my muffler and resonator. So thinking in getting the following and taking it to an exhaust shop to connect everything up. Let me know if I have everything needed. Also what type of flange do I need to get to connect to the stock cat?
    I'm thinking for now go with Spintech Prostreet 6000 muffler 2.5 center inlet/outlet
    https://spintechmufflers.com/6000-pro-street/
    Magnaflow 2.5 Y pipe
    https://www.magnaflow.com/products/10768-custom-builder-parts-y-pipe
  21. Nov 18, 2021 at 6:32 AM
    #141
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    For those of you with the Spintech... If you buy the 2.5" center inlet & outlet, can you just cut the existing pipe & install this directly with a few muffler clamps? Or do you need more parts?
  22. Nov 18, 2021 at 6:44 AM
    #142
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The stock muffler is a lot longer than the Spintech. You'll need around 18" of pipe as well. A muffler shop won't charge much to weld one in.
  23. Nov 23, 2021 at 12:39 PM
    #143
    Casper421
    In the woods
    06 DC
    I second guessed if I ordered the right muffler when I opened the spintech box. Looks about half the size of the stock muffler, maybe.
  24. Nov 23, 2021 at 12:44 PM
    #144
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Audible Volume is related to physical volume. Gonna wanna work on throttle control to make it sound good. My titan has a tiny muffler, and as long as im gentle it sounds great, if i lay into it, it ‘slaps’ and if i carry the rpm too high it ‘claps’.
  25. Nov 23, 2021 at 1:36 PM
    #145
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    They're pretty small. I think about 4x6x12 for the muffler body, not counting the inlet and outlet pipes. I was pretty surprised the first time I saw them.
    You got the 6000 series right? Not the 9000, the 9000 is tiny, I've seen cell phones with a bigger footprint.
    Post a video on acceleration once you get it installed if you can. I'm curious to hear one when vvt-i kicks in.
  26. Nov 23, 2021 at 1:49 PM
    #146
    Casper421
    In the woods
    06 DC
    Yeah, I got the 6000. Might have some time to weld it in this weekend. Then gotta figure out how to upload to YouTube, that’s the difficult part.
  27. Dec 2, 2021 at 9:16 AM
    #147
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Casper421[QUOTED] and dinosaur like this.
  28. Dec 2, 2021 at 9:43 AM
    #148
    Casper421
    In the woods
    06 DC
    Too many other projects. Gonna have to wait till next week after Death Valley.
  29. Dec 30, 2021 at 9:33 PM
    #149
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    I have a Walker system from manifolds back, I'm not really happy with it. It's got a weird vibration when accelerating and the rpms hit about 2400-2500. It isn't there above or below that point. Wish I would've spent more on a nicer system.
  30. Aug 16, 2022 at 11:52 AM
    #150
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
