1st gen cab mounts
Discussion in '1st Gen Tundras (2000-2006)' started by taranovich92, Dec 20, 2024.
  1. Dec 20, 2024 at 7:16 AM
    taranovich92
    taranovich92 [OP] 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Yokohama Geolander AT 285/70/17, Apple CarPlay, CB radio, Firestik hood mount antenna, Randy Ellis Design front bar, Hella 500 rally lights, Hella horn, Mini LED projector headlights, Trailrunner Customs fogs.
    I began my project of replacing the cab mounts on my 2003 access cab. The plan is to do the 2 rear mounts and then the 2 front mounts on a later day. The radiator support mounts are in good shape so I won't replace those ones. The two 10mm bolts that hold that cab mounts to the frame come down from the top of the frame and thread into welded nuts on the bottom side of the frame pockets. I don't understand how you can remove those without lifting the entire cab up over the frame (atleast on the rear two mounts). You can hardly even get a box wrench in there let alone a ratchet, and forget about leverage, you have none in that kind of position. I'm assuming if you have that job done at the dealer, they probably replace all 4 and float the cab over the frame on the lift to gain access to those 10mm bolts. For people like me who are doing this in their driveway, The only option I can think of is to cut the tails off those bolts and drill through them so that I can flip those bolts to face upward instead of downward and just through-bolting them with slightly longer bolts and flange nuts on top. Just curious how other people have done this.
  2. Dec 20, 2024 at 8:41 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    noahrexion and taranovich92[OP] like this.
  3. Dec 20, 2024 at 9:38 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
  4. Dec 20, 2024 at 9:42 AM
    noahrexion
    Washington
    2005 4WD DC
    Are you trying to replace with OEM mounts and reusing the welded cap nuts?
  5. Dec 20, 2024 at 10:02 AM
    taranovich92
    replacing with OEM mounts. Also got new OEM center bolts & OEM lower washers. Was planning on getting new m10x1.25 bolts and flange nuts to replace the welded nuts.
  6. Dec 20, 2024 at 11:23 AM
    @Jack McCarthy has ample experience and I have one or more links to details on replacing the cab mounts in the Megathread sticky if it helps.
  7. Dec 20, 2024 at 11:32 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I cut the welded nuts off and put in Energy Suspension’s cab mount kit 8.4109G which comes with nut and bolt hardware. There’s an entire thread on it here I created when I found my cab was leaning in the rear and could hear metal on metal going over road bumps because my cab mount imploded.
    If you’re a purist, it can still be done with OEM mounts, you just need to lift the cab up 4 inches on one side and maybe get a right angle impact in there if they’re rusted into the frame nuts.
    With the kit I used, I only had to lift it a couple inches at most.
  8. Dec 20, 2024 at 11:33 AM
    taranovich92
    Thanks for the reply, I'd obviously like to get those bolts out without having to drill them out but I just don't see how it's possible without raising the entire cab off the frame.
  9. Dec 20, 2024 at 11:34 AM
    taranovich92
    Awesome, I'm going to do the same thing but i'll be using OEM mounts.
  10. Dec 20, 2024 at 12:02 PM
    Yup, I linked it near the very top of the the community megastickythread because it's a pretty important tidbit you shared in that one:
    • Check all four cab mounts for rust. It's possible (not "easy") to replace cab mounts. This thread may help on replacement.
    Probably sound like a broken record, but we've tried to make that sticky thread the go-to for anything wrong with our trucks. All you gotta do is search the 1st page for a keyword. I found that seraching for "cab mount"
  11. Dec 23, 2024 at 6:34 PM
    MI_Treetaco
    MI_Treetaco New Member
    99 Tacoma trustyboy, 06 Tundra rustyboy
  12. Dec 28, 2024 at 8:19 AM
    Richid
    Richid New Member
    You can - mostly. I had one collapse and faced the same problem. Loosened the front cab mount and was able to easily lift the cab ~12in. - could probably got more, but was just replacing the broken one. Oh, and I used the OEM replacement.
  13. Dec 28, 2024 at 8:24 AM
    taranovich92
    I was thinking the same thing. If all the cab mount center bolts are backed out quite a bit I'm sure there will be alot of room to play with.
  14. Dec 28, 2024 at 8:26 AM
    Jack McCarthy
    Bill
    North of Boston
    So there’s enough slack in the fuel lines and brake lines coming off the master cylinder/ABS block to allow that much height? I’ll have to take a second look at that myself.
  15. Dec 28, 2024 at 8:29 AM
    Richid
    Richid New Member
    I didn't even fully remove the front cab mount bolt. It was at least 3" off the frame.
    No ABS, so just the brake lines - and they were fine.
  16. Dec 28, 2024 at 8:56 AM
    This is the method I always recommend, jacking the cab up off the frame after disconnecting the mount, and people always think I'm crazy.
  17. Dec 29, 2024 at 3:18 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My daughter has an '01 with a 2" body lift. It took me a while to process what I was looking at...the engine seemed too low in the engine bay. Yes, all that stuff just stretches out to accommodate the lift. The splash guards in the wheel wells no longer fit, but other than that everything seemed more or less the same. I'm uncertain, however, how the steering shaft was extended. Next time I get the chance (she's ~ 2,000 miles away) I'll take a better look.
    Jack McCarthy likes this.
