19' and 20' No Trans Cooler
Discussion in 'Towing & Hauling' started by Ruggybuggy, Dec 21, 2019.
  1. Dec 26, 2019 at 8:13 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You're probably thinking of this thread, Post #255 by @pickeledpigsfeet
    https://www.tundras.com/threads/2019-5-7-trans-cooler-location.33216/
    In Post 255, @pickeledpigsfeet said this:
    @pickeledpigsfeet also said this (Post 263):
    So...It was actually @pickeledpigsfeet that contacted Valvoline Tech Services. I didn't remember the degradation temperature of MaxLife correctly: It was actually 280 degrees F, not 240 degrees as I remembered. Sorry for the misinformation.
  2. Dec 26, 2019 at 8:40 PM
    muledawg
    muledawg New Member
    Ryan
    Indianapolis,IN
    2019 Silver Sky Metallic TRD CM
    I have not had an issue yet. I pull my 19’ Rzr turbo 4 seater aboard my 18’ tandem axle trailer down in the mountains of KY & TN. Pulls like a champ with those 4.30 running gears matched to the powerhouse 5.7.
  3. Dec 26, 2019 at 8:45 PM
    JohnLakeman
    One additional comment: If you are serious about setting up a thread dedicated to collecting 2019+ ATF temperatures under towing conditions, you need to request the mods set up a "sticky" thread in the "Towing and Hauling" forum.
    There are probably hundreds of posts to Tundras.com daily. Unless there are frequent posts to any thread to bump it to the top, it disappears from most members view in as little as one day.
  4. Dec 27, 2019 at 4:26 AM
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Requested
  5. Dec 27, 2019 at 4:46 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Well depends on ambient temps and distance you travel. Yesterday I drove mine 25+ miles Before the Trans TC and Pan temps finally reached the same as the engine, 185 during 60degree weather.
    What are you numbers? : ^ ))))
  6. Dec 27, 2019 at 4:52 AM
    ZPMAN
    Minnesota
    It's in the 30s right now but earley this year it was -10 and it took forever for the trans temp to rise. When it gets -30 agian I will check how long it takes to get up to temp.
  7. Dec 27, 2019 at 5:47 AM
    JohnLakeman
    I've never requested a "sticky thread", but I suspect that getting a thread made "sticky" is not as easy as typing the word "requested" in a post. OTOH, my original suggestion for a "sticky thread" is probably unnecessary. The "Towing and Hauling" forum is a smaller, slower forum. If 2019+ owners go directly to the "Towing and Hauling" forum, your thread should be visible on the first page of 50 for a (couple of months).
    If you want a thread about 2019+ ATF temperatures that doesn't attract a lot of other discussion, you need a thread title that is very specific and narrow in topic, e.g. "What ATF Temperatures Towing With 2019+ Tundras?", (or "Maximum ATF Temperatures Towing With 2019+ Tundras?"). Maybe even a poll. Some have said polls don't work, but they have to be designed properly. A poll gives the respondent a slot for his observation, even if they have no other valuable comments like trailer load, terrain, and ambient temperature. FWIW.
  8. Dec 27, 2019 at 5:51 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I may actually scap this this thread and start a new one. We'll see where it goes.
    JohnLakeman[QUOTED] likes this.
  9. Dec 30, 2019 at 6:00 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I think the only post about the temp warning light coming on was a 17 or 18. Have to see if I can find the post.
    Ruggybuggy[OP] likes this.
