19-21 Tundra (No Transmission Cooler) Miles Survey [OFFICIAL THREAD]
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stan7174, Dec 8, 2024.
  1. Dec 17, 2024 at 6:48 AM
    #61
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    One would think and the window stickers on the 19-20 models lead you to believe you did but that isn't the case.
    some info here... https://www.tundras.com/threads/5-7l-transmission-cooler-kits.60550/
  2. Dec 17, 2024 at 6:53 AM
    #62
    bpilati
    bpilati New Member
    2020 Magnetic Gray Metallic DC 4x4 SR5 TRD 2.5 Gen
    Rear cap, LED lighting upgrades, deck/bed railing system, truck bed storage box
    Appreciate the post. I bought mine used at a Nissan dealer, so no Toyota window sticker, and their window sticker says nothing about it, but there are other inaccuracies as well. $1300 is about the going rate on a good oil cooler? I like the fact they use Toyota plumbing. Have you installed this system yourself?
  3. Dec 17, 2024 at 6:57 AM
    #63
    Gaston
    Gaston New Member
    Gary
    SE MI
    I have not, still debating if I want to or not. If I do install a cooler for the transmission I'll likely go the DIY route https://www.tundras.com/threads/diy-trans-cooler-for-300.146998/
  4. Dec 17, 2024 at 7:09 AM
    #64
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Year:2020
    Miles: 81k
    Transmission fluid interval: Drain and fill at 60k miles
    Towing (y/n): Occasionally. Max ~3500 lbs about 230 miles once or twice a year.
    Towing Frequency:3-4 times per year
    Temp Monitoring (y/n): N
    No tranny issues of any type.
  5. Dec 17, 2024 at 7:19 AM
    #65
    bpilati
    bpilati New Member
  6. Dec 17, 2024 at 7:42 AM
    #66
    Gaston
    Gaston New Member
    Gary
    SE MI
    You're paying for the convenience of an assembled ready to install kit. Nothing wrong with it, I just don't feel like spending that much. You can piece the same kit together for less, not that it's any less of a finished product. What gets some people is needing a bracket to mount the cooler, the kit comes with one made for the supplied cooler. I do design work at a machine shop, I feel pretty comfortable I can design a bracket for a cooler and make it. I did just that when I bought my boat, I designed and made all the plates/brackets/mounts for the screens I placed at the bow and console out of 1/4" aluminum.
    Henry1jg and bpilati[QUOTED] like this.
  7. Dec 17, 2024 at 8:38 AM
    #67
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Ouch, $1300 nowadays? That kit was $900 when I bought it in July 2021.
  8. Dec 17, 2024 at 9:53 AM
    #68
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Most things that were $900 in 2021 are $1300 today.
  9. Dec 17, 2024 at 11:26 AM
    #69
    Stan7174
    Stan7174 [OP] New Member
    2021 Tundra SR5 5.7 4x4 Double Cab
    Stock
    Just for personal decision on whether or not to get a cooler and for people in the future to have a collected thread, haven’t seen a survey anywhere, so started one.
  10. Dec 18, 2024 at 5:49 AM
    #70
    mms
    mms New Member
    Year:2020 platium crew cab 4x4
    Miles: 100,800
    Transmission fluid interval: Drain and fill at 60k miles, every 20k after
    Towing (y/n): y some in the summer weekends tow a boat to the lake 4k roughly 120 mile round trip
    Towing Frequency: 8 times a year
    Temp Monitoring (y/n): y it gets hot 220-230 unleaded average 240-250 spikes towning
    2WD and Stan7174[OP] like this.
  11. Dec 18, 2024 at 6:21 AM
    #71
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    2019
    102,000
    44,000
    Never tow
    Dealer performed 2 evil tranny flushes and it still shifts as new. I’ll continue trans fluid flushes every 40Kish.
  12. Dec 18, 2024 at 10:53 AM
    #72
    Stan7174
    Stock
    Added to leaderboard.
  13. Dec 20, 2024 at 8:53 PM
    #73
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Tundra Dude 45, 2WD and batman900 like this.
  14. Dec 26, 2024 at 5:56 PM
    #74
    Stan7174
    Stock
    There’s a guy on Reddit with a 2019 Tundra
    Considering adding the 900,000 mile 2019 tundra from Reddit to the leaderboard. It went 500k miles on the first transmission.
  15. Dec 27, 2024 at 3:07 AM
    #75
    Creepbam
    Creepbam New Member
    2020 SR5 4x4
    year: 2020
    mileage: 85k
    towing: yes 4-5 times/month around 4k pounds
    service: transmission was flushed at 50k by dealer when they repaired the transmission pan gasket leak
    issues: zero (besides gasket leak)
  16. Feb 19, 2025 at 4:42 PM
    #76
    Stan7174
    Stock
    Any updates guys?
  17. Mar 26, 2025 at 9:05 PM
    #77
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Cooler has been installed. Tranny stays around 185 when not towing, even when going up Mt. passes. Towing a small trailer with my side by side it catches a lot of air and it stays around 185 until I climb a pass, then it may spike to 190-195, but drops quickly to 185. So far so good. Real test is this summer in hot weather, towing 5k and then using some 4WD hi goofing off in the desert, but I expect it to stay cool doing both. Very happy so far.
  18. Mar 27, 2025 at 6:53 AM
    #78
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Assuming by goofing off you mean blasting around the sand at speed but if not you should use 4-lo in the sand, it keeps the transmission much cooler. A couple of the times people on here have seen the high temp light come on on these forums is people using 4-hi crawling around the beach.
  19. Mar 27, 2025 at 9:09 AM
    #79
    Pmac
    Pmac New Member
    No sand, blasting around the desert in 4 hi is going to happen. One of the reasons I put the cooler in. Even just driving around on BLM two tracks in 4 hi it would get too hot. 4 lo won’t go past 4th and is too slow. My hope is the cooler makes 4 hi viable for this, like it was in all my other rigs.
  20. Mar 27, 2025 at 9:20 AM
    #80
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Though I agree, I think some of those posts were people who didn't have a cooler.
