15k miles Transmission drain and fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, May 1, 2021.
  1. May 5, 2021 at 6:20 PM
    #91
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I want to be just like you when I grow up.
    RJVA and Joe333x[OP] like this.
  2. May 5, 2021 at 8:11 PM
    #92
    Thank you for the information you offered. I was looking for something in an article at least. I can’t find anything on Bobs the oil guy site or anywhere that would back this up though.
    https://www.joebowmanautoplaza.com/blog/does-changing-your-transmission-fluid-722120
    Now this one talks a little bit about how old fluid will help a worn transmission shift/not slip...but the problem is already there.
    https://drivecave.com/changing-transmission-fluid-damage/
  3. May 5, 2021 at 8:50 PM
    #93
    Joe333x
    Joe333x [OP] Member
    Boston
    2019 Tundra CrewMax Platinum
    He did know a guy that told him something once though. I was thinking by his logic maybe adding some sand in my next fluid change, you know because it helps add friction.
  4. May 5, 2021 at 9:18 PM
    #94
    Well, I’m not going to discredit anything. Wouldn’t be the first time my ego outran my knowledge on here and had to eat some crow.
  5. May 6, 2021 at 8:41 AM
    #95
    Rocko9999
    Rocko9999 New Member
    Do the 5.7 and 4.6 have the same transmission?
  6. May 6, 2021 at 10:11 AM
    #96
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I used to work for a company that manufactured Hydrogenated Nitrile (HNBR). Extremely durable elastomer. We sent samples to Hydromatic so they could test in transmissions. It is how I met their design engineers, not manufacturing maintenance engineers but design engineers. In the end after 150K miles of simulated testing they didn't like our product. Problem was it showed zero degradation. Hydramatic in the business of selling transmissions. I wonder if they lied to me to create another transmission failure... Makes sense now.
  7. May 6, 2021 at 11:30 AM
    #97
    timsp8
    NY
    No.
    Rocko9999[QUOTED] likes this.
  8. May 6, 2021 at 11:34 AM
    #98
    Rocko9999
    Thanks. Was wondering if the fill hole was near the same spot.
    timsp8[QUOTED] likes this.
  9. May 6, 2021 at 11:41 AM
    #99
    timsp8
    NY
    Maybe. I’ve seen threads of 4.7 owners putting on a cooler and it looked like the same process. Pretty sure they don’t have a dipstick either.
  10. May 6, 2021 at 1:13 PM
    #100
    mb66l79
    mb66l79 New Member
    Thanks for the background, makes more sense where you're coming from. One thing that really sticks out to me is that engineers, like any other profession, there is a wide range from scary good ones to scary bad ones. Who knows where the ones that told you that fall. My opinion is that they misinformed you.
    RJVA likes this.
  11. May 6, 2021 at 1:30 PM
    #101
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Reading that Wikipedia page I'm seeing two transmissions for a 2019 5.7l 4WD. The AB60E and AB60F.
    AB60E has torque converter lockup in 4th, 5th, and 6th gear. AB60F has torque converter lockup in 5th and 6th gear.
    I'm thinking the AB60E is for the Sequoia 4WD which has the Torsen center diff. Reason I say that is because the LC200 with 5.7l and Torsen has an AB60E.
    2019 Tundra 5.7 4WD has the AB60F I think, slight difference because of the Torsen center diff.
  12. May 6, 2021 at 2:21 PM
    #102
    timsp8
    NY
    I can’t find much info except this one website. Says the AB60F is for 4wd cause it has a connection for the transfer case. Not sure of it’s accuracy.
    “To back up its brawny new image, a new 6–speed AB60E transmission was put behind the equally new 3UR-FE 5.7L V8 and 1UR-FE 4.6L V8. The Toyota Tundra AB60F transmission was put in four-wheel-drive models, and allowed for connection to a transfer case.”
    https://www.transmissionrepaircostguide.com/ab60e/
  13. May 6, 2021 at 3:14 PM
    #103
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    Hat off to people do it every 15,000 miles and hoping your will last more than 400,000 mile. We have a member run the truck for 400,000 miles and never change out the fluid.
  14. May 6, 2021 at 4:27 PM
    #104
    Summitroad
    Summitroad New Member
    His Tundra has a factory oil cooler, that is why lasted that long with no issues, my 2007 has over 200K of abuse, no issues either
  15. May 6, 2021 at 6:09 PM
    #105
    Joe333x
    Joe333x [OP] Member
    Boston
    Exactly the whole reason I started this post and the reason I changed the fluid at 15k to begin with is to see what it looked like having gone through insane heat cycles unlike ones with a cooler that rarely see over 220. I can go over 220 just driving 65mph down the highway not towing.
  16. May 6, 2021 at 6:41 PM
    #106
    Summitroad
    I dont care what Mike Sweers says. IMHO is just to increase profits, not QRD, after all these are the last Tundras as we known them.
  17. May 6, 2021 at 9:13 PM
    #107
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’m going to follow exactly what my manual states for the simple reason that I have limited transmission knowledge and I’m going to believe the ones who wrote the manual have a lot.
  18. May 7, 2021 at 10:41 AM
    #108
    Rocko9999
    In general, for the average user, I think this is the best advice. Follow the manual intervals, use OEM or higher quality fluids. I don't think any harm comes from using the special operating conditions intervals even if driven normally either.
    I wish we had fluid analysis from samples pulled at 60, 100K to see how they hold up.
    BTBAKER[QUOTED] likes this.
  19. May 7, 2021 at 10:49 AM
    #109
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    No no no no no...
    farnsrocket likes this.
  20. May 7, 2021 at 10:58 AM
    #110
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    As long as they're not the same dudes that believe in "lifetime fluid", then you should be fine...
    NWPirate likes this.
  21. May 7, 2021 at 11:02 AM
    #111
    Rocko9999
    Do we not have intel on the fluid from long drain intervals on Tundras?
  22. May 7, 2021 at 11:05 AM
    #112
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Some people just do not understand that certain threads are not the appropriate context for anything resembling common sense.
  23. May 7, 2021 at 11:08 AM
    #113
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Thing is, transmissions that have never been serviced will continue to work for an undetermined amount of time and being Toyota... that could be along time. However, the longer you wait to service it, the most likely it is to slip after doing it.
    WS is cheap, transmissions are not, so that's one a hell of an experiment if anyone's willing to run his/her Tundra without ever servicing the tranny :D
    Joe333x[OP] and 15whtrd like this.
  24. May 7, 2021 at 11:16 AM
    #114
    Rocko9999
    I agree. I never bought into lifetime anything. I would just like to see how bad the fluid is at Toyotas recommended interval.
  25. May 7, 2021 at 12:42 PM
    #115
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    No. Fill for A760 is located on the tail shaft housing.
    The funnel and hose method from the sill could be made to work after a fashion, using 2-3 people. I decided it will be tricky to manage without wasting a couple of quarts of fluid in the tube low spot (transmission fill port higher than frame), with one quart spilled removing the tube.
  26. May 7, 2021 at 1:24 PM
    #116
    Rocko9999
    Ah, good to know. Thanks. Looks like pumping it in is the only option.
    JohnLakeman[QUOTED] likes this.
  27. May 7, 2021 at 1:51 PM
    #117
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    A guy I knew in high school couldn't get a prom date. That sounded like his prom night.
  28. May 7, 2021 at 1:52 PM
    #118
    JohnLakeman
    Actually, I should clarify my answer if you plan to use that info.
    For A760E (2WD), fill port is in the tail shaft housing on the passenger side.
    For A760F (4WD), fill port is in the adapter (Edit: driver side) between transmission and transfer case. It will be a 24mm? hex head bolt right at the (Edit: transmission case) flange. The bolt head will have the letters "WS" for World Standard ATF.
  29. May 7, 2021 at 1:54 PM
    #119
    Rocko9999
    Thanks. I didn't see one video on the fluid change with a 4.6L, I would have been looking for a while.
  30. May 7, 2021 at 2:07 PM
    #120
    JohnLakeman
    Alright, one more try to get this right. :anonymous:
    The A760F fill port IS in the adapter housing, BUT ON THE DRIVER SIDE.
