15k miles Transmission drain and fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, May 1, 2021.
  1. May 1, 2021 at 5:27 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    2019 Tundra CrewMax Platinum
    With all the discussion on the deletion of the trans cooler I decided that I'll do drain and fills once a year or so to keep the fluid fresh. Used two empty water gallons to measure what came out and put the same back in. Next time I'll probably just do 4qts its close enough to exactly 4qts that comes out. I was quiet surprised with the color of the fluid after just 15,000 miles. Only towed a boat once, other than that I dont haul anything besides me and the dogs. Don't really go over 65mph very often either.
    AZ_Tundra1, The Dude, SSPey and 10 others like this.
  2. May 1, 2021 at 5:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Do you use Mama Toyota fluid?
    Saltyhero13 likes this.
  3. May 1, 2021 at 5:32 PM
    Professional Hand Model
    Hand Protectors
  4. May 1, 2021 at 5:36 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Very interesting. So you just drained and refilled whatever came out right?
  5. May 1, 2021 at 5:37 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Yeah, was contemplating switching to something I can get at Walmart like Valvoline but figured since I'm going to be mixing fluids together that Ill stick with the WS fluid.
  6. May 1, 2021 at 5:38 PM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    That's is quite impressive. My son had a '05 Tundra with 170K+ miles on it when we got it and the tranny was butter and the fluid super clean when we got it. My guess is that the first (and only) owner treated his kit like you do. On behalf of the future guy that buy this rig from you in the future, hat tip.
  7. May 1, 2021 at 5:40 PM
    NWPirate
    Zach
    WA
    I thought so too, did you get the trans up to the correct temp and pull the check plug?
  8. May 1, 2021 at 5:47 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Yes sir, that's actually all Toyota ever calls for but they recommend it much later. From what I understand even dealers only do drain and fills which is only 4qts out of maybe 12. When the tranny had a cooler you could much more easily drain all the fluid from the cooler hose but now thats obviously not an option. The filter is just a screen so there is really no need to ever drop the pan either especially since I've heard people typically have issues with snapping the bolts that hold it on.
  9. May 1, 2021 at 5:54 PM
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    Any chance you are going to send some to Blackstone?
    rebmo, Wallygator and Saltyhero13 like this.
  10. May 1, 2021 at 8:04 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    I didnt, I do have techstream plus an OBDlink to check the temp and do that whole procedure but I figured that putting in what came out would be a hell of a lot easier than doing the temperature check plug thing.
  11. May 1, 2021 at 8:07 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    I did put some in a Blackstone test kit, i currently have 3 kits with different fluids i wanted to test but never end up sending them out. This one i think i actually might do though just for pure curiosity, wish it wasn't so expensive though.
  12. May 1, 2021 at 8:59 PM
    NWPirate
    Zach
    WA
    As long as the new and old were close to the same temp, you should be good to go!
    Now I need to get mine done :thumbsup:
    Jerry Te37 likes this.
  13. May 1, 2021 at 9:21 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    The truck was cooled down so both fluids were ambient temp. I was a bit hesitant to do mine since I had never done one before on a vehicle but it was very easy using the Slippery Pete pump from Amazon. https://www.amazon.com/dp/B07DTS8N7P/ref=cm_sw_r_sms_apa_glt_i_M5BP8H4X17PCC5QSRYFK?_encoding=UTF8
    You'll also need a 24mm socket for the fill bolt or a 15/16 worked just fine for me.
  14. May 1, 2021 at 9:31 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I would always measure what comes out. For some reason folks report draining different amounts out, like 3 - 4ish quarts. I know I measured 4.5 quarts drained when I did mine.
    Joe333x[QUOTED][OP] and NWPirate like this.
  15. May 1, 2021 at 9:36 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Probably depends on the temperature of the fluid when draining and also if anyone ever changed the fluid before. Mine came out to about 3.73 quarts and I figured with the bit of loss with the wind blowing some of the draining fluid onto the driveway and the amount of fluid that sticks to the drain pan along with the amount of fluid that stays stuck in the pump tube and bottom of the bottles I'd just do 4qts and call it a day. Definitely would recommend measuring though. My drain pan I used basically showed 4 quarts but I still did the water gallon thing along with a scale just to be sure but next time if the pan shows about 4qts drained I'll just pump in 4qts. Theres definitely some room for error considering the silly check procedure Toyota has rather than a simple dip stick theres no way of telling exactly how much fluid is in there.
  16. May 1, 2021 at 9:36 PM
    NWPirate
    Zach
    WA
    Ordered, thanks! Been looking for a quality transfer pump
    Joe333x[QUOTED][OP] likes this.
  17. May 1, 2021 at 9:50 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    No problem I definitely recommend it, I also have the Slippery Pete pump for the differential fluid bottles which does work but this one works a lot better, it has a much faster fill rate. I may see if theres a way I can make the one I used for the transmission fit the differential fluid bottles. One tip I would say though and I had seen another Amazon review comment on it. These little black plastic tabs are super flimsy and break. I took it out of the package and one was actually already broken off, so I broke off the other one first before even using it, last thing you want is a piece of plastic floating around in your transmission.
  18. May 1, 2021 at 10:03 PM
    NWPirate
    Zach
    WA
    :hattip:
  19. May 2, 2021 at 2:05 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    That fluid looks pretty nasty for 15K miles...just sayin'.
    Please send off your sample to Blackstone, and post your results. :thumbsup:
  20. May 2, 2021 at 7:08 AM
    Rocko9999
    Rocko9999 New Member
    How do you pump back in 100% of a specific measured amount-with the draw tube not being able to pick up all of the fluid in the bottle of clean fluid?
    Also, how much fluid remains in the pump and lines?
  21. May 2, 2021 at 8:14 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Changing every 15K miles you will wear your clutches out. The darkened fluid is caused by clutch material and you guessed it that adds friction material to the fluid which makes your clutches work better. So. now with new fluid the clutches will slip more because the fluid has to build of its coefficient of friction again by wearing your clutches. Old fluid looks perfect. Why trust the Toyota engineers that it doesn't need a cooler but don't trust on change interval??
  22. May 2, 2021 at 9:02 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Thank you OP. Just rolled 20,000 miles on my 2019, will go ahead and drain/fill and will order the pump you recommended. Wishing you many many miles of smiles with your Tundra!
    Joe333x[OP] likes this.
  23. May 2, 2021 at 9:05 AM
    Joe333x
    Joe333x [OP] Member
    Boston
    Thats exactly why I ended up just putting in 4qts rather than what I measure out which was 3.7qts
    Sorry man but that is very incorrect. I believe you are mixing up information. There is one instance that is believed to be better off not changing fluid and that is if you have a vehicle that has high miles and it has never been changed it recommend not to do a full flush because the machine that forces the fluid in can end up pushing metal particles that have built up over time into places they shouldn't be causing damage and possibly taking out a gritty fluid that is actually helping a damage transmission last longer by causing more friction than there is supposed to be. Changing your transmission fluid with a drain and fill will not cause more wear on your transmission, if you have what you are referring to as "friction material" in your transmission fluid, that material is going to cause things to wear out faster. Similar to how sandpaper would be referred to as a friction material and if you rub it on wood it will wear out that spot on the wood, where as of you rub oil on the wood that obviously will not happen. I do understand this is a forum and all opinions are welcome but what you are saying is just wrong. As far as the cooler goes I do not believe it should have been removed but I also do not want to spend the time and money on adding one as I do not tow and also dont typically drive much longer than 20-30 minutes at a time and I monitor the temperature of the fluid on every drive and definitely believe Toyota only removed it to pinch pennies knowing that it will work just fine but definitely will shorten the life of the transmission but by that time it will be out of warranty so they win.
  24. May 2, 2021 at 9:07 AM
    Joe333x
    Joe333x [OP] Member
    Boston
    Thanks man! You as well! Let me know if you have any questions, YouTube also has lots of informative videos if you are a visual learner as myself.
  25. May 2, 2021 at 9:16 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    So far everything I've learned from the Toyota head mechanics and local transmission shops is that clutch packs are greatly affected by dirty fluid other than clogging or fluid starvation, those last two are symptoms of poor/no maintenance. The more goo builds up, the more likely to create a big blob that will be eventually taken for a ride by new ATF/WS and clog something. Basically, you get 3 options:
    -Never change it and hope for the best, maybe it'll last more than 100K mi., at this point, changing the fluid can do more harm than good.
    -Drain and fill 3-4 times in a 50-60K mi. period (what actual mechanics recommend), if you missed it, flush it and then adopt that schedule.
    -Drain and fill every 10K miles and sort of overdoit, while expensive -just as overdoing engine oil- it will not hurt.
    "sealed" and "lifetime" gets thrown around a lot because it creates revenue when some poor soul forgets to change the fluid. Inventory that never leaves the warehouse costs money.
    GAknight and Joe333x[OP] like this.
  26. May 2, 2021 at 9:45 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Transmission shops are self fulfilling prophecies. They want failures, they need failures to stay in business. I would follow Toyota schedule. Nothing more nothing less.
    After 180K miles on my Lexus a solenoid went bad in the transmission, I had to drop the pan to replace. Pan was spotless, filter was spotless. Owned car since new only transmission service was open transmission pan drain plug 2 quarts came out 2 went in every 60K miles.
    Lexus wanted $500 for solenoid I went to pick a part $10 that was 8K miles ago.
    Trooper2, Darkness and Tundrastruck91 like this.
  27. May 2, 2021 at 2:33 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Tundrastruck91 likes this.
  28. May 2, 2021 at 2:39 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
  29. May 2, 2021 at 4:46 PM
    JohnLakeman
    Don't watch this hack.
    In that video, he suggests pumping all the old fluid out before adding any back, and when he does, he overfills the transmission pan/housing to avoid multiple additions. Not my style. He's selling Amsoil...poorly.
    BlueRibbon4x4 and Kywildman like this.
  30. May 2, 2021 at 5:26 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    After he initially drained the pan and replaced the filter, he added more back in than what initially drained.
    I was wondering about the other side of the return line once he unhooked it...hence my comments about it being interesting.
    I think it would have been better to have fresh fluid pumping back in the return line. Then leveling off with the check plug.
    Sufficed to say, the flush seems to be an easier process than I initially thought though.
    ‘And it’s definitely a sales pitch.
