15k miles Transmission drain and fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, May 1, 2021.
  1. May 2, 2021 at 5:51 PM
    mb66l79
    mb66l79 New Member
    No it's a filter, not a screen. That seems to be a common misconception.
    This should be deleted so no one can read it and think there's any truth to it.
    farnsrocket, RJVA, Wallygator and 3 others like this.
  2. May 2, 2021 at 5:54 PM
    Vizsla
    Vizsla pretend2send
    Think calling that guy a “hack” is mostly not understanding what he is doing. Not flushing, changing from WS to Amsoil(or whatever floats your boat) without wasting expensive transmission fluid, while minimizing the amount of WS left in the system. He had fresh fluid flowing in, that’s the overfill.
    GAknight[QUOTED] likes this.
  3. May 2, 2021 at 11:25 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    2019 Tundra CrewMax Platinum
    Made me curious to see actually what is inside the plastic filter, found a video where a guy actually opens it up incase anyone is curious.
    https://youtu.be/Y2f7dFNP82k
  4. May 3, 2021 at 1:31 AM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    My truck had 158k on the original WS fill when I replaced all the fluid with Valvoline Maxxlife. Also put a Wix filter in. The original fluid was very, very dark brown. The pan had no large debris but the magnets were thoroughly covered in fine metallic dust. The transmission seemed to do well with new Maxxlife but had the occasional odd shift. I added 10oz of LubeGuard red. The transmission shifts great now. Zero strange shifts since adding the LubeGuard.
    Wallygator and 1rooster like this.
  5. May 3, 2021 at 4:37 AM
    timsp8
    NY
    Sometimes Toyota calls it a filter, sometimes they call it a strainer. Either way it’s not a part that’s in any maintenance replacement schedule that Toyota recommends.
    Tundrastruck91 likes this.
  6. May 3, 2021 at 6:21 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    You have no clue what your are talking about. You will wear your transmission clutches by changing the fluid to often.
  7. May 3, 2021 at 6:23 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Whats in the lubegaurd? Friction modifiers to help the clutches work? Why would you need that? Because you drained the friction material out when you changed your fluid.................
    Kywildman likes this.
  8. May 3, 2021 at 6:25 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This thread is sprouting legs.
  9. May 3, 2021 at 7:41 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yep...It's a veritable depository of vehemently-defended misinformation for anyone wishing to take some away for repetition to others.
    After draining the pan, he removes the transmission pan and changes the strainer. Everybody, especially Toyota, knows removing the transmission pan is a real bad idea. Then, he overfills the transmission by a full gallon, total volume of 8 quarts, until it runs out of the fill port, which is more than inch above the pan flange.
    He then disconnects a cooler line, starts the truck and pumps out fluid until it's a "nice cherry red". That says to me the fluid in the torque converter and valve body, roughly 2/3 the transmission volume, has been completely replaced with the two gallons he added. He then adds fluid (about a gallon?) and sets the level using a temperature gun on the pan, which will be cooler than the temperature at the transmission thermocouple.
    During this time, what happens to the pan level? What the hell does the achievement of a "nice cherry red" have to do with maintaining a fluid level in the pan? None, completely coincidental there's any fluid left in the pan. Elementary mathematics indicates he's run the level in the pan right down to breaking pump suction after having overfilled it by a gallon.
    I don't have a problem with the basic technique for complete fluid change, but it is lazy to expect to accomplish this in one step. Anyone that doesn't care about overfilling their transmission by a gallon, and then pumping the pan level right down to nothing, then this video should work for them.
    Another ATF video of his I watched was sales bs as well.
  10. May 3, 2021 at 8:15 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    hitech, Spvrtan, landphil and 5 others like this.
  11. May 3, 2021 at 9:04 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    So far, I'm the only one with a completely valid method for trangsmission maintenance: I'm gonna buy a new trangsmission every 60K miles.
  12. May 3, 2021 at 10:12 AM
    mb66l79
    mb66l79 New Member
    Ok yeah I was asking to be called out. I know enough to know that I don't know everything.
    So if I'm wrong, educate me. I always like learning. What is your basis or source of your claim, or your credentials for knowing this? If you're going to make that claim, back it up and support it, prove me wrong.
  13. May 3, 2021 at 10:19 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Source for your claims? Sounds like absolute bullshit, but I've been wrong before.
    RJVA, ColoradoTJ and Joe333x[OP] like this.
  14. May 3, 2021 at 10:26 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I’ve come up with a radical 2 step plan to address transmission concerns:
    Step 1. Follow the Toyota maintenance schedule.
    Step 2. Refuse to worry about it.
  15. May 3, 2021 at 10:27 AM
    Joe333x
    Joe333x [OP] Member
    Boston
  16. May 3, 2021 at 10:35 AM
    mb66l79
    mb66l79 New Member
    Could it be because the valvoline fluid used is not what is specified to be used? Don't you think the necessary modifiers are already in new fluid? Or clutch material if that's what would actually be needed?
    I say that in complete jest. Let's use this forum as it was intended, sharing of information and knowledge, not what this thread is quickly turning into. Don't be offended by us questioning and challenging what you said. Prove us wrong.
    RJVA and snivilous like this.
  17. May 3, 2021 at 10:40 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    No no no no no...
  18. May 3, 2021 at 10:43 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    As to the transmission filter/screen debate. This is what mine looked like after 175k miles on the original filter/screen. No need to change the filter, very very very minimal clutch material inside the filter, and if I had to guess, it was all from initial break in. 20191213_150527-1.jpg 20191213_150654-1.jpg 20191213_150658-1.jpg 20191213_150702-1.jpg 20191213_150706-1.jpg 20191213_150715-1.jpg
  19. May 3, 2021 at 10:53 AM
    #49
    Joe333x
    Joe333x [OP] Member
    Boston
    This is awesome thanks. From all the information I've gathered I'm never going to drop the pan.
  20. May 3, 2021 at 11:02 AM
    #50
    Sumo91
    TN
    Here is the thread I started when I first changed the trans fluid in my transmission
    https://www.tundras.com/threads/2014-transmission-maintenance-question.57617/
    Lots of good info and pictures from multiple members. I've had the Schaeffers 204SAT fluid in for 41k miles now with no issues (it has a slightly higher viscosity than what's called for, but works fine) I'll doing a complete drain and refill of 12+ quarts again this week with Schaeffers 205A (correct spec for our trans), and sending a sample to blackstone to see how the fluid looks after towing my 8k camper for several thousand miles and doing some heavy offloading.
    I agree never having to drop the pan to change the filter, unless it was super high mileage 500k+ just out of curiosity.
  21. May 3, 2021 at 11:19 AM
    #51
    Rocko9999
    Rocko9999 New Member
    Why are people debating this is not a filter?
  22. May 3, 2021 at 11:29 AM
    #52
    Professional Hand Model
    Hand Protectors
    We’ve seen 1st Gens Trangsmission Filters/Screems with 300-400k miles and they look like can go another 300-400k. Clean!
    Per Fluid: Best practice is just Drain and Fill at regular intervals like every 2nd or 3rd Engine Oil Change.
    You guys definitely need an External Trans Cooler, though. :boink:
    hitech, 300BLK, RJVA and 3 others like this.
  23. May 3, 2021 at 11:31 AM
    #53
    Joe333x
    Joe333x [OP] Member
    Boston
    I think the misconception was the material used for the filter. Many times it is described as a screen which it clearly is not but its also not a paper filter that could break down over time either. I guess i would call it a mesh screen maybe. They stopped using metal screens because they corrode overtime.
  24. May 3, 2021 at 11:43 AM
    #54
    JohnLakeman
    I like and trust that guy. He's a smart, experienced Toyota technician. He posted an earlier video that explained why you should NEVER get your transmission "flushed", but I couldn't find it on YouTube. It's possible he got some "flak" from businesses that want to continue selling "transmission flushes".
    That "flush" video posted earlier by @GAknight is not a "flush" of the transmission in the usual sense, even if the video title identifies it as a "flush". A typical transmission "flush" procedure uses a machine with it's own pump, that pumps ATF (possibly contaminated or the incorrect type) from an onboard reservoir, through the transmission under higher pressure than normal operating. That's how those "deposits" inside the transmission get disturbed, and pushed into places they shouldn't be.
    What is occurring in that video is simply a complete replacement of the transmission fluid by starting the vehicle and allowing the transmission pump to empty all the old fluid out of the transmission through a disconnected cooler tube, while maintaining the pan fluid level by adding fresh fluid. The transmission does not even know it's fluid is being changed. I endorse the method, but not the poor execution in the video.
    Since you don't have a cooler, it's pretty much a moot point for you. Couldn't do this procedure if you wanted to.
    C.I., GAknight and Rocko9999 like this.
  25. May 3, 2021 at 12:12 PM
    #55
    JohnLakeman
    Basically, it's because the first person that ever referred to a transmission strainer as a "filter" was, well...under-informed and confused.
    Filters work by the flow being pushed by pressure through a fine media which incurs a pressure drop. The more pressure drop, the better the filtration, until of course the filter is plugged. Because of the pressure drop, you can not have a filter on the pick-up tube to a pump. It's true on engine oil pump pick-up tubes, and it's true on transmission pump pick-up tubes.
    The Tundra transmission strainer, in fact, has the pick-up tube built right into to it...it's sucking fluid nearly right off the pan bottom. If there's a 10 psi pressure drop across that strainer media...no more pump suction.
    This from the referenced filter/strainer supplier website linked below:
    http://www.gulfcoastfilter.net/strainers/difference-between-filters-strainers/#:~:text=The primary difference between filters,the particulates they are removing.&text=In simpler terms the word,term “filter” is used.
    15whtrd and Joe333x[OP] like this.
  26. May 3, 2021 at 12:42 PM
    #56
    mb66l79
    mb66l79 New Member
    Good info, I guess the question then becomes the size of the transmission filter/strainer, not that it really matters, we're arguing something unimportant. I was incorrectly using the differentiation based on media type. The term strainer I correlate to a "coarse" media that is cleaned instead of replaced. I was wrong.
    Though now that we're getting into the details, more pressure drop does not always equal better filtration. Filters can be and are in some cases also on suction sides of pumps, so that by itself also does not determine filter vs strainer.
  27. May 3, 2021 at 12:47 PM
    #57
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    I would urge you to use the search function to find answers to your questions about LubeGuard. Have a fantastic day!
  28. May 3, 2021 at 12:51 PM
    #58
    15whtrd
    15whtrd Mr. Blonde
    Slippery Pete
    Rocko9999 likes this.
  29. May 3, 2021 at 1:08 PM
    #59
    JohnLakeman
    Pressure drop across filters is NOT the desired outcome. The objective is to remove micron-sized contaminant particles from the fluid with as little pressure drop as possible. Filter media with very small internal passages does that, but at a pressure and energy price. The smaller the passages, the higher the pressure drop. If you're thinking of the K&N et al oiled-gauze filters, don't even get me started...A fool and his money are soon parted.
    Some pumps, e.g. positive displacement pumps, are more forgiving of suction pressure drop than others, such as centrifugal pumps. Automotive engine oil pumps and transmission pumps are both positive displacement pumps, and strainers are still used.
    No pump can handle a stopped-up suction, which is the likely result if an inaccessible "filter" works too well. If the pump can continue to pump, without shearing the drive or overpowering the driver, the extreme case is the pick-up tube would simply collapse on itself.
    Name an example of a pump with a filter on it's intake pipe (positive displacement vacuum pump?), and I'll admit it if you're right.
    Sumo91 likes this.
  30. May 3, 2021 at 1:15 PM
    #60
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Yes yes yes yes yes
    Mocking is mandatory in these situations.
    Vizsla and hagrid[QUOTED] like this.
