12volts Plug & Play remote start groupbuy!
Discussion in 'Audio & Video' started by T-Rex266, Jul 31, 2019.
  1. Aug 20, 2019 at 12:25 PM
    #301
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    Just got my instructions emailed an shipping notification. I ordered 8/7. Probably won't put this in until my B2 Audio stuff gets here. That's gonna be a busy day. Thanks James.
    TheBeast likes this.
  2. Aug 20, 2019 at 6:35 PM
    #302
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    Lucky man. I ordered 8/2 and still no confirmation. He said it should ship Monday but never got notification.
  3. Aug 20, 2019 at 7:43 PM
    #303
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    Same. I think there's something wrong with the 18,19 kit?
  4. Aug 20, 2019 at 7:52 PM
    #304
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    I think so too.I got my kit for 18 a week ago installed same day followed instructions and youtube video tutorial .100% sure everything was installed correct and truck doesnt re-lock after remote starting.He wants me to open everything up again and send him a pic of how i tapped the tpms wire.! Clearly this is something with the module
    YsoSeRiouS! likes this.
  5. Aug 20, 2019 at 7:54 PM
    #305
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Yup, which is what is probably setting off the alarm like people were mentioning earlier, just a guess on my behalf
  6. Aug 20, 2019 at 7:56 PM
    #306
    YsoSeRiouS!
    NorCaL
    did you cut it and connect each wire to each end or did you tap into it?
  7. Aug 20, 2019 at 8:16 PM
    #307
    viha22
    viha22 MAGA
    WA
    I did exactly as this guy in the video
    https://youtu.be/0VcbQdS0oX8
  8. Aug 21, 2019 at 4:48 AM
    #308
    ToyotaTundraMike
    2015 Tundra
    Instructions he sent are a little confusing.
    You are supposed to disconnect battery before install? At what point do you reconnect and program the module?
    “make sure all connections are made with battery disconnected and before you hook the battery back up remove all connectors from the remote start unit“
    If you remove the connectors to the module before you reconnect the battery then how does the thing still work lol....
  9. Aug 21, 2019 at 4:55 AM
    #309
    CyberViking
    The Ozarks
    I think it means to connect the module after you reconnect the battery? For people that have to splice? Instructions could be better.
  10. Aug 21, 2019 at 5:33 AM
    #310
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    I didn’t unhook my battery, I followed the same video as above. My driver door doesn’t lock either he said it might be in the software of the module. I believe he said he had to check hundreds or even thousands of them before he sends them out. For now I just hit the lock button again after it starts. Minor details.
  11. Aug 21, 2019 at 6:33 AM
    #311
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Sweet...woke up to shipping email :)
    YsoSeRiouS! and InfernoToyo like this.
  12. Aug 21, 2019 at 6:36 AM
    #312
    InfernoToyo
    InfernoToyo New Member
    Barty
    Inland Empire
    2018 Inferno Limited
    Me too
  13. Aug 21, 2019 at 6:54 AM
    #313
    AZTundra
    Paul
    Phoenix, AZ
    Seems like the 18's and 19's are starting to roll out. :thumbsup:
  14. Aug 21, 2019 at 7:12 AM
    #314
    YsoSeRiouS!
    NorCaL
    For 18-19 just missing the t-harness?so if I got that I’m assuming no need to cut wire? Fortin-thar-toy10 is 80 bucks figure if that’s it then I will just get the harness
  15. Aug 21, 2019 at 7:13 AM
    #315
    YsoSeRiouS!
    NorCaL
    I’m curious too because I’ll just look to purchase that harness
  16. Aug 21, 2019 at 7:33 AM
    #316
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I can't tell if this is the harness you'd need... The newer version of the kit from 12volt.solutions (not James' kit) comes with an additional t-harness for the TPMS splice, but it's seriously just one wire and not really worth the money to buy that separately IMO. I bought my 12volt.solutions kit secondhand and needed to splice but it was no big deal at all. I can try to find their video that was posted for the older version that requires the TPMS splice.
    AZTundra likes this.
  17. Aug 21, 2019 at 7:35 AM
    #317
    YsoSeRiouS!
    NorCaL
    eBay? Me too lmao!
  18. Aug 21, 2019 at 7:46 AM
    #318
    YsoSeRiouS!
    NorCaL
    Looking at the Fortin instruction it says we need to cut the Tpms so if the manufacturer says it than I think the t harness won’t make a difference. I got my shipping Info this this morning so I’m super stoked
  19. Aug 21, 2019 at 10:59 AM
    #319
    AZTundra
    Paul
    Phoenix, AZ
    Don't waste the money on the harness just to avoid one wire splice. Just grab a T-Tap and you're good to go. You can get them from any autoparts store.
  20. Aug 21, 2019 at 11:04 AM
    #320
    YsoSeRiouS!
    NorCaL
    Doesn’t it have to be cut so each end gets a wire connected if I splice two wires to the tpms wire, won’t it screw it up. Remember our vehicles are different years so we have different instructions I think
  21. Aug 21, 2019 at 11:14 AM
    #321
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah you can't just tap the TPMS wire - it has an input and output that correspond to wires in the module harness. I'm still trying to find the video I used.
    YsoSeRiouS![QUOTED] likes this.
  22. Aug 21, 2019 at 11:17 AM
    #322
    YsoSeRiouS!
    NorCaL
    Thank you sir for the confirmation
  23. Aug 21, 2019 at 11:26 AM
    #323
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  24. Aug 21, 2019 at 11:43 AM
    #324
    YsoSeRiouS!
    NorCaL
    Just curious should I disconnect battery during install
  25. Aug 21, 2019 at 11:45 AM
    #325
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It's probably a good idea to do so, but I didn't (and rarely do with any electrical work...) during my install. I like to live dangerously and/or am an idiot, so there's that.
  26. Aug 21, 2019 at 11:50 AM
    #326
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    WTF does TPMS have to do with starting the vehicle is my question.
  27. Aug 21, 2019 at 11:59 AM
    #327
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I can't find much for answers on this except a post on a Fortin forum:
    If the wire is not interrupted, the factory remote can not be detected when the engine is running.
    I don't really know what/why/who/how, but it's just a necessary step in the remote start procedure.
  28. Aug 21, 2019 at 12:18 PM
    #328
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Just to confirm as I am going to be doing this install in the coming days on my 2017... Trucks with OEM alarm only need the key sense wire connected if they also have the glass break sensor.
    I just used threads https://www.tundras.com/threads/glass-breakage-sensor-install-and-setup.19870/page-2 and https://www.tundras.com/threads/factory-alarm.22338/ to confirm that I have the OEM alarm without the glass break sensor and the OEM alarm on my truck is activated.
  29. Aug 21, 2019 at 5:33 PM
    #329
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I can only comment on with glass break sensor since that's what my truck has. Try it without and see if you alarm goes off after it times out for 15mins or you turn the truck off by clicking the remote button 3 times.
    Pbear1454 likes this.
  30. Aug 21, 2019 at 11:05 PM
    #330
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Thanks as I didn't know there's an off switch
