08 tundra 5.7 left me stranded again
Discussion in '2nd Gen Tundras (2007-2013)' started by Bber08527116, Jun 18, 2022.
  1. Jun 21, 2022 at 7:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m thinking that just might do it.:thumbsup:
    The immobilizer light in the center display of the dash (outline of a car with an outline of a key in the middle) should flash if there is a transponder key issue. But I doubt that info is really relevant anymore.
    WVI and Jeff_5_7 like this.
  2. Jun 22, 2022 at 10:01 AM
    Dr_Al
    Dr_Al New Member
    Al
    On my first gen Tundra the wipers came on one day and wouldn't shut off. I pulled the fuse until i could look into it. What it turned out to be was the washer pump. The cable going to it had a small rock get stuck on top of it where it ran across the frame. Over the years (my guess) it damaged one of the wires going to the pump and it actually was shorting to ground just enough so the computer thought I was trying to wash the windshield. But it wasn't a good enough of a short to make the washer pump actually work.
    I found it by reading through the wiring schematics. The way it worked (at least in 2000) was power would go to the pump and the wash lever in the truck would ground the washer motor. The computer monitors the power going to the washer motor (I'm guessing that it measures the current) and when it sees it get above a set level it then turns on the wipers. My point is until I found this out I would have assumed that a bad wire going to the washer motor would only result in the washer motor not working. With modern vehicles they are much more complex. That damaged wire could cause other issues that you wouldn't think were connected.
    As for the fuel pump shutting off I would have expected a miss fire to cause an ECU code.
    WVI likes this.
  3. Jun 22, 2022 at 12:29 PM
    Bber08527116
    Bber08527116 [OP] New Member
    08 tundra
    Problem found fixed
    NewImprovedRon, landphil, WVI and 2 others like this.
  4. Jun 27, 2022 at 2:11 PM
    Bber08527116
    08 tundra
    Thanks everyone for helping me with this issue.
  5. Jul 1, 2022 at 10:40 AM
    Bber08527116
    08 tundra
    So I'm back again Toyota fixed the fuel pump ecu broken wire and the other day I went to start had the same symptoms started up fine then died immediately got it to start again drove a few minutes and had to turn around had a strange hitch like before not transmission hitch but it was like engine was cutting out . Toyota charged me 500 buck to fix that plug and broke. Wires they said 100 percent that was the issue but having same symptoms as I always had
  6. Jul 1, 2022 at 10:50 AM
    Bber08527116
    08 tundra
    I was reading maybe could be the main fuse wires under the fuse box that are connected could be broken or worn is why I get no codes ?
  7. Jul 1, 2022 at 10:52 AM
    JRS
    JRS New Member
    2012 DCLB
    Others said it, but have you REALLY checked the ground cable at the battery? Salt water is going to create internal corrosion. Look behind the lug and underneath the jacket, especially if it's cracked at all. I've had intermittent issues with a different vehicle before due to a corroding ground cable, and on my tractor. Increased air water concentration would exacerbate this.
    Also, has the battery been tested with an actual state of health meter? Hooking up a multimeter and reading 14.x volts isn't enough to say the battery is fine.
  8. Jul 1, 2022 at 11:02 AM
    Bber08527116
    08 tundra
    Yes battery has been tested where will I find this ground wire ?
  9. Jul 1, 2022 at 11:05 AM
    JRS
    JRS New Member
    2012 DCLB
    I'm talking about the main ground cable at the battery lug and any going to the fuse box or surrounding chassis straps.
  10. Jul 1, 2022 at 11:11 AM
    Bber08527116
    08 tundra
    How many ground straps should I be looking for ? I haven't checked the one that goes to the block I have been parking it at the ocean pier for 6 years and I live on a lake so I'm hoping that's it's
  11. Jul 1, 2022 at 11:18 AM
    JRS
    JRS New Member
    2012 DCLB
    Don't actually know on the Tundra. Haven't had any electrical issues from mine. Just trying to help based on prior experiences with other vehicles.
    Edit: if you find you need new cables, see this post I made about crimpers and lugs. These are standard order for marine-grade applications: In need of advice for electrical box
  12. Jul 2, 2022 at 12:05 PM
    Bber08527116
    08 tundra
    Ok now truck ran fine yesterday took it today now I'm getting all three throttle position sensor codes had never gave codes before
  13. Jul 2, 2022 at 12:58 PM
    Dr_Al
    Dr_Al New Member
    Al
    I think you have damage to a wiring harness, possibly a mouse. As much as it will suck I think you're going to have to check every harness for damage. That includes checking the connectors just in case one isn't sealing water out.
  14. Jul 2, 2022 at 1:32 PM
    Bber08527116
    08 tundra
    Ok thanks for the help that's what I'm thinking noticed at the firewall where the harness hooks in after it's clamped down that it seems there's a lot of play
  15. Jul 4, 2022 at 1:46 PM
    Bber08527116
    08 tundra
    Now truck went into limp mode said I had 3 codes for throttle body sensor now truck will start but will not rev up. Found that my positive battery terminal was kinda loose after it died on me again then those codes popped up. I r fixed all these other issues and it fixed it for a while my grounds are good at the block and under the air box as well. Checked wires under there fuse box everything looked good I never had codes before I'm wondering if the main engine harness is bad but I don't see anything wrong with it when I looked it over or could it have been throttle body the whole time and it wasn't getting a good battery connection to send the right code to the ecm ?
