In need of advice for electrical box
Discussion in 'Electrical' started by Voss, May 26, 2022.
  1. May 26, 2022 at 8:45 AM
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Morn’n all. I need to clean up the electrical on the truck and I want to connect my Frig, ham radio and other things in the future most likely.
    I won’t be running a 2 battery system. Got myself one of these…
    I’ve seen people use the switch pro to set up their electrical but I don’t want to use the electrical switch board it comes with. I like my switch set up now and have an idea of where additional switches will go for future additions. I only need the box where all the different things connect with the breakers but not sure what to get.
    Any suggestions on what box to use to protect the things I’ll be connecting to the battery? I basically don’t know anything about electrical, breakers, how to protect etc.
    Appreciate it!
  2. May 26, 2022 at 8:50 AM
    I don't normally reco anyone to another forum, but this is one of those cases where asking a Mod to move your thread over to the Electrical forum may expose you to a more targeted audience and get a wider variety of viewpoints: https://www.tundras.com/forums/electrical.130/
    I think you can click 'Report' to flag a your post for moderation, or just @ tag a moderator like Colorado TJ, K9, or T-Rex mods, those are just the ones I remember (I think there's a mod w/K9 in their name at least)
    Voss[OP] likes this.
  3. May 26, 2022 at 8:53 AM
    Voss
    2003 AC TRD 4x4
    Thanks
  4. May 26, 2022 at 8:54 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Easy access disconnect. With a key or a lever like a drag car.
    lots of gromets.
  5. May 26, 2022 at 9:42 AM
    JRS
    JRS New Member
    2012 DCLB
    Your question is vague so I'm just giving a general answer modeled after what I did for my boat. You'd use a DC fuse block (Blue Seas makes nice equipment) to handle independent loads in conjunction with a relay box for the switches. Put a DC breaker in front of the fuse block (don't get Amazon Chinesium on this part because they suck - get a name brand from McMaster like Bussmann) and size the wire and breaker accordingly. For such short runs, and to better protect against corrosion, I'd recommend getting tinned copper instead of welding wire. There are plenty of charts to figure out gauge for draw vs length.
    Also, the lugs and crimpers on Amazon are shit. They're made to metric standards and make a terrible crimp on AWG wire. They'll probably work if you're wanting to do this on the cheap (be sure to use marine grade heat shrink to attempt to salvage the terminals), but the FTZ 94284 crimper and their associated lugs are where it's at.
  6. May 26, 2022 at 9:48 AM
    Voss
    2003 AC TRD 4x4
    Not sure what that means bud lol
  7. May 26, 2022 at 9:48 AM
    Voss
    2003 AC TRD 4x4
    Thanks. I’ll look into all that.
  8. May 26, 2022 at 9:56 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    E2EB4862-83A3-4601-841F-FC5E1EB80FF1.jpg Something that closes the electrons quick and easy.
  9. May 26, 2022 at 10:04 AM
    Voss
    2003 AC TRD 4x4
    Thanks. Why would this be needed? In case of an electric short or fire or something along those lines?…
    Sirfive[QUOTED] likes this.
  10. May 26, 2022 at 10:08 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Exactly. Or a bad accident or a runaway winch since most don’t use fuses (more common than you think)
    Voss[QUOTED][OP] likes this.
