06 DC Daily Driver / 2wd to 4wd Conversion
Discussion in '1st Gen Builds (2000-2006)' started by MrDirtjumper, Jun 26, 2019.
  1. Jul 30, 2025 at 11:09 AM
    #91
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    The A340E/F is the same transmission in our trucks. The only exterior difference is the bellhousing (VZ vs UZ) and the tailshaft housing (E for 2wd and F for 4wd). You'll need the "F" tailshaft housing from a donor trans. If you do replace the trans, don't just go out and stab any old Tundra trans into it. They are not all the same. See this thread for more trans info A340E/F INFO DUMP | Toyota Tundra Forum
  2. Jul 30, 2025 at 9:12 PM
    #92
    757TundraAC
    757TundraAC New Member
    Cody
    2002 Tundra AC 2wd
    6 inch rcd lift 35 inch nitto tires 17 inch Mickey Thompson rims
    Tbh, it confused me. So what vehicles would I find for the transmission to properly do the swap going from v6 2wd to v6 4wd? Or would it only be the 2000-2004 v6 4wd tundras?
  3. Jul 30, 2025 at 9:32 PM
    #93
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    this link needs to be a sticky.
  4. Jul 30, 2025 at 10:31 PM
    #94
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I can’t say if the v8 tranny would bolt up to the v6 engine block or not, but the other hang up might be that you’d probably also want to get an engine wire harness from out of a 4wd 2002 v6.
  5. Jul 30, 2025 at 10:33 PM
    #95
    757TundraAC
    Cody
    2002 Tundra AC 2wd
    So my donor truck should be a 2000-2004 v6 4wd tundra to have the most compatibility?
  6. Jul 31, 2025 at 3:35 AM
    #96
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Is there anything wrong with you current transmission? If not, you only need to swap over the tail shaft housing and transmission crossmember from the 4wd donor... along with all of the other components to make it 4wd. Read the A340 transmission thread that I linked earlier. The internals are all the same, but there are different pans, filters, sensors, switches and valve bodies along with the 2 different bell housings and tail shaft housings. If you need to replace the trans, you'll more than likely be swapping over these components. You should read @whodatschrome 's build thread, Taco Tuesday Tundra. He also did a 4wd conversion and did a fantastic job of documenting the entire process (pic heavy:D).
    whodatschrome likes this.
  7. Jul 31, 2025 at 3:47 AM
    #97
    757TundraAC
    Cody
    2002 Tundra AC 2wd
    No, transmission is perfectly fine, just want 4wd.
  8. Jul 31, 2025 at 1:26 PM
    #98
    whodatschrome
    lots of dents
    The early 2000-2002 v8 trucks had an actual throttle cable, while the 2003 and newer had a fly by wire setup. That also meant that the engine harnesses were different for those years. I have no idea what throttle cable configuration differences the V6 trucks have between 2000 and 2004. Of course you’d want to match up the correct 4wd v6 harness to the matching throttle body.
    Gotta ask, what makes your current v6 tundra so sentimental to you?
