0 offset with 3 in lift
Discussion in 'Wheels & Tires' started by Dustydirt19, Feb 27, 2017.
  1. Dec 17, 2021 at 5:06 PM
    #61
    BettyWhite20
    BettyWhite20 New Member
    2020 DC SR5 4X4
    Did you ever get an answer for this? I'm looking to run a 275/60R20 (32.99×10.8) on a Bilstein 6112 front at 3rd setting = 1.9" on a 20x9 0mm and I can't find anyone running that offset, tire size, and level/lift....
  2. Dec 21, 2021 at 10:16 AM
    #62
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    This tire size fits with no lift on stock 20" wheels.
    0 offset is really way too aggressive for Tundras according to most of the posts on the web.
    The sweet spot is usually+20 to +30 offset wheels.
    I doubt this will work without major trimming/CMC.
    BettyWhite20[QUOTED] likes this.
  3. Dec 21, 2021 at 10:19 AM
    #63
    How is 0 offset aggressive for a Tundra?
    BettyWhite20 likes this.
  4. Dec 21, 2021 at 10:23 AM
    #64
    Kanobi13
    Kanobi13 New Member
    It just is according to the internet..
    wexttxco likes this.
  5. Dec 21, 2021 at 10:25 AM
    #65
    BettyWhite20
    2020 DC SR5 4X4
    Thanks for the reply! I never did find a wheel I thought I'd be happy with that wasn't +1 or 0 or a negative offset. In my personal opinion, other colors like MGM for example are a lot more forgiving than Super White and I probably would have went with an 18" wheel with a +20 and been perfectly fine with it. I guess I'm not understanding how 0 can be way too aggressive.... its only 0.787" more than a +20. And my thinking was that a 0 offset would give me more inner clearance than a +20.
  6. Dec 21, 2021 at 10:27 AM
    #66
    BettyWhite20
    2020 DC SR5 4X4
    Stock wheels are +60 so 0 is pretty aggressive. (60mm ÷ 25.4 = 2.36") With that being said, I didn't think it would be too aggressive.....
  7. Dec 21, 2021 at 10:49 AM
    #67
    I run 18's on a 0 offset and my tires are flush with my Bushwacker flares.
  8. Dec 21, 2021 at 10:55 AM
    #68
    BettyWhite20
    2020 DC SR5 4X4
    What size tires on that 18 with 0mm and what level/lift?
  9. Dec 21, 2021 at 11:05 AM
    #69
    285/70 (34's) and 3 front, 2 rear
  10. Dec 21, 2021 at 12:10 PM
    #70
    BettyWhite20
    2020 DC SR5 4X4
  11. Dec 21, 2021 at 6:03 PM
    #71
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    0 offset is very aggressive. But you can make it work with smaller tires. Personally, I like a higher offset with the largest tires possible. It’s not so much that it only sticks out .787” further than the +20’s. It’s because the turning arc of the wheel gets larger. Not a whole lot, but just enough to cause rubbing. Kinda like comparing the arc of the middle of your windshield wiper to the end of the wiper. The arc at the end of the wiper is way bigger. A little exaggerated but that’s essentially what is happening.
  12. Dec 21, 2021 at 6:07 PM
    #72
    BettyWhite20
    2020 DC SR5 4X4
    I'm thinking about order the Coachbu
    I wonder if the 1/2" front bumper shims will help?
    joonbug[QUOTED] likes this.
  13. Dec 21, 2021 at 6:11 PM
    #73
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, those help quite a bit. But only on the front. You’ll still have to address the rubbing on the cab mount.
  14. Dec 21, 2021 at 6:14 PM
    #74
    BettyWhite20
    2020 DC SR5 4X4
    With a 33"? I was hoping that these guys running a 275/60R20 on a 20x9 +1mm with minor rubbing, that a 20x9 0mm would be fine too? I only see CMC with 35's.
  15. Dec 21, 2021 at 6:17 PM
    #75
    BettyWhite20
    2020 DC SR5 4X4
    I mean, I can call or email Shock Surplus and see about having my front struts set at 2.5" instead of 1.9" and add Shackles in the rear if that will clear?
    I'm already going about $1k over what I originally planned on spending anyways. ‍♂️‍♂️‍♂️
  16. Dec 21, 2021 at 8:18 PM
    #76
    cjscinta
    cjscinta New Member
    Nashville TN
    Trd pro with coachbuilder kit.
    Nitto Ridge Grapplers 295 70 r18
    Fuel Vapor 18x9 with 0 offset
    Barricade High clearance front bumperDB72D49A-01E3-4DB2-BBA6-7DAA0B33B2AF.jpg
    No BMC, front mud flaps removed, no rubbing.
    A little aggressive but not too aggressive IMO. If I decide I don’t like it, I will add the flares.
  17. Dec 22, 2021 at 4:23 PM
    #77
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Any chance you could give us a shot down the side of the truck to see how far the wheels stick out? I was thinking of going black rhino rapid's which are a 10 mm offset.
  18. Dec 22, 2021 at 4:49 PM
    #78
    cjscinta
    cjscinta New Member
    Nashville TN
    Absolutely though it’s kind of hard to tell from the pic I’m right on the edge of what I’m comfortable with but I decided I’m ok with it. If I decide otherwise I can always soften it with some OEM flares. BADA3DB8-41CA-4C99-9AFD-A11AAA7282B7.jpg
  19. Dec 22, 2021 at 4:51 PM
    #79
    cjscinta
    cjscinta New Member
    Nashville TN
    I can’t seem to do more than one at a time for some reason. DE074836-1906-430C-8C77-85A9597A8CCB.jpg
    WinterWarlock21 likes this.
  20. Dec 22, 2021 at 5:16 PM
    #80
    Seafury
    Agent K
    SC Low Country
    Sorry guys, I wasn't trying to start a flame war.
    I used a bit too much hyperbole.
    It is not too aggressive.
    But by aggressive, I just meant it requires a good amount of effort/modification to use compared to the sweet spot of +20-30.
    It also pushes the wheels out more risking paint damage requiring more mods to protect that.
    At the end of the day, having all the mods to run 0 and even negative offset the right way looks awesome, and I sometimes wish I could go that far to.
  21. Dec 22, 2021 at 5:38 PM
    #81
    cjscinta
    cjscinta New Member
    Nashville TN
    haha. I thought just the opposite. I like what you are putting out.
  22. Dec 22, 2021 at 6:12 PM
    #82
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    I’ve got 6112’s at 1.9” in front. 20x9 with a believe +1 offset and have falken 275/60r20
  23. Dec 22, 2021 at 7:39 PM
    #83
    thedonn
    thedonn New Member
    i am thinking that the 33s will wipe out the lack of offset (vs a +20 or +25). so you should be okay with just plastic modifications. if you need more definitely get the coachbuilder bumper shims. i would not think going higher on the lift would help - thats not where they will rub.
  24. Jan 16, 2022 at 10:02 AM
    #84
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have 1.75" lift front/ stock height rear. MR 701s 295/70/17 with 0 offset and Mickey ATZs (33.2 x 12). Trimmed and pushed wheel well liner- slight rub on flaps but all good.
  25. Jan 16, 2022 at 10:04 AM
    #85
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Not sure what happed with all those pics- apologies.
  26. Jan 25, 2022 at 8:57 AM
    #86
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    3/1 lift
    295/60r20 (33.9" X 11.8") Toyo ATlll's
    20x9 0 offset Gloss Black XD 820 Grenade wheels
    Tundra234 likes this.
  27. Jan 28, 2022 at 6:17 AM
    #87
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I’m at a measured 3 1/4” and 0 offset Methods.
    726A3356-D939-4EC2-A76B-AC48005762B4.jpg 977C6839-6584-4E71-A27B-AD0A38497142.jpg
    Skew12, BettyWhite20 and Tundra805 like this.
  28. Jan 28, 2022 at 6:43 AM
    #88
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    I think we as a forum should tell everyone "Look, if you have a purposeful build where you have reasons behind your offset, go for it, if you are on a forum asking about offset, buy +25 and call it a day". Like, recommend +25 to everyone.
    COTundra23 and Skew12 like this.
  29. Jan 28, 2022 at 6:45 AM
    #89
    GT87
    GT87 New Member
    Greg
    Western NY
    ZERO OFFSET OR NOTHING!!! :headbang:
    JK you're probably right lol
    Ace96 and BettyWhite20 like this.
  30. Jan 28, 2022 at 7:39 AM
    #90
    sea_weathered
    Pacific Ocean
    You are probably right, the mods required to run 0 offset and larger tires are outside the ability of most.
