“How-to” Video for Installing the FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Oct 26, 2017.
  1. Oct 27, 2017 at 6:10 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Thank you
    blue16[QUOTED] likes this.
  2. Oct 27, 2017 at 6:56 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    Great video , I love my FRAC and had that video been out I might have done it myself ! I have FRAC 1.0 and had to replace the camera and it was so easy to pop in and change out at the keyed connection point in the engine bay .
    TundraTex[OP] and 4x4_Angel like this.
  3. Oct 31, 2017 at 1:17 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Great job @TundraTex and @4x4_Angel!!!
    I still have yet to install mine...I've got a TRD Pro Grille on the way. So hopefully I'll have this done in a week or so. The vid is/will be a huge help!
    Thanks again!!!
  4. Oct 31, 2017 at 5:19 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Welcome!
  5. Oct 31, 2017 at 6:20 AM
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Glad to hear it! Make sure to post up some pics of your install.
    4x4_Angel likes this.
  6. Nov 4, 2017 at 3:22 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I installed mine today. Some minor cussing involved...only because of the cheap feel of the interior and taking 3 tries to pull the cable into the cabin. No broken clips tho and it works great! If i had to do it again it would be a breeze.
  7. Nov 5, 2017 at 7:56 AM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I got the harness and switches wired up last week so this weekend I’m trying to run the video cable through the firewall and install the front camera.
    What’s the proper way to remove the passenger kick panel to be able to get to the rubber nipple?
  8. Nov 5, 2017 at 9:10 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Pull off the sill cover. It's just held in with clips. Then there is one nylon screw and two clips holding the kick panel in. Remove the screw and pull the kick panel out and to the rear. The bulkhead grommet harness will then be visible up under the dash. You should be able to see the lower nipple hole. The carpet is slotted around the harness.
    silverhack and 4x4_Angel like this.
  9. Nov 12, 2018 at 6:50 PM
    wilsonos2
    wilsonos2 New Member
    Don
    2018 Tundra Sport
    3” lift, 33” tires
    Installed my FRAC this weekend and it works great. Thanks for the great product.
  10. Nov 13, 2018 at 3:11 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice job! The camera installation is very clean.
  11. Jan 29, 2019 at 4:21 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Great video! I have the camera installed; the cable run; and I started disassembly of the interior. I got the shift cover off and the rest of the lower ray too. When I pulled out the A/C control panel, besides the lower plugs across the bottom, there is a plug halfway up the back for the controls. Does it twist or squeeze or just pull out? I cant get it to budge yet.
    2018 CrewMax SR5
  12. Jan 29, 2019 at 4:24 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I got it. By studying the picture, it’s obvious you just push down on the tab. I didn’t notice that until I sent previous reply.
  13. Jan 29, 2019 at 6:02 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I finished, but I have problems. The rear camera works but not the front. And it doesn’t make any difference whether the on/off switch is on or not (the green wires). Flip switch to double bars and rear camera shows, regardless of on/off switch position.
    Switch switch to single bar and the screen goes black, regardless of on/off.
    Any ideas before I start all over?
  14. Jan 29, 2019 at 10:30 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    If the screen is going black when you switch to the front camera, that means the FRAC circuit is working correctly and switching to the front cam video feed, but there is no video there to display. I would double check your front camera power, ground, and video output. Make sure the front cam video RCA plug is properly plugged in to the FRAC Harness circuit board. If none of this fixes the problem, you may have a bad camera. But that is extremely rare in my experience.
    The on/off switch on the green wires is for the VIM Enable function only and has no effect on video.
    Let me know how it works out.
  15. Jan 30, 2019 at 9:37 AM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Thanks, I’ll check it out tonight hopefully.
  16. Feb 1, 2019 at 1:05 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    I have power at the cable out through the firewall to the connector that the camera plugs into. So I’m guessing the camera is bad. I ordered another one.
  17. Feb 2, 2019 at 8:40 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Good deal. I helped a friend of mine with his install last year and he had the same problem. In that case it turned out that the culprit was the intermediate splitter cable that goes between the camera 4-pin mini connector and the video/power line going into the truck. Power was there, but the video lines were bad. So your camera may be ok. Good news is the cams are pretty cheap and you get all the parts to work with when you order a new one.
    Please let me know how this turns out.
  18. Feb 2, 2019 at 9:30 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    So when the camera arrives, I should first try interchanging that section of wiring before undoing the camera install? That would be nice, as I scratched the heck out of my wrists doing the camera install. LOL
    It should arrive Mon or Tue.
  19. Feb 3, 2019 at 11:37 AM
    #49
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes, I would try that first.
  20. Feb 5, 2019 at 11:28 AM
    #50
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    My replacement camera arrived today, but yesterday I was taking some guys to lunch and when I switched the button to front camera to show them what was suppose to happen, it worked! Previously I had the key turned on but the engine was not running. Would that be the difference?
    Anyway I will try the replacement camera, because it’s advertised as a front camera, and the camera I have up there now it showing a reversed image. When I pass somebody and they are on my right, they show as being on my left on the screen.
  21. Feb 5, 2019 at 11:29 AM
    #51
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    For those of you who are hesitant to do the install, it took me 6 months to finally get to it, and it wasn’t bad at all. I would have done the install 6 months ago if I knew it was going to be that easy.
    TundraTex[OP] likes this.
  22. Feb 5, 2019 at 3:14 PM
    #52
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The key needs to be in the "On" position; doesn't matter if the engine is running or not. The FRAC Circuit works off of "ignition" power.
  23. Feb 23, 2021 at 3:27 PM
    #53
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    What make/model is the camera, and will it fit in the Toyota logo of an older Tundra (I have the '10 Platinum grille in my '08 Limited)? Thanks!
  24. Mar 18, 2022 at 2:41 AM
    #54
    James07
    James07 New Member
    James
    Maryland
    2017 CM Platinum in Super White
    Ready Lift 3/2 General Grabbers ATX 35x12.5x17 Icon Alloys Rebounds 17 Window Tint Line-X Bed 32" Rigid Light bar in Bumper Stubby Antenna VLED under dash lights A-Pillar Grab handle Blacked out exhaust tip Shovel/Axe bed mounts
    @TundraTex for the FRAC do you need both rocker switches or can be be done on a 2017 Tundra with only one switch? Any ideas on mounting for a front camera on a 2017 TRD Pro Grille? Great video!!
  25. Mar 18, 2022 at 5:56 AM
    #55
  26. Mar 18, 2022 at 7:28 AM
    #56
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @James07, There are two main functions provided by the FRAC Harness; Front/Rear Anytime Camera display and VIM control. Only one switch is required for each function, so if you only want the camera function, you only need to install the camera select switch. As @Jim LE 1301 stated, there is a lot of additional information in the main FRAC thread including camera installation, switch locations, etc. Check that out and let me know if you have additional questions. I'll be happy to help!
    Jim LE 1301 likes this.
