38 Gallon Gas Tank Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by matttowns509, Dec 27, 2018.
  1. Jan 1, 2019 at 1:02 PM
    #61
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    $108 in Portland, OR area at a cheaper pump.
    With the Kroger points program though, I get as much as a dollar off per gallon- no limit on a fill up.
    I tell my wife not to use it up in her Honda so I can fill the beast for about $50.
    15whtrd and OR18TRD like this.
  2. Jan 2, 2019 at 3:37 AM
    #62
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    Yes, the gauge and the remaining amount of gas is off and slightly frustrating.
  3. Jan 2, 2019 at 4:22 AM
    #63
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    San Antonio, TX that would have cost only $65 to fill up at $1.74 here at the quick trip.
  4. Jan 2, 2019 at 7:38 AM
    #64
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Careful! Or y’all will “run out of gas” lol
    TundraTSS19[QUOTED] likes this.
  5. Jan 2, 2019 at 7:51 AM
    #65
    Okie1
    Okie1 New Member
    SW Missouri
    2017 Tundra 1794 Crew
    My build sheet—— even using my vin on tundras.com tells me I should have 38gallon tank but I believe it to be 30gallon. I was past empty and still only put in 30gallon.... what gives?
  6. Jan 2, 2019 at 8:00 AM
    #66
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    You still had 8 gallons of fuel in the tank...
    Mutiply your avg mpg x 8 and thats this distance you could drive b 4 the tank is empty and yhen it would take 38 gallons. Simple.
  7. Jan 2, 2019 at 3:45 PM
    #67
    Okie1
    Okie1 New Member
    SW Missouri
    i did the math... not a 38 gallon tank.
  8. Jan 2, 2019 at 3:50 PM
    #68
    Nm6300'asl
    2022 DC SR5 4x4
    Yes it is. Go 30-40 miles past zero miles left and put in 33-34 gallons. Go further and you can put in even more. O and as long as fuel is going thru the fuel pump, it is fine as well. Search the above, discussed to death and proven.
    15whtrd and BRTundra like this.
  9. Jan 2, 2019 at 5:57 PM
    #69
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Your math is wrong.
    Smoofers and 15whtrd like this.
  10. Jan 3, 2019 at 9:27 AM
    #70
    Okie1
    Okie1 New Member
    SW Missouri
    :) you guys don't pull any punches... Which is fine with me. I hope it's 38 gallon. I might throw a tank in the bank and let my truck run out just so i know for sure. Let me ask you guys this question. After you fill up how many miles will your computer tell you have left to empty? I suppose i could understand an 8 gallon reserve but after i fill up my computer tells me i have approximately 420 miles to empty. So is my compute wrong also or maybe it purposely doesn't account for the 8 gallon reserve? 14mpg x 30gallon = 420 miles.
  11. Jan 3, 2019 at 9:38 AM
    #71
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Screen isn't as accurate as pen & paper (calculator optional).
    5.7TRDProm and Fishman57 like this.
  12. Jan 3, 2019 at 5:04 PM
    #72
    Bergmen
    Bergmen New Member
    Ukiah, California
    There are two tank sizes for the 3rd Gen Tundras, 26 and 38. If you put in 30 gallons, you cannot have a 26 gallon tank. It is well known that the low fuel light comes on when there are around 8-9 gallons left in a 38 gallon tank. Lots of threads on here about that.
    Be glad you have one, I certainly am.
    15whtrd and Ronin73 like this.
  13. Jan 4, 2019 at 4:59 AM
    #73
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    The computer will only ever calculate to until it reaches the reserve no matter how low you run it. Read all the posts in this thread and many others regarding the early low fuel indicator.
    If you're really curious, let it run down to 0. Reset your trip A and keep driving another 50 miles or so. You'll get more than 30 gallons back in.
    My previous '11 Tundra with the 26 gallon did the same thing. The low light would come on and I'd only get about 20 gallons back in.
  14. Jan 4, 2019 at 9:21 AM
    #74
    WX4SNO
    WX4SNO New Member
    Anthony
    Snowville, VA
    2019 CM Limited 4x4, 5.7L Cement Grey
    I noticed my low fuel light didn't come on the other day and I had ~30 miles remaining with the dial indicator on E. I was only able to put in 28.108 gal in it so I could have went another 148 miles or so before running out of gas pretty much. To me, empty is empty...as in totally empty...I wish the dial indicator and computer would read it this way, but I guess they want to be sure folks get gas.
  15. Jan 7, 2019 at 6:00 AM
    #75
    Okie1
    Okie1 New Member
    SW Missouri
    okay i now believe everyone. After my low fuel light came on i reset the trip odometer and drove another 40 miles. The 'miles to empty' was past zero and would only say "low Fuel" (or something similar). I put in 32 gallons. the Fuel gauge was level with the E. most vehicles i have ever own the needle will drop below the E... so i suppose this all makes sense.
    Nm6300'asl likes this.
  16. Jan 16, 2019 at 11:07 AM
    #76
    BKVR6
    BKVR6 New Member
    BK
    18 Tundra unLTD
    I was at out in the woods when the light came on and display said about 20 miles till empty. Having read this tread I was not too worried, but just a little since I might have got the "accurate" truck. Took it easy to the gas station and got there with 0 on the miles to empty. Managed to put 29.2 gallons in.
    That was with the nose a little high the way the station was angled, which got me wondering if there is a difference in the ability to fill a truck completely up. based on the angle it sits. Can those with trucks with a leveled lift get more or less gas in the tank. I haven't looked at the relation of the tank to fuel input.
  17. Jan 16, 2019 at 2:04 PM
    #77
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Get on the ground and look under your driver's side of the truck. If the tank looks like a big black body bag, then it's 38gal. ;)
  18. Jan 20, 2019 at 2:10 PM
    #78
    drewid20
    drewid20 New Member
    Sitting on zero I put in 32 gallons on my first fill up.
  19. Feb 14, 2019 at 7:02 PM
    #79
    polymerhead
    polymerhead New Member
    Just filled up today. Range was down to 5 miles. Gas gauge was even with the “E” empty mark. Gas light wasn’t even on yet. Filled up with 31.9 gallons. Seems to work out that we do indeed have a 6 gallon “reserve” the range calculator and gas gauge ignores in the 38 gallon tank.
    TomyTun likes this.
  20. Feb 15, 2019 at 6:51 AM
    #80
    Ronin
    Ronin Hoof Hearted
    2019 CrewMax 5.7 Tanker
    We need more threads on this topic...:puke:
    JeremyGSU and Boerseun like this.
  21. Feb 16, 2019 at 7:58 AM
    #81
    Str8up50
    Str8up50 New Member
    WL
    S Louisiana “Chasin Redfish”
    2016 Tundra DC
    Man thank goodness for this thread and comments. I just filled up when it said 20 miles to empty. Didn’t even come close to 38g fill up. I looked at my purchase sticker to confirm larger tank and was thinking I may have got ripped off
  22. Feb 16, 2019 at 8:13 AM
    #82
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    HA HA ! That gave me a chuckle. :D
    I am super competitive.:mad:
  23. Feb 16, 2019 at 9:32 AM
    #83
    Yosemite_Fam
    Yosemite_Fam Enjoy Life!
    Larry Brown
    Mira Loma, CA
    2015 SR5 Tundra Crew Max
    Iron Cross Automotive Steps, Bakflip MX4 & TRD Off Road wheels
    2 things: 1) you don't want run completely out of gas for you will be stuck and 2) you MAY burn up your "submerged" fuel pump running the tank nearly dry. I do not know this from experience. I have read many threads on the subject and techs have commented that it can be an expensive lesson to run that low. I would just be cautious about running to low. Myself, I am a bit bummed my 2015 SR5 only has the 26 gallon tank and not the 38, for the range when towing. I am not bummed at the pump when CA prices are around $ 4.00 per gallon. Love my truck though!
  24. Feb 16, 2019 at 9:37 AM
    #84
    TRDProLife
    St.Louis
    Fake news:annoyed:
    Ronin and Yosemite_Fam[QUOTED] like this.
  25. Feb 16, 2019 at 10:59 AM
    #85
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    The price per gallon doesn’t really matter when it comes to tank size. You’re gonna put the same amount of money into fuel cost at the end of the month regardless of tank size.
  26. Feb 16, 2019 at 11:27 AM
    #86
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    Has anyone actually ran out of gas? I would like to see if someone would go out with a 5 gal can and run it until it runs out. Put the 5 gal in and then go fill up.
    my last fill up was 33.6 gal, I drove 25 miles past "0 miles left".
  27. Feb 16, 2019 at 11:52 AM
    #87
    TRDProLife
    St.Louis
    I feel like the people posting on page 3, didnt read page 2 at all. So here is evidence again.
    Ronin, TacoWuzzaTurd and jc153 like this.
  28. Feb 16, 2019 at 12:00 PM
    #88
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    Thanks for posting that. I have no doubt I have a 38 gal tank. It's good to know you have a big reserve on these trucks. I can easily drive 500 miles on one tank if needed.
  29. Feb 16, 2019 at 12:14 PM
    #89
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Everytime I see that price for 38 gal. of fuel I just get :censored: The price we all pay for fuel(crap gas) in CA is crazy.
    TomyTun likes this.
  30. Feb 16, 2019 at 12:28 PM
    #90
    TRDProLife
    St.Louis
    :boink::boink::boink:
    Otaku4life69[QUOTED] likes this.
