Recovery strap suggestions?
Discussion in 'Recovery & Gear' started by FirstGenVol, Dec 30, 2018.
  1. Dec 30, 2018 at 6:27 PM
    FirstGenVol [OP] Brake Czar
    2002 AC
    Is there a preferred brand? Amazon has a million choices. Just looking for something I can keep in my truck that won't break the bank. Also need a d ring receiver hitch.
    831Tun likes this.
  2. Dec 30, 2018 at 6:43 PM
    T-Rex266 Moderator Staff Member
  3. Dec 30, 2018 at 6:43 PM
  4. Dec 30, 2018 at 6:43 PM
  5. Dec 30, 2018 at 6:48 PM
    Aurora CO
    27K........
  6. Dec 30, 2018 at 6:53 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Kinetic 20k lbs. Used mine once to tow a Ram
  7. Dec 30, 2018 at 6:58 PM
    Aurora CO
    USA made................>>>>>>>>27000^^^^^and from a forum vendor and possible forum discount.....
    jewsNbrews likes this.
  8. Dec 30, 2018 at 7:52 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Black Wolf likes this.
  9. Dec 30, 2018 at 10:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    This is a tree strap. Shouldn’t be used to pull another truck. And probably way too short.
  10. Dec 30, 2018 at 10:20 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Just be sure you decide whether you want a snatch strap or a tow strap. They are very different.
    BestGen, Opus5150 and 831Tun like this.
  11. Dec 30, 2018 at 10:51 PM
    nishibot
    Perris, CA.
    It's actually the 30' tow strap I guess they are out of stock on that one so it put up the tree saver instead.
    joonbug[QUOTED] likes this.
  12. Dec 31, 2018 at 12:18 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  13. Dec 31, 2018 at 6:16 AM
    2002 AC
    Yeah that's really what I'm asking. I didn't realize there was this much to know. A snatch strap is designed to stretch and a tow is not. Is that right?
    The reason I'm asking is because I've had one of these in my Truck for a few years and learned it's really not safe for pulling out stuck vehicles. So I guess it should only be used for towing?
    joonbug[QUOTED] and Black Wolf like this.
  14. Dec 31, 2018 at 6:25 AM
    2002 AC
    I keep hearing about these forum discounts. Is there a secret handshake one must learn?
  15. Dec 31, 2018 at 6:33 AM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
  16. Dec 31, 2018 at 6:41 AM
    Sunnier
    Sunny
    San Diego, CA
    Yes. :D
    BestGen likes this.
  17. Dec 31, 2018 at 6:41 AM
    Aurora CO
    Call WheelersOffRoad and ask to talk to Dan.. YotaDan. Tell him what you need. I also got their tree saver strap with freebie d-shackle. The shipping box always has a Wheelers sticker and candy. These straps are custom made for Wheelers. They aren't marked up too much at all. More strength at less cost. Win...win..
    FYI>>>>Continuous use strength is 13000. Pretty good.
    joonbug likes this.
  18. Dec 31, 2018 at 6:52 AM
    Aurora CO
    I'm sure they are OK but made in China for Rhino "USA". They are made of decent material. Break strength is important but even more important is the continuous use rating. Not sure what Rhino USA continuous use rating is. It's usually 1/3 or more of break strength.
    joonbug and nishibot[QUOTED] like this.
  19. Dec 31, 2018 at 7:08 AM
    Aurora CO
    What's good about snatch straps is they are also good for towing. I've seen hooks fail on the cheaper tow straps. I avoid them completely.
    joonbug likes this.
  20. Dec 31, 2018 at 12:15 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    A snatch strap stretches and uses the kinetic force to help pull out a stuck vehicle. A tow strap doesn’t stretch. If you’re pulling out a really stuck vehicle and don’t have much traction, a snatch strap is almost required. It’ll allow your truck to get a running start and use all that energy to pull out the stuck vehicle. If you try that with a tow strap, it’s going to jolt you like you ran into a brick wall and possibly pull off a bumper or whatever you are attached to. You can tow with a snatch strap in an emergency, but you’ll ruin your snatch strap. They’re not designed to continually stretch. Ask me how I know.
    I would actually get a nice snatch strap rated 2-3 times your truck weight. Stronger is not better in this case. It won’t stretch enough if the rating is too high. And also carry a cheaper tow strap. Rated about 30k lbs.
    argtexas, Petrone, MS22 and 12 others like this.
  21. Dec 31, 2018 at 6:32 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice info. Good point about the proper amount of stretch.
    Sunnier and joonbug[QUOTED] like this.
  22. Aug 22, 2019 at 10:51 PM
    COFlyFisher
    COFlyFisher New Member
    2019 Tundra Limited Crewmax 4x4 Cav Blue
    Wish I had seen this thread before I had purchased my recovery strap and my towing strap...I would have purchased it all from “Wheeler’s Off-Road Inc.” Really like to purchase USA made when possible and support smaller shops. With that said I got an “ARB” recovery (snatch) strap and a “Smitty Built” tow strap. Both will stay in the truck together, along with my tow strap hitch.
  23. Oct 8, 2019 at 5:37 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I probably won't need it, hopefully not for me, but I'll carry this and a few other things (tow hitch strap, soft shackles) during the winter in case I run across someone needing help in the snow. It was $30cad from Costco and if it breaks the first time, it gets returned.
    I figure I'd rather be under weight and have the strap break then not enough give and do damage to someone's vehicle.
    https://www.costco.ca/Erickson-9.1-m-(30-ft.)-Recovery-Strap.product.100214660.html
    Features:
    • 8,164.7 kg (18,000 lb.) of break strength with 4,082.3 kg (9,000 lb.) maximum vehicle weight
    https://www.amazon.ca/dp/B079QMWBSL/?
    CURT Manufacturing 45832 D-Ring Shackle Mount Trailer Hitch, Fits 2-Inch Receiver, 13,000 LBS coliid=I75QSBJMPB6D5&colid=189EGHOUZJZ82&psc=1&ref_=lv_ov_lig_dp_it
    RedDragon and jordan0317 like this.
  24. Nov 14, 2019 at 6:35 PM
    Spoolnms
    Spoolnms New Member
    2014 Tundra
    7" lift, 37x13.50r18, catback dual exhaust, intake, etc.
    RedDragon and KarmaKannon like this.
  25. Dec 10, 2019 at 8:14 AM
    tglyder
    tglyder New Member
    Salt Lake City
    Silver 2010
    I have a 30' Yoke strap, a 20' chain with chain hooks on both ends and a short chain with chain hooks on both ends. Never needed more than my Ball hitch to connect to. knock on wood, I never needed it but I've helped many others out.
  26. Dec 10, 2019 at 8:33 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  27. Dec 10, 2019 at 8:36 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Please don’t connect anything to the ball hitch when doing a recovery.
    theraven, joonbug and BravoDeltaRomeo like this.
  28. Dec 10, 2019 at 8:48 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  29. Dec 10, 2019 at 8:50 AM
    TundraDude18
    'Merica
    '21 Limited CM
    Like that these are 100% U.S. made too, @smslavin :thumbsup::oldglory:
  30. Dec 11, 2019 at 10:30 AM
    tglyder
    tglyder New Member
    Salt Lake City
    Silver 2010
    WHY? and What is another option?
