Tundra 5.7 engine vibration
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra_power, Nov 30, 2018.
  1. Nov 30, 2018 at 8:59 AM
    Tundra_power
    Tundra_power [OP] New Member
    hello I have a 2008 Toyota Tundra 5.7. The truck has 91,000 and the whole truck vibrates around 1200 to 1500 RPM. And sometimes under heavy acceleration. Cannot feel it in any other rpm.
  2. Nov 30, 2018 at 9:26 AM
    15whtrd
    15whtrd Mr. Blonde
    Possible carrier bearing or U joint? Are you positive it’s at that RPM or is it at a certain speed? So many different variables. I guess it could be the fly wheel or harmonic balancer.
    I would definitely check the easy stuff first.
  3. Nov 30, 2018 at 10:18 AM
    Tundra_power
    Yes im positive seems like if you hold it at 1400rpm it does it constant. My tires are wear uneven bc i just bought the truck but it happens in park or neutral maybe the belt needs to be replace?
  4. Nov 30, 2018 at 10:26 AM
    15whtrd
    15whtrd Mr. Blonde
    Any engine codes? Is it possible it’s miss firing? I’m still leaning towards harmonic balancer or fly wheel. Hopefully somebody else with more expertise will chime in.
  5. Nov 30, 2018 at 10:33 AM
    Tundra_power
    Ok no code runs really idle is a pinch rough Power is really good. I replace my spark plugs clean my throttle body and my maf. Seems like when you rev it fast in park to 1500rpm it shakes alot and when you left off the gas it shakes to.
  6. Nov 30, 2018 at 11:04 AM
    Tundra_power
    Seems like it does it inconsistently like it shakes than stops and than shakes again very weird. I but some b12 in it and it got alittle better.
  7. Nov 30, 2018 at 2:07 PM
    15whtrd
    15whtrd Mr. Blonde
    That makes it sound like a weird misfire.
  8. Nov 30, 2018 at 3:49 PM
    Tundra_power
    Its really more of a vibration than a shake. I dont think its a misfire because its not constant. Its only a certain rpm. I was thinking a rotation problem maybe fan, serpentine belt or is just normal because when daily driving you dont feel it.
  9. Apr 21, 2020 at 10:24 AM
    dystepanov
    dystepanov New Member
    Hi I have the same thing. I have a 2018 tundra and installed a 2-1 level kit and I thought I noticed a very slight vibration so I installed a 1/2 inch carrier bearing drop spacers and it drives great no vibrations. But I did noticed when I’m parked or neutral and give a slight gas a little over 1000 rms and I feel a slight vibration. And only in a curtain rpm, can this be just how the engine runs?
  10. Feb 11, 2022 at 10:53 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Sorry to kick this old topic up, did you guys ever solve this problem ?
    I have been dealing with the same problem always arround 1000-1800 rpm while driving but also when I rev the engine when in Park. Since then I already took the whole engine apart … but never able to put my finger on the problem, so it got me thinking maybe the tundra is supposed to be like this ?
  11. Feb 13, 2022 at 1:01 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I am experiencing the problem between 1000-1800, strongest arround 1400 rpm.
    When driving but also when in P or N and rev the engine to that range.Because I have hold all the engine parts in my hands I can even tell that it’s still not good when running idle.
    Today I checked another tundra, it ran like shit but didn’t have the vibration like we are experiencing, I’m sure we have the same problem.
    What I did till now :
    -Lift kit 3 inch front and back,carrier bearing drop kit I have a 2WD. But this doesn’t have anything to with it, it’s the engine.
    -carrier bearing replaced.
    -2 heads completely rebuild + timing chains/tensioners replaced
    -new spark plugs + coils
    -torque converter replaced
    -con rod bearings + bolts replaced
    -injector cleaner added to fuel
    -cleaned throttle body
    -swapped airflow meter
    -smoke detection test on the inlet and vacuumhoses
    -cleaned actuators of camshafts and swapped them arround
    -no error codes
    I have pulled the engine and gearbox apart as you can see on the list.
    But clueless what else to try..
    I have this problem since I bought the truck 2 years ago.
    The best way to describe it , it feels like driving of a stairs, I am starting to think the tundra is supposed to be like this.But since I checked the other tundra wich didn’t have the problem it gote thinking what am I missing here..
    anyone else have any clue ?
  12. Feb 13, 2022 at 4:28 AM
    Retired...finally
    My first thought was motor mounts gone south.
    IsaiahCanada likes this.
  13. Feb 13, 2022 at 6:08 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    has any one covered the basics of battery clean, all engine a chassis grounds good, ECM fire wall connector good and no corrosion also what's the live data say , live data could solve this issue quicker than speculation can.
  14. Feb 13, 2022 at 6:11 PM
    Bonzen
    Bonzen @solid_offroad
    Lake Havasu City, AZ
    Motor mounts are blown out, or carrier bearing. Possible unbalanced driveshaft or bad ujoints.
    Cupped tires would of been my first guess however
  15. Feb 13, 2022 at 6:13 PM
    Retired...finally
    Happening in park and neutral puts the problem from the transmission to the fanblade.
    Ricos likes this.
  16. Feb 13, 2022 at 9:11 PM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    Yes is have done all of this.
    And it’s not the drive line because , it also is there in park and neutral
    I have pulled the engine and inspected the motor mounts, nothing to see hear or feel there …
  17. Feb 14, 2022 at 7:51 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I jacked up the engine under the oil sump and the vibration seems to change a little, nothing to see or feel on the engine mounts, guess I will order a set and give it a shot :(
  18. Feb 14, 2022 at 8:25 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Know a few people that broke motor mounts including myself, nobody had a vibration. If I recall correctly your vibration coincides with the fuel pump switching speeds, but its been awhile so might be way off.
  19. Feb 14, 2022 at 9:11 PM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    Some of the things I have done had another reason or just needed to be done.My truck has the problem on petrol and on LPG, I can switch fuels whenever I want, so I can make sure it’s not in one of the fuel supply’s.
    I spoke to the topic starter and a other member who responded on this topic, they both have the same vibration in the same range, they haven’t replaced anything and just ride with it and going with the thought: the truck is supposed the be like this.
    I’m sure I am missing something that is causing the shake.
  20. Mar 4, 2022 at 5:41 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    M’n
    i replaced the 2 motor mounts and the transmission mount, on both motormounts the little pin next to the bolt thread was broken, it’s slightly better now, but its definitely not solved the shaking yet … the search continues
    suggestions more then welcome
  21. Mar 4, 2022 at 7:58 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Did you replace both pieces in the picture(mount and engine side bracket)? If so, and you still have them, would you be interested in selling them? Thanks!
  22. Mar 4, 2022 at 8:51 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I replaced the engine mounts on both sides not the engine side brackets , I live and ride tundra in Holland
  23. Oct 22, 2022 at 3:11 PM
    irishchewbacca
    irishchewbacca New Member
    Sullivan
    2018 Tundra Crew Max - Magnetic Gray
    2" Rough Country Leveling Struts - Fuel Wheel - Ridge Grapplers
    Has anyone found the seismic tremors in the 1200-1500rpm range yet? I have one as well, and it has all the dealers puzzled. Its more annoying than anything. Maybe they were all made in the same place and had a bad batch of parts in them? Toyota should put us in for a PIP Kit.
  24. Oct 24, 2022 at 4:49 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    Still the same annoying problem over here
  25. Nov 11, 2022 at 10:22 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I just replaced the harmonic balancer on the crankshaft , unfortunately no result.
  26. Nov 11, 2022 at 10:36 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Every truck I’ve owned that had bad u joints performed exactly as you described
  27. Nov 11, 2022 at 10:41 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    Did you try running it without the fan blade? I had a broken blade on my work vehicle and it shook the whole truck like crazy. Just a thought, I too was going to suggest motor mounts but I see that wasn’t it. Could it be the torque converter?
  28. Nov 11, 2022 at 11:39 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I ran the engine without the fan blade and serptine belt, also I already replaced the torque converter see my previous posts…
  29. Nov 11, 2022 at 11:40 AM
    Ricos
    Ricos New Member
    Ricardo
    Never stopping ...
    I can already feel the vibration/Shake in the engine in P & N so driveline is excluded
  30. Nov 11, 2022 at 4:39 PM
    Bonzen
    Certain trucks vibrate or exhibit harmonics that are felt into the cab and drivers senses, its kinda un-explainable. Ive seen loose dashboards vibrate like crazy and make the driver think there was an engine issue.
    You have to determine if the vibration is coming from the engine operating normally, or if the engine is causing other components to vibrate and what you are actually feeling and hearing are non-mechanical parts hitting certain harmonics from a healthy engine just doing its thing. The only happening at certain RPMs makes me think this. If an engine was unbalanced the vibration would get worse as RPM increases theoretically.
