09 for a 2014
Discussion in 'Wheels & Tires' started by Zum, Oct 18, 2018.
  1. Oct 18, 2018 at 6:30 PM
    Zum
    Zum [OP] New Member
    NS Canada
    - bought a 2014 double cab 4x4 a month ago
    - bought some used factory 2009 tundra rims, thinking for some winter tires
    - at the time didn't realize the center bore is different by .5mm
    - without trying, does anyone know if the older 110mm center bore rims will fit on the 110.5mm 2014?
    - should I just try to sell them and go to a good all season on the existing rim?
    - sorry for the bullet form but my paragraph typing can get lost in a hurry
  2. Oct 18, 2018 at 6:42 PM
    joeyman15
    joeyman15 New Member
    I have a 2010 and bought a set of rims/tires from a 2016. I haven't noticed any issues and they been on for about 20k. Even got the tpms sensors reprogrammed.
    Zum[OP] likes this.
  3. Oct 18, 2018 at 6:57 PM
    Zum
    Zum [OP] New Member
    NS Canada
    - pretty sure 2016 are 110.5mm
    - 2010 would be at 110mm so the 2016 will fit over the hub in your case your lugs will center the rim
    - I'm looking opposite of what you did, if the 110mm is an actual measurement.. .sometimes measuements arent exact(thats what im hopeing)
    - will the 110mm (09)factory rim fit over the 110.5mm hub(14)?
    - I did just read an interesting post on hub and lug centric though
  4. Oct 18, 2018 at 7:13 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Huh, I thought they were interchangeable?
    jc153 and 15whtrd like this.
  5. Oct 18, 2018 at 7:41 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    The center bore is the size of the hole in the wheel. The truck hub hasn’t changed to my knowledge. 2007-present are interchangeable. .5mm is so small it wouldn’t matter anyway.
    Black Wolf, 831Tun and 15whtrd like this.
  6. Oct 18, 2018 at 7:46 PM
    15whtrd
    15whtrd Mr. Blonde
    My thoughts exactly!
    831Tun and jc153[QUOTED] like this.
  7. Oct 18, 2018 at 8:01 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Did you physically try to mount them on the truck?
  8. Oct 19, 2018 at 3:49 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Thank for the replies.
    I was on the web site wheel-size.com...if you click on 2014 then 2009 you will see a center bore difference. The gen.3 size is 110.5mm and the 1st and 2cd are listed at 110mm. This is why I was asking the question, later down the road if I decide to go aftermarket, which size would be correct, 110 /110.5mm?
  9. Oct 19, 2018 at 3:50 AM
    Zum
    Zum [OP] New Member
    NS Canada
    No...thought I'd ask first, they still have old 275 18's on them.
  10. Oct 19, 2018 at 4:50 AM
    jc153
    San Diego
    You are correct about the size difference beginning in 2014, the hub bore is .5mm larger. That being said the difference is negligible. We’re talking about half a millimeter. Tundra wheels are not a press fit, especially to those tolerances. 2007-present wheels are interchangeable.
    MotoTundra likes this.
  11. Oct 19, 2018 at 4:54 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Give it a try with one wheel and you'll see what @jc153 is talking about.
    15whtrd and jc153[QUOTED] like this.
  12. Oct 19, 2018 at 5:11 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Makes perfect sense,for some reason, (in my head)I was thinking 5mm difference not .5mm
    Thanks again
    jc153[QUOTED] and MotoTundra like this.
  13. Oct 26, 2018 at 11:23 AM
    Zum
    Zum [OP] New Member
    NS Canada
    Had a leak around one of my tpms sensors so decided to put one of the 09 rims on.
    Black rims would differently change the look of the truck.
    One a side note,dont think the 2 ton jack I have in the shed will cut it for this truck.
    15whtrd likes this.
  14. Oct 26, 2018 at 11:26 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I have a 3 ton jack I’m just about need an extension to get it up high enough. I’m hoping to find a lifted pedestal for my jack or getting a bigger one.
    I like the 09 rims on it BTW!
  15. Oct 26, 2018 at 11:41 AM
    Zum
    Zum [OP] New Member
    NS Canada
    With this 09 "spare" my tpms light didn't come on. I didn't think or it doesn't look like the 09s have the sensors, so is it just going off the 3 sensors on the original wheels?
