2015 tundra brake controller harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1G3-TRD, Feb 11, 2015.
  1. Feb 5, 2016 at 6:59 AM
    #61
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  2. Feb 5, 2016 at 7:14 AM
    #62
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I try to help you guys out a little bit. :D
    SouthBoundSteve and mdavis like this.
  3. Feb 5, 2016 at 12:50 PM
    #63
    mdavis
    Michael
    Rock Hill, SC
    @dcsleeper408 Roman hooked me up on this earlier today. $100 cheaper than at your local dealership. a few posts up he has shared the links of where to buy the controller and panel.
  4. Feb 5, 2016 at 2:52 PM
    #64
    Jjones
    Jjones New Member
    Roman do you know if you can get he 38 gallon tank and new fuel pump/whatever needs to come with it on a 2015? Hard to find an answer
  5. Feb 5, 2016 at 2:55 PM
    #65
    Roman
    Roman
    Franklin, TN
    I may be able to get them, but I honestly do not know 1) if it will work, and 2) what all parts it will take to do the swap. Last time I looked up the parts, almost everything associated with the gas tank was different between the two sizes.
  6. Feb 5, 2016 at 4:22 PM
    #66
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  7. Feb 5, 2016 at 8:00 PM
    #67
    Jjones
    Jjones New Member
    I could go with a transfer flow tank I just want the fuel gauge itself and the digital range read out to reflect the new tank. Can that be done?
  8. Feb 5, 2016 at 9:15 PM
    #68
    gosolo
    Ray
    NW Oregon
    I have the 46g tank from transfer flow and the gauge reads accurately. The display on the dash that says "miles to empty " is a little bit confused.
  9. Feb 6, 2016 at 7:18 AM
    #69
    Jjones
    Jjones New Member
    In reality I don't really use a miles to empty. But it would be nice if it was accurate. What does it read on a full tank?
  10. Feb 6, 2016 at 10:24 AM
    #70
    gosolo
    Ray
    NW Oregon
    ok, so the "miles to empty has always been pretty meaningless. When I drove off the dealer lot I think it said 420. gradually it has decreased its estimate to about 380. That is what it read with a full 46g tank also. Now, with over 450 miles on the tank it is saying about 120 which might be close if you do not account for the 6g-8g +/- that Toyota has designed into the system computer for 'reserve'. The gauge is reading slightly above a quarter tank. I anticipate filling up every 600m +/-. My fuel mpg avg is slightly above 15.
    I absolutely love being able to drive past gas stations without worry! The 26g stock tank on the 2015's is just bad engineering.
    BTW, I think this thread is about the controller so I will include this note. Adding the controller is easy. Having it register with the 2015 system computer and show up on the display is awesome. Having my 2015 Pro up to or exceeding the 1016 and perhaps the 1017 Pro is my goal.
    And before someone flames me, I do not want the leather seats, and if my truck had them I would have the same seat covers I have now regardless!
    SouthBoundSteve and dcsleeper408 like this.
  11. Feb 6, 2016 at 11:31 AM
    #71
    Jjones
    Jjones New Member
    I
    purposely got cloth. I think the only way I'll trade in this truck is if toyota either A: offers a diesel, or B: puts a 6.5 ft bed on the crew max. Just a few more things I'd like to do. Larger tank, and upgrade the internals to make it a TRD pro. If neither A or B happen I plan on keeping this truck to 200k miles
  12. Feb 6, 2016 at 11:50 AM
    #72
    gosolo
    Ray
    NW Oregon
    One of the things that makes this Pro nimble off road is the tight turning circle. For me, I would not want to lose that by having a longer wheel base. I already creased the rocker area below the rear door on the drivers side. We all have different ideals, and again, for myself, I would not want a diesel. Noisy clatter, smokey exhaust, and the smell would only be redeemed if I was towing frequently which I do not plan on doing. I'm glad I have the Double Cab since I prefer the bed space.
  13. Feb 6, 2016 at 1:23 PM
    #73
    Jjones
    Jjones New Member
    At this p
    at this point just turn it into a TRD pro with the wheels, shocks, exhaust and skid plate. I wonder how long tundras tend to last. I know that tacomas can get into the 250k relatively easily. Not sure about the larger trucks
  14. Feb 6, 2016 at 2:51 PM
    #74
    gosolo
    Ray
    NW Oregon
    it is a Pro
    dcsleeper408 likes this.
  15. Feb 7, 2016 at 11:39 AM
    #75
    usmp97
    usmp97 New Member
    2019 Silver Sky CM Platinum
    Sold ‘15 CM
    Just ordered my parts!!! Excited, can't wait for them to come in now. Thanks @Roman
    Roman likes this.
  16. Feb 7, 2016 at 12:08 PM
    #76
    Jjones
    Jjones New Member
    Glad I took the risk on this one so more people could know. The guys in the parts department at my local dealership are going to spread the word also
  17. Feb 14, 2016 at 7:28 AM
    #77
    mcfly4001
    mcfly4001 New Member
    Paul
    2014 Toyota Tundra. crew max. 4wd. Off road package. V8 5.7l
    I have a 2014 tundra. Would like to use the OEM brake controller if possible. Is there an adapter harness out there? That can be used to connect the factory brake controller to the harness at the kick panel? Or has anyone hard wired one in, if that is possible?
    Thanks
    Carlos likes this.
  18. Feb 15, 2016 at 4:38 PM
    #78
    mcfly4001
    Paul
    Anybody?
  19. Feb 15, 2016 at 5:09 PM
    #79
    mdavis
    Michael
    Rock Hill, SC
    I'm pretty sure the factory controller is only for the 15's and up. The 14's have a different connector and lack the software to display it on the drivers info screen. I doubt it will work for you.
  20. Feb 24, 2016 at 4:28 AM
    #80
    jmcolejr
    jmcolejr New Member
    James
    BRONZE 2015 TUNDRA 1794
    Brake Controller: I just installed into my 2015 TUNDRA and everything work great! Thanks for the info. Toyotaonlineparts.com/oe-toyota. (SWITCH PANEL, $21.90) (RELAY TRAILER BRAKE, $179.88).
    Carlos likes this.
  21. Mar 15, 2016 at 9:05 AM
    #81
    TRF 67
    TRF 67 New Member
    2015 Gray SR5 Tundra
    Does anyone know if the OEM Brake Controller is proportional or time delay?
  22. Apr 7, 2016 at 6:53 PM
    #82
    Ehunter
    Ehunter New Member
    2015 White Tundra XP
    32" Grill Led Bar Led Back up lights BR5 Front Bumper/ 24" light bar Warn 10,000# winch Tow Mirror OEM Brake Controller Bakflip G2 Bed Cover
  23. Apr 8, 2016 at 6:35 AM
    #83
    Roman
    Roman
    Franklin, TN
    Yes sir. Same part.
  24. Apr 8, 2016 at 2:57 PM
    #84
    Ehunter
    Ehunter New Member
    Thanks, ordered everything last night..
    Roman likes this.
  25. Apr 11, 2016 at 6:15 PM
    #85
    Ehunter
    Ehunter New Member
    Got the Brake controller in today, took all of 10 minutes to install. Everything works great.. Thanks Roman for the fast delivery...
    Roman and NewImprovedRon like this.
  26. May 5, 2016 at 9:18 PM
    #86
    gatorman
    gatorman New Member
    I would also like to know about a wire harness to use the factory brake controller with my 14 Tundra. I get that it wont read on the center display screen but do you really need to have it display? I've never had trailer brakes before but want to purchase a camper and like to have factory looks. In my mind as long as they are hooked up you should be able to just turn them on and figure out where you want them without having a screen tell you but like I said I have never had them before. Any clarification on this would be helpful.
    Carlos likes this.
  27. May 9, 2016 at 6:40 PM
    #87
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    As stated earlier in the thread, the factory Toyota OEM brake controller does not work with 14 and earlier Tundra. It only works in the 15 and later Tundra. However, you can use a Prodigy 3 and install it near the parking brake (the plug in is in the kick panel near the parking brake). To learn more about how the Prodigy works, go to etrailer.com here -> https://www.etrailer.com/bc-2014_Toyota_Tundra.htm
    The listing shows that the cable is included and they have some videos showing how it all works - the Prodigy comes with user and set up instructions.
  28. Jun 25, 2016 at 10:36 AM
    #88
    Jmcarlson12
    Jmcarlson12 New Member
    Jeff
    2015 Tundra SR5 5.7
    7" BDS lift kit, 20" fuel throttle wheels
    You installed this yourself?
  29. Jun 26, 2016 at 10:46 AM
    #89
    budge09
    budge09 New Member
    Are you able to put this into the 2014 models?
  30. Jun 26, 2016 at 12:57 PM
    #90
    mdavis
    Michael
    Rock Hill, SC
    No
