How Coilovers Work 101
Discussion in 'Suspension' started by T-Rex266, Aug 1, 2018.
  1. Aug 1, 2018 at 3:43 PM
    T-Rex266 [OP] Elon approved Staff Member
    From your suspension whore, @jberry813
    A coilover assembly has two major components, the damper itself (shock) and the spring surrounding said damper. As an assembled unit, a coilover will not change over all length at full extension. The upper and lower mounts of the assembly are a fixed extended distance (it can't get any longer regardless of preload).
    There are several ways to add ride height to your vehicle with preload depending on what kind of coilover you have. With a stock coilover, you can add a preload spacer. With aftermarket like Bilsteins you can set the lower spring perch mount higher. With tunable and rebuildable coilovers (such as King, Fox, Icon, etc.) you can add preload by adjusting the preload collar. With any of these methods, the overall mount point length of the assembly DOES NOT CHANGE. The truck will sit higher because you've preloaded the coil assembly. Spring rate with stock and aftermarket coils are a constant. Meaning if you had a 600 lb/sq in coil spring rate, and you added 1" of preload, it would take 1200 pounds (left and right coilover) of additional force over the springs to bring the truck back down to stock ride height. "Smoother ride" is completely subjective as it depends on terrain, driver preference, valving, unsprung weight, sprung weight, etc. etc. etc. But when you preload a spring, the spring will always have some stored energy. The amount of stored energy is directly proportional to how much is preloaded (Hooke's Law). That additional stored energy in a preloaded assembly is what subjectively changes the perceived ride quality. I personally think the stock springs are too soft for anything other than street use.
    Coachbuilder "shims" are commonly referred to as top-plate spacers everywhere else in the word. A top place spacer is added on top of a coilover assembly. Meaning you will physically be increasing the overall length of the assembly. This is the key difference. A top plate spacer in essence makes the coilover longer. Meaning if everything else stays the same, you will push the LCA lower with a top plate spacer giving the vehicle a higher ride height. A single CB shim is a 1/4" top plate spacer, and with the coilover working angle on tundras, would equate to just shy of 1/2" of lift. Two shims = 1/2" of spacers with about 1" of lift. Nothing changes with the spring rate or ride characteristics with a top plate spacer (except with factory upper and lower control arms which use loaded (tension) rubber bushings). The tension in the bushings would be increased. Most people's butt-to-shock meter won't be able to feel the difference but those that spend a lot of time tuning can definitely feel the additional tension. Seems like a no brainer right? Add a top plate spacer and you keep a stock ride and get a little lift? Well it's not that simple. By increasing the over all length of the coilover, you are also increasing the length of the coilover when completely compressed. Meaning if you actually get your truck dirty, and get into a full bump situation, your coilover will bottom out before your factory bump stops. Meaning the shock itself becomes the new bump stop. Here are some of my favorite examples of what happens when the shock is the new bump stop:
    Now if you're strickly a mall crawler, maybe you never run into the situation. An easy band aid is to add bump stop extensions to your stop bumps. But then you are bumping earlier than with stock geometry and yadda yadda yadda.
    So...it's up to you what sacrifices you want to make now that your informed. Up to the owner to figure out what's going to work for you, your rig, and your driving style and terrain.
  2. Aug 1, 2018 at 3:53 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    You rang, Satan?
  3. Aug 1, 2018 at 3:55 PM
  4. Aug 1, 2018 at 4:18 PM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    So someone tried to jump speed bumps with a 3" spacer lift?
    HighDesertSurfer and ColoradoTJ like this.
  5. Aug 1, 2018 at 6:03 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Your explanation of the Bilstein makes sense to me. However, why do many people say you need to run bump stop extensions with them?
  6. Aug 1, 2018 at 7:40 PM
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    Bump stop extensions make it so you dont be come one of the people in the picture's @T-Rex266 posted. You want to contact the bump stop before the shock bottoms out to prevent damage to the shock (hint: your shock shaft should not be an L shape) :rofl:
  7. Aug 1, 2018 at 9:13 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Great post, but for the rookie like myself it means jack shit. Are you telling me if I want to level my truck just get the Bilstein 6112's at 1.9" and be done or what? :frusty:
    pandapro, Mwray8909 and Sunnier like this.
  8. Aug 1, 2018 at 9:30 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    He said you don't need them with Bilstein's. Only with shims/spacers
  9. Aug 1, 2018 at 9:33 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Basically if you want to use CB shims, get bumpstop extensions which CB sells too or buy SuperBumps, both increase where the height of the stock bumpstop would be, and keep it on the street.
    Newm likes this.
  10. Aug 1, 2018 at 9:58 PM
    Rica25
    Ricardo
    Tulare
    So I have installed the 5100s with 1/2 shim on top and 5100s on rear also with 1 inch lift so should i replace the front bump stops
  11. Aug 1, 2018 at 10:15 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Good stuff man ... Do you do online courses? lol .I love learning this stuff! Thanks for sharing.
    040Tundra likes this.
  12. Aug 1, 2018 at 10:16 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I know first hand..... on a 7in bds lift New Kings are on their way!CC1621BB-EDE3-4F6A-91B1-8CA1BD54A1BB.jpg
    HighDesertSurfer likes this.
  13. Aug 1, 2018 at 10:22 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    On the front, there are 4 rock hard stock bumpstops, I replaced the ones behind the axle with SuperBumps and when I smack them, it's a whole lot less jolting. I imagine if you didn't add extensions, there's more space before you hit them and probably not good for the shock if you fly into an unexpected deep pothole.
    In action on a Taco:
    Amnesiac and equin like this.
  14. Aug 1, 2018 at 10:37 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Thanks. My plan was to use 6112's on the front and go on with life. I'm 99% street driving anyway.
  15. Aug 2, 2018 at 9:20 AM
    jberry813
    Lake Tahoe
    @T-Rex266, you done fucked up by making my post your own thread :rofl::rofl::rofl::rofl:
    Cfincke, Silv333 and T-Rex266[OP] like this.
  16. Aug 2, 2018 at 9:23 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I can't wait to get rid of my stupid spacer lift! Elka needs to speed it up with their Tundra stuff :spending:
    T-Rex266[OP] likes this.
  17. Aug 2, 2018 at 9:24 AM
    People need to read; maybe slower.
    Tfro33 and jberry813[QUOTED] like this.
  18. Aug 2, 2018 at 9:27 AM
    jberry813
    Lake Tahoe
    Holy shit! You're the first person I've ever heard of that knew about Elka pushing into the Toyota market. How did you hear?
  19. Aug 2, 2018 at 9:28 AM
    Bailey
    CO
    It could be Bold, Underlined, and in Italics and people would still miss it. At least that's the way it seems :D
    T-Rex266[QUOTED][OP] likes this.
  20. Aug 2, 2018 at 9:31 AM
    Bailey
    CO
    I've heard about them for a while. I looked under a few of @TOTAL CHAOS rides and started asking a million questions. They are currently testing on a Tundra and GX470.
    Elka is going to give King and Fox a run for their money... especially in cold weather climates :)
    equin and TOTAL CHAOS like this.
  21. Aug 2, 2018 at 9:57 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    IDK, im a bit skeptical. Are two quarter inch spacers really going to lead to this type of damage off road? Maybe at very high speeds, but even yes, i still doubt it.
    But hey.. im wrong a lot, so if i am , let me know ;)
  22. Aug 2, 2018 at 10:09 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Thanks for sharing that video. One thing I noticed with the Superbumps is how much they compressed. In a few instances, it almost appeared as if they flattened out. I can see how that may soften the ride a bit by preventing a hard jarring when smacking into stock bumpstops with a presumably harder compound. But I’m wondering if they may compress too much to the point where they may not prevent the shock bottoming out? I remember reading old posts from several years ago on an FJ forum that surmised how the softer bumpstops flattened out so much they failed to prevent damage resulting from bottoming out. I haven’t found anything else on that, though, much less concerning Tundras, so maybe it’s not a concern.
    The Bilstein 6112s I got came with some wide washers, which I assume are intended to be added to the stock bumpstops. The original post is an excellent reminder to be sure I don’t forget to install them when I get around to bolt on the 6112s.
  23. Aug 2, 2018 at 10:28 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I’m thinking the same, it be a dampening effect if any. I think the moral is risk of shock breakage if using a top-plate spacer off-roading. Definite street improvement using those, I totally recommend Superbumps like a RSB.
    equin[QUOTED] likes this.
  24. Aug 2, 2018 at 10:34 AM
    equin
    Ed
    DFW, TX
    Sorry for the dumb question, but what is “RSB?”
  25. Aug 2, 2018 at 10:36 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    I hate reading
  26. Aug 2, 2018 at 11:09 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    No worries, rear sway bar.
    Articulators will take those off but easily the biggest noticeable improvement in street handling.
  27. Aug 2, 2018 at 11:16 AM
    Warreng
    Warreng New Member
    Elka is some quality stuff. Although it is Canadian so you should probably avoid buying it, got to keep America great and all.
  28. Aug 2, 2018 at 12:08 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Thanks for the insight re coilovers, knowledge is always good when it is accurate. My last set of warranty replacement Bilstein 5100's came with new bump stops which I installed. However, it seems like I have to warranty these shocks every 1-2 years due to seal leakage. I have it set on the 2nd notch from the bottom so it is not like I am over extending them and I wonder if Bilstein sent me the bumpstops because of the frequent warranty replacements? :) 1.5 years now and no leakage and I use my truck off road regularly, maybe the bumpstops fixed it???
  29. Aug 2, 2018 at 12:46 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    The spacers are better than no spacers, if your shocks bottom out before hitting the stock bumpstops.
  30. Aug 2, 2018 at 1:05 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Hey now! I bought Superbumps and was charged an atrocious shipping fee, which I was assured in writing it covered customs only to be charged another $43 at the border. I basically paid more than double to support a US company. And you still see me promoting them.
    :canada:
    dak13, 15whtrd and Warreng[QUOTED] like this.
