Range: “Refuel” Despite Full Tank
Discussion in 'General Tundra Discussion' started by ronlunan, Jan 21, 2018.
  1. Jan 21, 2018 at 2:21 PM
    ronlunan
    ronlunan [OP] New Member
    Ron
    2018 TSS Metallic Gray
    Any ideas? Had negative terminal off two or three times today while doing work. This tank is about 10 miles old and was filled up prior to work.
    Troubleshooting Steps: I’ve restarted engine, taken off fuel cap, and disconnect/reconnected battery.
    Metro14536 likes this.
  2. Jan 21, 2018 at 2:28 PM
    RonW
    RonW New Member
    I have no idea. But at 1600 miles the dealership better.
    My comment wasn't meant to be helpful. I'm really just watching the thread. Mine only has twice that mileage so I'm curious.
  3. Jan 21, 2018 at 2:29 PM
    ronlunan
    Ron
    Oh, they’ll be seeing me if I don’t figure it out in short order!
    NewImprovedRon likes this.
  4. Jan 21, 2018 at 2:32 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Was it reading before you disconnected the battery?
    When you disconnect the battery you reset everything but the odometer. If you have not driven the truck since reconnecting the battery, then you truck has no baseline to calculate fuel economy thus it does not give you a range.
  5. Jan 21, 2018 at 3:28 PM
    Aurora CO
    This^^^
  6. Jan 21, 2018 at 3:40 PM
    Steve6
    Steve6 New Member
    Tucson
    Good to know. Haven't disconnected my battery yet but will be soon. Thanks
  7. Jan 21, 2018 at 7:54 PM
    ronlunan
    Ron
    @Cfincke I have driven the truck since and there wasn’t a warning before disconnecting battery.
  8. Jan 21, 2018 at 8:14 PM
    Cfincke
    San Antonio
    Disconnecting the battery is like your house losing power and all the clocks flashing 12:00.
    When the truck loses power, it not only resets your trip odometers back to zero and clears the fuel economy info, it also clears out certian sensor info in the ECU. The ECU has to re-learn the info, typically takes 200 miles of driving. I am not sure if the estimated fuel range info is tied in with all the sensor info the ECU has to relearn. If you truck still does not provide an estimated range after 200 miles then I would be a little more concerned.
    Boerseun likes this.
  9. Jan 21, 2018 at 9:06 PM
    ronlunan
    Ron
  10. Jan 22, 2018 at 12:31 PM
    RonW
    RonW New Member
    Be sure to post an update if you don't mind. I wonder what else gets scrambled when you disconnect the battery.
  11. Jan 22, 2018 at 4:01 PM
    ronlunan
    Ron
    Ok @RonW
    It finally reset itself. @Cfincke must’ve been right and I didn’t give it enough mileage to reset. I did two things today right before it reset; I topped off my tank, maybe 1 gallon, and I drove it about 5 miles. One (or both) of those did it.
    Kung and pmcgeorge1964 like this.
  12. Jun 17, 2018 at 10:53 PM
    Matthewadams888
    Matthewadams888 New Member
    Folding mirro
    I had the same issue after long day of led bed light instalation and 5 Mile or so later all back to normal.
  13. Oct 29, 2018 at 8:13 AM
    phil Lee
    phil Lee New Member
    Phillip
    2018 Tundra Crewmax TRD Limited
    Thanks for posting this. Just had my computer updated due to recall and the “Refuel” light was on. Dealer Service Dept didn’t know what it was and said just keep an eye on it. This post helped. Funny that the Toyota Dealer Service techs didn’t know.
    pmcgeorge1964 and Boerseun like this.
  14. Nov 22, 2018 at 12:18 PM
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Useful post! I had the same problem just now, when I disconnected my negative terminal prior to installing a remote start system. "Refuel" even though 3/4 tank. I drove it to 7/11 to get some Ben & Jerry's, but it still says refuel. I guess I'll give it a couple of days to sort things out.
    pmcgeorge1964 likes this.
  15. Jul 24, 2020 at 4:27 PM
    BradAK
    BradAK New Member
    Brad
    2018 tundra
    Cold air intake and pedal master
    Thanks for the info. I just put in a cold air intake Volant 18857 and throttle spacer and bam hooked back up the negative battery post “refuel” just like above.Thanks again for the info.Brad
  16. Jun 29, 2021 at 6:54 AM
    farm&forest
    farm&forest New Member
    2021 Tundra SR5 TRD-Off Road Double Cab
    Dobinsons 2-3" Complete Suspension Kit w/ medium Dobs Leafs, Decked Drawer System, Leitner Forged ACS Rack, Line-Xed bed and Line-Xed Tyger Blade Steps, Wet Okole seat covers, VLED lighting, soon to add Swith Pro and auxillary lights
    Soooo useful! Disconnected batt to wire aux lights to Switch Pro 9100. 'Refuel' got me quite concerned. Thanks!
  17. Nov 17, 2021 at 1:43 PM
    Supratuntaco
    Supratuntaco New Member
    Canada
    2022 Tundra Trd Pro
    I just had my 2018 Tundra in for a recall update and when I left the dealership I noticed my truck says to refuel even with a half a tank. I was going to disconnect the battery but after reading here I'm not sure what to do. Any thoughts?
  18. Nov 19, 2021 at 4:15 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
    It worked on mine, it was saying to refuel too soon. I have the 38 gallon tank and it would come on and "only" take 26 to fill, after reset it now takes 33ish to fill with the light on. I left the battery off overnight.
    Supratuntaco[QUOTED] likes this.
  19. May 10, 2022 at 6:28 AM
    bstringrandy
    bstringrandy New Member
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    This is useful info! I just installed an amp upgrade and disconnected the positive and negative battery terminals a couple of times.
    The refuel light is on but all other indications are normal except the light and no range calculation. I'll give it few trips to see if it clears out.
  20. Oct 28, 2022 at 4:38 PM
    ThatGuy246
    ThatGuy246 New Member
    2004 Tundra
    My 2019 is showing the same thing only the battery has not been disconnected.
    One problem after another with this vehicle
  21. Oct 29, 2022 at 6:47 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    At least the range isn't ACTUALLY zero because the truck is in the shop to fix a driveability issue.
    Toyota is always a bit slow to add technology, so it seems to have been a bit of a struggle.
    One of the reasons we bought out Tundra was the relative lack of technology. Back-up cam, Bluetooth, and park sensors. D to E has always been fairly accurate.... if you don't consider the 6 gallons remaining in the tank ;)
    What other issues have you run into?
  22. Oct 29, 2022 at 1:11 PM
    ThatGuy246
    2004 Tundra
    Perhaps my expectations were unrealistic. I have a 2004 Tundra, 230,000 miles. The only major issue I've had was replacing AC but that was at neay 200,000 miles. Bought the 2019 used, maybe a mistake, but 6 months later, at 50,000 miles it left me stranded 30 miles from home. Some electronic module. Cost me $1000 to replace plus hundreds more for Uber rides and rental car. Then on the way to work one morning "low tire pressure" light comes on. Stop check tires they are ok. Now this. Can I trust my fuel guage or should I try to keep track of mileage to be sure I don't run out of gas? I don't feel I can trust the vehicle
