18's or 20's - That is the question
Discussion in 'Wheels & Tires' started by NCinCO, Jun 6, 2018.
18's or 20's. What size is preferred with a 3/1 lift?
Poll closed Jun 13, 2018.
  1. 18"wheels
    19 vote(s)
    86.4%
  2. 20"wheels
    3 vote(s)
    13.6%
  1. Jun 6, 2018 at 9:59 PM
    NCinCO
    NCinCO [OP] Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    With a 3/1 kit, new wheels are almost always the next mod to come. Would you keep the 18" size or up it to 20"? How does price play in your choice?
  2. Jun 6, 2018 at 10:01 PM
    Rica25
    Ricardo
    Tulare
    I would do 17s maybe on my next set up
  3. Jun 6, 2018 at 10:14 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    18 for lifted trucks
    20 for lowered trucks
    NCinCO[OP] and Fraser like this.
  4. Jun 6, 2018 at 10:20 PM
    Fraser
    Fraser New Member
    Brady
    British Columbia
    2018 Cement CrewMax
    Agree with 18's on lifted trucks. I like the look of more tire rather than more rim, but to each their own.
    NCinCO[OP], 4x4_Angel and jewsNbrews like this.
  5. Jun 6, 2018 at 10:33 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I went 3/1 kit with 295/70/18's. I downsized from 20 to 18 and glad i did. Rides much better.
  6. Jun 6, 2018 at 10:41 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    17s or 18s for off road, tires and wheels are cheaper. 20s for street queens for less sidewall flex and better cornering. But why stop at 20s? 22s for real cornering.:crapstorm:
    SC_TRD, NCinCO[OP], joonbug and 2 others like this.
  7. Jun 6, 2018 at 10:43 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    ^^^^18's for off road. 20's for show
    SC_TRD, NCinCO[OP], JoshuaA and 2 others like this.
  8. Jun 7, 2018 at 2:30 AM
    Aurora CO
    Go with 17s. You won't regret it...
    NCinCO[OP] likes this.
  9. Jun 7, 2018 at 3:23 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I want 18s. Only reason I have 20s is because I wanted the BFGs that came on TSS. I was going to get a TRD OR but the tires swung me to the TSS. I always said nothing bigger than 18s on a 4x4.
    Black Wolf likes this.
  10. Jun 7, 2018 at 4:27 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Are you country or baller?
    295/70R18 or 305/55R20
    At least 18+ wheel offset or higher to avoid chopping
  11. Jun 7, 2018 at 5:29 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    22's, no go for 26's!
    831Tun[QUOTED] likes this.
  12. Jun 7, 2018 at 8:02 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    Care to elaborate? Thanks man :)
    831Tun likes this.
  13. Jun 7, 2018 at 8:07 AM
    Aurora CO
    Old rule of thumb for off roading...........tires should not exceed twice the diameter of your rim. 17's would be better for running 35s than 18s. More sidewall and flotation when aired down. I'm already good to go with my 18" FN's but if I had to do over it would be 17s in a heart beat. IMHO.
    zcarpenter92, dcsleeper408 and 831Tun like this.
  14. Jun 7, 2018 at 8:12 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So, with my 18s I'm gonna have to go to 37s? :broccoli:
  15. Jun 7, 2018 at 8:14 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thanks for the info. I think this falls under the plus two sizing, correct? I remember when I had a 90' CRX back in the days and everyone was running 18s but the wheel camber was all jacked because stock was 14s. I only did plus two and ran 16x7 and it was all good with even tread wear. Funny enough I still have those rims in the garage. Old school BBS RX 16x7 4x100 made in Germany rims over 25 years old. Wife hounding me to get rid of them. LOL. Thanks again for the valuable info Matt!
    Cheers!
  16. Jun 7, 2018 at 8:14 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Wheels and tires are less expensive in the 17s. Not all 17s work on our trucks though so check carefully before buying.
  17. Jun 7, 2018 at 8:15 AM
    tinman10101
    Tinman
    2016 MGM Crewmax
    Thanks for that. forgot they need to clear the brake caliber. :)
  18. Jun 7, 2018 at 8:18 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If FN would’ve had those 17” BFD lookalikes back when I was looking, I’d of likely bought those and put em on 35’s.
    DO ITTT.
  19. Jun 7, 2018 at 8:18 AM
    Aurora CO
    If you want the lift to run 37s...............Go for it...I'm running 34.5" with my 295s. It is what it is. I going up to 305s STT Pros when my Coopers wear out. Better ratio...
  20. Jun 7, 2018 at 8:19 AM
    Aurora CO
    zcarpenter92[QUOTED] likes this.
  21. Jun 7, 2018 at 8:21 AM
    Aurora CO
    FN 17s...........perfect fit like my 18" FN BFDs. (and Zachs')They come with ideal offset. Made specially for the Tundra ONLY like the BFDs...Can't go wrong..
  22. Jun 7, 2018 at 8:26 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I just put new 305s on. It's gonna be quite a while before I go to 37s and I wouldn't do it w/o re-gearing first. Now, I'm wondering where we ever got the idea to run the 295s cause the 305s fit great.
  23. Jun 7, 2018 at 8:27 AM
    Aurora CO
    For years most trucks came only with 15". For years. Was easy to get 30" tires. Times change such as much larger calipers which calls for larger rims= more rubber=more clearance required= more $$$ for lift= broke
  24. Jun 7, 2018 at 8:29 AM
    Aurora CO
    I need a CMC to run 305s. They might slightly clear but I prefer a lot of wheel well space too for these old mining roads here in CO. 295s seem to be a great fit for my OME lift.
  25. Jun 7, 2018 at 8:32 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I had to do the BMC for the 295s 'cause I like a lot of caster. I've got around 4.5* right now which, for me, is perfect. I think I'd need to chop it again if I went to 37s.
  26. Jun 7, 2018 at 8:38 AM
    Aurora CO
    @LOTSOFTOYS did a great job aligning my Tunny when he installed my OME coilovers. Close to factory but need the SPCs to get best alignment. I'm still upgrading to SPC's but doing the full RCI skids first.
  27. Jun 7, 2018 at 8:40 AM
    Aurora CO
    I've misplaced my Relentless chop plates in my storage unit. That's kind of a hold up. They are in there somewhere in a box with my beefy Wheelers Off Road tree saver strap..:homer:
  28. Jun 7, 2018 at 9:22 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I’d think it’s because there aren’t many tires offered in 305/70-18. I only know of one or two off the top of my head.
  29. Aug 4, 2020 at 7:27 PM
    IrishRanger2020
    IrishRanger2020 New Member
    Tundra TRD
    Going to jump in here and try and get info, my 2020 tundra tss is getting 5100-5160s and spcs with shackles& diff drop anyone know for a fact whats the biggest tyre i can run without chopping, also ive currently standard 20” rims can i drop to 18!?
