Toyota Techstream software
Discussion in '2nd Gen Tundras (2007-2013)' started by Srtmedic, Mar 12, 2018.
  1. Mar 12, 2018 at 2:56 PM
    Srtmedic
    Srtmedic [OP] New Member
    Robert
    2007 Tundea SR5 4WD
    Can anyone tell me where the best place would be to obtain the latest Toyota Techstream software? I have an issue with my interior lights on my truck not working, and I need this software to run the diagnostics flowchart. I already have a Panasonic Toughbook that I can install it on, and I have the obd-2 connector (usb style) to connect to the truck with the laptop. Just need the software (and of course directions on how to install it correctly so it actually works).
  2. Mar 12, 2018 at 3:16 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I always use OBDII365.com. Here the link to latest Techstream v12.20.024
    http://blog.uobdii.com/toyota-tis-techstream-v12-20-024-download-and-setup-on-win7/
    Installation Video
    https://youtu.be/GBY_Y-zpqNw
    splante1 and Onrie like this.
  3. Mar 12, 2018 at 3:21 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    ok, so I can download the Toyota techstream software from this site and install it on my computer, correct? Then use the mini VCI cable I have to connect to my truck?
  4. Mar 12, 2018 at 3:22 PM
    iHacker
    iHacker SW TRD PRO
    Depending on the VCI cable you have, if you have the drivers for the cable shouldn’t be a problem
  5. Mar 12, 2018 at 3:26 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    Ok....wondering where I obtain drivers for that cable from?
  6. Mar 12, 2018 at 3:27 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    Starting to think I would be better off just paying the $300.00 for the IT2 diagnostic scope.
    iHacker likes this.
  7. Mar 12, 2018 at 3:27 PM
    iHacker
    iHacker SW TRD PRO
    The file include drivers for the compatible cables they mention in the installation instructions
  8. Mar 12, 2018 at 3:29 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    Ok. I have a disc that came with the cable that is supposed to have the techstream software on it but I never could get it to install properly.
  9. Mar 12, 2018 at 3:30 PM
    iHacker
    iHacker SW TRD PRO
    You can also buy a compatible cable from them for about $30 links at the end of instructions
  10. Mar 12, 2018 at 3:33 PM
    iHacker
    iHacker SW TRD PRO
    This is because all the tricks you have to do if you already have one just follow the instructions, remember if we buy a cable and a disc online 100% sure the software is a cracked version, to get a legit version of the software you have to be a dealership or at least a registered mechanic to let you buy a subscription and is not a cheap subscription
  11. Mar 12, 2018 at 3:35 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    Ok....cool! thanks for the help! I have to look and see what the OS is on that Toughbook. My tablet has Windows 10, and my other computer at home is....at home, of course. I am at work. Just found out this morning that on top of the other issues, I also now have a rear axle seal leaking....and that is going to be FUN to change. Explains why my ABS light, and my 4HI and 4LO lights are all flashing, as well as the VSC light. JUST replaced the rear driveshaft a couple of weeks ago after a catastrophic failure with that......ujoint let go and destroyed the driveshaft.
  12. Mar 12, 2018 at 3:35 PM
    iHacker
    iHacker SW TRD PRO
    I bet the cable is the same everyone buy from eBay Amazon and other sites so drivers in the link I sent should be OK
  13. Mar 12, 2018 at 3:36 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    Well, is this version you referred me to going to cost anything?
  14. Mar 12, 2018 at 3:36 PM
    iHacker
    iHacker SW TRD PRO
    I’m using the latest version in the link on my Windows 10 MacBook Pro
  15. Mar 12, 2018 at 3:36 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    oh ok, cool....
  16. Mar 12, 2018 at 3:37 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    So I should be able to download it to this tablet and use it?
  17. Mar 12, 2018 at 3:37 PM
    iHacker
    iHacker SW TRD PRO
    Is always free
  18. Mar 12, 2018 at 3:38 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    Awesome!!!!!
  19. Mar 12, 2018 at 3:40 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    I am going to try to find the name of the place I ordered my driveshaft from and post it on here, in case anyone else encounters this problem. It was pretty damn nice to be able to order the complete rear shaft with a new carrier bearing installed, already balanced and ready to install.....They had one there that they were able to rebuild and ship to me....and it wound up being less expensive than buying one on Ebay or from the dealer. Couldn't find one locally in the salvage yards.
    iHacker likes this.
  20. Mar 12, 2018 at 3:46 PM
    Srtmedic
    Robert
    2007 Tundea SR5 4WD
    So, it shows in the instructions to "Replace Main.exe".....replace it with what????
  21. Mar 12, 2018 at 4:01 PM
    iHacker
    iHacker SW TRD PRO
    The cracked version of this file MainMenu.exe is in the file you download from the link
    Then you have to replace the original file in the following windows directory
    C:/Program files/toyota diagnostics/techstream/bin
    When you find the bin folder then just find the MainMenu.exe file and select it right click and select paste then a message is shown select “Paste and replace”
    All step by step in the video
    Continue with next step...
  22. Mar 12, 2018 at 4:17 PM
    iHacker
    iHacker SW TRD PRO
    Just a recommendation to anyone trying this install, before starting the installation disable any Antivirus software you have installed in your computer, most craked software is detected as malware or a Troyan which isn’t true in this case I guarantee that for sure
    If antivirus detect any file as a virus or something else is deleted immediately and this may cause software issues and stopping software to start correctly for any missing files
    Coldjustin likes this.
  23. Apr 18, 2018 at 2:04 PM
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    Jtundra81, NHSailor, cadbob and 3 others like this.
  24. Apr 19, 2018 at 6:12 AM
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    Does v12.20.024 include 2016 in the drop-down list? My current TS version goes to 2015.
    Thanks.
  25. May 17, 2018 at 5:04 PM
    maharaj1
    maharaj1 New Member
    Justin
    2014 Tundra 1794 2WD
  26. Jun 4, 2018 at 8:00 AM
    tinyt1553
    Tom
    Cypress, TX
    This one has been great for me for my 2017. https://amazon.com/gp/product/B07BCL3DFR/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
  27. Oct 27, 2018 at 10:03 AM
    jskin261
    jskin261 New Member
    Jon
    2014 S/C Tundra
    TRD Supercharger Escort radar/laser Rigid LED
    Do you know if this version will let me do the ethanol density relearn on my 2014 flex fuel?
  28. Nov 5, 2018 at 9:34 AM
    TTCrewmax
    TTCrewmax New Member
    Quick question for those that have done this. I've got the techstream installed and it works. But the MVCI Driver keeps failing during install. So now the cable isn't being recognized. Does anyone have a link to a new MVCI? It keeps ending prematurely...Thanks!
  29. Nov 25, 2018 at 10:21 AM
    Heff67
    Heff67 205,000 miles and counting
    Castle Rock, CO
    2014 Tundra SR5
    Old Man Emu Lift, Dakar Rear Leafs, Firestone Air Bags, SPC Upper Control Arms, Tough Country Evolution Winch Bumper, 12,000 lb TJM winch, Fab Fours Rear Bumper, Slee Sliders, Transfer Flow Fuel Tank, Volant Intake, Corsa Exhaust, RCI Full Skids, Switch Pros, Body Mount Chop, Dodge Ram 2500 Lugs
    You have to install the MVCI Driver first and then Techstream. Its a huge PITA but this is the best step by step I found for the Driver: It takes about 10 minutes if you follow the directions.
  30. Dec 19, 2018 at 12:58 AM
    chasen
    chasen New Member
    Chasen
