1st gen on 35's
Discussion in '1st Gen Tundras (2000-2006)' started by mudslinger79, Feb 20, 2018.
  1. Feb 20, 2018 at 12:21 PM
    mudslinger79
    mudslinger79 [OP] New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    This truck belongs to Mike French. Moto X enthusiast and pre runner guy. It has 35 inch BFG AT tires with camburg upper arms, sway a way 2.5 coil overs. No lift in the rear. I'm wondering how much trimming he had to do to get them to fit? In the video this is from he is adding 1.25 inch spacers to help rubbing in the front.
  2. Feb 20, 2018 at 12:31 PM
    TheBeast
    TheBeast The Beach
    nice ! the BFG 35" are really 34.3" I believe.
    mudslinger79[OP] likes this.
  3. Feb 20, 2018 at 12:33 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    I'm currently looking at 285 70 18 tires. They're roughly 33.7 by 11.4 by 18. I'm damn tempted. . .
    TheBeast likes this.
  4. Feb 20, 2018 at 12:37 PM
    Dejohnson8034
    Dejohnson8034 New Member
    Prosper, Texas
    2017 Tundra Limited
    looks good
  5. Feb 20, 2018 at 12:39 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    I think so too. I'm also a fan of big tires.
  6. Feb 20, 2018 at 3:05 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    After seeing a decent number of guys running 37’s on 2-3.5” of lift on 2nd and 3rd gens in the last year, I’m not surprised by this on a 1st gen. I’m betting he had to do a healthy amount of trimming though.
  7. Feb 20, 2018 at 3:58 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    I have a 2 inch spacer kit, but am planning to go to Bilstein 5100's at the top notch. Kinda leaning towards a new set of rims too. Something in the 33 inch range for tires with a 16 inch rim with 4 inches of backspacing.
  8. Feb 20, 2018 at 4:46 PM
    Casper421
    In the woods
    06 DC
    He tubbed to fit the 35’s.
    Sunnier likes this.
  9. Feb 21, 2018 at 10:12 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I can see that he cut the front bumper cover. You can see the angle cut where the front of the tire would hit it.
  10. Feb 24, 2018 at 12:19 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    I have 18x9 inch rims. I'm curious if I could fit a 33x12.50-18 on it. :yay::yay::yay::yay:
  11. Feb 25, 2018 at 11:12 AM
    Gtfour43
    Gtfour43 New Member
    Oahu
    Google rickashay tundra
  12. Mar 5, 2018 at 11:37 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have a 03 on 315/70/r17 duratrac's which are just shy of a 35. I have a 6 inch lift in the front and about a 4 inch lift in the rear. The rear has plenty of space in the wheelwells. Although the front I had to take off the mud flaps and trim the bumper. To keep from rubbing in full flex. I would also highly recommend regearing if you're going to step up to 35's.
  13. Mar 6, 2018 at 6:25 AM
    mudslinger79
    Christopher
    Williamsburg, Va
    That looks really good!!!! I just went to 33's. I need to look into regearing as my Speedo is off by 5mph. I do want that 6 inch lift too!! Just not on the budget right now.
  14. Mar 6, 2018 at 1:10 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Thanks man. I almost went with a 5 inch tuffcountry lift and 33s. But I didn't hear the best things about that lift. So I went with the 6-inch rcd lift instead. The lift itself is kind of pricey at $2,500. But where it really gets pricey is all the other things. Like rims and tires and regearing. And if you have your differentials taken apart for regearing you might as well put in a locker. The locker also requires an air compressor. And if you're going to get an air compressor might as well get a tank for it. Then I didn't like the idea of blocks for a lift in the rear. So I had custom leaf springs made. All in all I have about 8,000$ put into the truck. It sounds like a lot but I love the way the truck drives and looks. Plus the truck is a lot more capable off-road now. If I had to I would do it all over again.
    Darkness and mudslinger79[OP] like this.
  15. Mar 7, 2018 at 7:36 AM
    mudslinger79
    Christopher
    Williamsburg, Va
    Did you do all of the work yourself?
  16. Mar 10, 2018 at 3:14 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Not all of it. I have a good friend that is a mechanic with his own shop. He helped me with a lot of it.
  17. May 25, 2018 at 1:26 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Is it straight piped
  18. May 25, 2018 at 3:09 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    No. It has a Magnaflow single in single out.
  19. Jul 23, 2018 at 5:42 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I recently bought a used '05 with the same lift. The rear is in need of some freshening up and I also don't like the 6" blocks. Where'd you get the custom springs made? Also, did you go with longer shackles to make up for the more flexy leafs?
  20. Jul 23, 2018 at 5:56 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Why only a 4" in the rear?
  21. Jul 23, 2018 at 5:57 PM
    Need to know stuff
    Have fun with those 6 inch lift blocks
  22. Jul 23, 2018 at 6:23 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    "Fit" is loosely used. I've seen videos of his and he didn't cut much out (unless he changed later). He hits frame when turning and bounces off the body often. From what I have seen his pinch weld cut is exactly like mine and I barely fit 285/75.
    A few guys have done the real tub job for 35s, I've seen about 6 guys who did it and it's a bold move. I'm still on the fence about doing it it myself.
    Casper421 likes this.
  23. Jul 23, 2018 at 6:23 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Why do you think I'm looking for a leaf/shackle combo that will give me 6" of lift in the rear?
    Darkness and Sunnier like this.
  24. Jul 24, 2018 at 6:47 AM
    Brown Bear
    Nor cal
    03 TRD offroad
    The lift kit only comes with 4 inch blocks. With a 6" in the front and 4" in the rear it's supposed to make the truck sit level. When I got the leaf springs made the truck did set level. But they have since sagged a little bit so now it's sitting a little bit low in the rear. It has the oem shackles on it. I am looking at doing a shackle flip kit. This way I'll be able to get longer shackles to get it level again. I got the leaf springs made at Sacramento Spring. I love the added travel and flexibility well still being able to to hold a load in the bed.20171005_171345.jpg 20170924_114051.jpg
    Darkness, MS22 and JC303 like this.
  25. Jul 31, 2018 at 8:58 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Thanks. The guy I bought the 1st Gen from told me the left was set at 6" but it was adjustable to 4" but would need 4" blocks for the back so that's what I have been assuming. You got me thinking, so I went and measured the blocks. They're 4". Now I'm thinking of getting some 2"-2.5" springs, do a shackle flip and get rid of the blocks.
  26. Jul 31, 2018 at 11:30 PM
    Casper421
    In the woods
    06 DC
    Good thinking. What shackle flip kit are you thinking about?
  27. Jul 31, 2018 at 11:33 PM
    Casper421
    In the woods
    06 DC
    Do you rub that much with 285/75r17’s that you’re considering a tub job?
  28. Aug 1, 2018 at 5:42 AM
    Brown Bear
    Nor cal
    03 TRD offroad
    I haven't found a company that makes a shackle flip kit specifically for the first gen Tundra. This is what I was going to go with.
    https://www.ruffstuffspecialties.co...aRSL_y4F-tg13r162uP5X4j2Wjw6dxRRoC9WAQAvD_BwE
  29. Aug 1, 2018 at 5:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  30. Aug 1, 2018 at 5:06 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    TundraDude18 likes this.
