Backlit TRD Pro TOYOTA Grill Letters
Discussion in 'Lighting' started by Sting Ray, Feb 4, 2018.
  1. Feb 4, 2018 at 1:49 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Time for a new project. Got a few different ideas I want to try just need to see what's gonna look the best.
  2. Feb 4, 2018 at 1:49 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    IMG_6462.jpg Got the O hollowed out and after 4 attempts of cutting the 3mm Perspex I finally got it good enough for now.
  3. Feb 4, 2018 at 1:49 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Tried the EL wire first. Easy to work with flexible and can go around the letter several times. Bright enough, maybe....IMG_6456.jpgIMG_6458.jpgIMG_6457.jpg
  4. Feb 4, 2018 at 1:50 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    IMG_6459.jpg IMG_6460.jpg IMG_6461.jpg Then tired the led strips. It's too wide doesn't fit that well and only able to fit 1 run, not as flexible as the el, but definately britghter.
  5. Feb 4, 2018 at 1:52 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
  6. Feb 4, 2018 at 1:52 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    How you take off the letters? Is it hard?
  7. Feb 4, 2018 at 3:31 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I'm gonna try 2 different kinds of lights, EL wire (red and white) and led white led strips. And 2 different thicknesses of Perspex. I plan to dremel out the back side put the lights inside the hollowed area, and then back it with either 1mm or 3 mm Perspex. Initial thought is the the el wire won't be bright enough but the led strips will be. May paint the inside of the letters with a chrome paint to help with light reflection. Also I think the 3mm Perspex will be better as it would let more light escape. May also trim the Perspex so it sticks out a bit from the edge of the letters. Just gonna do one letter for now and see how it turns out.
  8. Feb 4, 2018 at 5:32 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  9. Feb 4, 2018 at 5:45 PM
  10. Feb 4, 2018 at 5:49 PM
    Munk
    Munk Vol For Life
    Mickey
    Bristol, Tennessee
    2017 Black SR5 Tundra Crew Max
    3/2 Lift
    Can’t wait to see how this project turns out.
    Inquiringone likes this.
  11. Feb 4, 2018 at 5:51 PM
    War Machine
    War Machine SSEM # 5 3MW
    You done yet?
  12. Feb 4, 2018 at 5:53 PM
    Believe they screwed in or they clipped on but can be removed
  13. Feb 4, 2018 at 5:54 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Lol, no not done, not even close. Maybe I'll have my first mock up letter tested tomorrow, maybe...gotta go find me a dremel bit that will cut this stuff and maybe a new dremel too.
  14. Feb 4, 2018 at 5:55 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I haven't removed my letters yet as I bought these but they don't screw in, theybhave alignment pins and doubles sided tape. They should come off similar to badges, just have to work around the pins.
  15. Feb 4, 2018 at 6:31 PM
    Aurora CO
  16. Feb 7, 2018 at 5:55 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Updated....
    Black Wolf likes this.
  17. Feb 7, 2018 at 7:14 PM
    Notachickmagnet
    Notachickmagnet New Member
    I seen one the other day that was lit, and it was sharp. Couldn't tell ya if it was a Taco or a Tundra. Couldn't look at anything but the grill
    Marty McFly and Sting Ray[OP] like this.
  18. Feb 7, 2018 at 7:54 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    May have been one of the DB customs grills.
  19. Feb 7, 2018 at 8:25 PM
    Notachickmagnet
    DB ?
    Sting Ray[QUOTED][OP] likes this.
  20. Feb 7, 2018 at 8:34 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes
  21. Feb 7, 2018 at 8:39 PM
    Notachickmagnet
    Just looked at their website...I bet it was one of theirs
  22. Feb 7, 2018 at 8:42 PM
    LML 3500HD
  23. Feb 7, 2018 at 8:54 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    There's an aluminum tape used for HVAC that I've used in the past when making reflector bowls for lights. You might find this more reflective than paint? https://www.amazon.com/3311-Silver-Aluminum-Multiple-Sizes/dp/B00O9R4K7O
  24. Feb 7, 2018 at 9:13 PM
    Marty McFly
    Morty McBoonJug
    I'm with chris, do you accept MC :spending:
  25. Feb 8, 2018 at 5:00 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  26. Feb 8, 2018 at 5:02 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Lol, I'm having some letters 3d printed and if I can find a place that will cut the Perspex then maybe just maybe Inwould be crazy enough to make more then 1 of these.... lol.
  27. Feb 8, 2018 at 7:28 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    :spending: You had me at hello
  28. Feb 8, 2018 at 1:55 PM
    geno0506
    geno0506 New Member
    Michael
  29. Feb 8, 2018 at 5:48 PM
    Aurora CO
    Damn it. I thought I said to pass the popcorn????
  30. Feb 8, 2018 at 5:52 PM
    geno0506
    geno0506 New Member
    Michael
    LMFAO, again! :rofl:
