2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Dec 13, 2017 at 1:11 AM
    #361
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Is the morimoto h4/9003 bi xenon on your website the correct motocontrol?
  2. Dec 13, 2017 at 6:10 AM
    #362
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Yes that's the correct relay harness for gen 3 Tundras
  3. Dec 13, 2017 at 2:23 PM
    #363
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    Anyone else have issues with defective connectors and a slow response to fix the issue? I have 2 pins that won't stay put on two separate 9006 connectors. One female 9006 arrived broken. Currently electrical tape is holding these connections together.
    Leo said he has switched suppliers, but I've been waiting almost a month now for replacements.
  4. Dec 14, 2017 at 11:50 AM
    #364
    dakient
    dakient New Member
    Hi Leo and forum guys, I've connected everything up and it all seems to work on my TRD Pro. But, it seems that routing the wires the way most of you guys have to the passenger sides leaves one of the 9006 connectors (the one tied to passenger ground) about 6-8 inches short from connecting to the headlight. Placed the Morimoto near the battery like I've seen.
    Using Leo's kit...what am I missing? How did you guys route the connections over? Appreciate any help, truck is apart and I need to pick up my kid in a few hours!
  5. Dec 14, 2017 at 9:16 PM
    #365
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    What will you charge me for the harness minus the motocontrol relay? Since I already have one? Let me know ASAP thanks
    geno0506 likes this.
  6. Dec 14, 2017 at 9:50 PM
    #366
    geno0506
    geno0506 New Member
    Michael
    Ty, sent you a PM!
  7. Dec 19, 2017 at 7:25 PM
    #367
    eledobleu
    Orlando, FL
    Remember guys use coupon code "holiday20" for 20% off now through new years!
    SR5, Limited, Pro, Tss = $184 with coupon
    Platinum, 1794 = $165
    Includes free shipping and all harnesses with Morimoto Motocontrol
  8. Dec 19, 2017 at 7:52 PM
    #368
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    Just curious how this worked out....I am about to start the install in a day or so:popcorn:
  9. Dec 19, 2017 at 10:50 PM
    #369
    xtyfighterx
    Ty
    North Idaho
    What about without the motocontrol
  10. Dec 21, 2017 at 2:43 PM
    #370
    eledobleu
    Orlando, FL
    So
    Minus Motocontrol is -$20
    **Correction on prices**
    Platinum, 1794 = $160
    The harnesses include the following depending on trim models:
    SR, SR5, TRD PRO, Limited
    • Morimoto H4 Relay Harness (for High/low beam fuction)
    • Conversion harness (to fit on H4 Relay)
    • PNP LED harness (for DRL via ignition fuse *high power/bright mode all the time*)
    1974, Platinum
    • DRL conversion harness (with stock high/dim function)
    xtyfighterx[QUOTED] likes this.
  11. Dec 21, 2017 at 7:44 PM
    #371
    Dsingh06
    Dsingh06 New Member
    Deepak
    Houston
    2018 Super White Tundra CM 4x4
    Okay I'm a noob to this whole conversion stuff, but I just purchased 2018 Tundra TSS and want to convert everything to LED, what all would I need? I kind of tried to skip around the forum to see but haven't seen any clear, concise answers. Thanks in advance!
  12. Dec 22, 2017 at 8:07 PM
    #372
    eledobleu
    Orlando, FL
    To use the 2018 led headlights, you only need the headlights and this harness to convert them
  13. Dec 23, 2017 at 4:17 PM
    #373
    eledobleu
    Orlando, FL
    ***For those are you interested, I have word there will be group buy on the 2018 LED Headlights soon. Im not sure yet how much of a discount it will be but I will keep everything posted.***
  14. Dec 26, 2017 at 2:00 PM
    #374
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    f.jpg thumbnail[1].jpg Thanks eledobleu. Plug and Play was flawless and fast. Two hours from start to finish with replacing the headlights and the harnesses. Everything went off without a hitch. Forgive the wheels and tires in the pic, winter here and salt on the roads just kills everything so the good wheels and tires are off for the winter.
    sohcenrubbish likes this.
  15. Dec 30, 2017 at 7:42 AM
    #375
    Trevman2
    Trevman2 New Member
    Need some help - I am installing my headlights today but I don't know where the 3 prong connector goes from the Morimoto controller...this one
  16. Dec 30, 2017 at 7:59 AM
    #376
    Trevman2
    Trevman2 New Member
    Nevermind - I found it goes to the original OEM bulb input.
  17. Dec 30, 2017 at 9:54 AM
    #377
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Any idea when this will be happening?
  18. Dec 31, 2017 at 8:30 AM
    Trevman2
    Trevman2 New Member
    I got my lights installed yesterday but they don't work 100% right - any help is appreciated...
    With the engine off, everything works like it is supposed to.
    With the engine on, the DRL's work until I turn on the headlights. When I do, the drivers side DRL goes out completely. when I turn on the high beams, the headlights and the passenger DRL shimmer from normal to a lower level, and back and forth quickly.
    I have heard of people getting a bad Morimoto. Could this be my issue?
  19. Jan 1, 2018 at 2:28 PM
    #379
    Trevman2
    Trevman2 New Member
    I got it figured out - thanks anyway
  20. Jan 3, 2018 at 3:12 PM
    #380
    JoeOndish
    JoeOndish New Member
    @eledobleu Got a question. Do you happen to have a picture or reference (apart from the guide on your main post) in regards to how the repin of the blinker should look? I thought I had it right last night, but i’m still getting a fast blink. Now that I’ve switched the wires a couple times, I can’t for the life of me remember what stock was. Knowing the order of the 3 colors (with a reference point), would be a huge help.
  21. Jan 4, 2018 at 5:05 PM
    #381
    Atlas87
    Atlas87 New Member
    2015 Tundra SR5 4x4
    TC UCA 1" Uniball , Coilover's, King bypass in rear, Rigid D2 pods, afe Coldair intake, Magnaflow w/ Turn down just after the cabin. Toyo Open Country AT 325/60R18, Method NV Wheels.
    Hey everybody, Just got my harness in on Tuesday and my headlights showed up today. I wont be able to install till tomorrow since I have to head to work here shortly but I had some questions about the install. I went through every page and read about some of the common issues folks were having and I'm torn if I want to cut the grey wire or not. It not that big of a deal I was planning on cutting the wire and adding a simple connector for easy connection in the future if need be but that's not my problem at the moment. LOL how the heck do you access the J29 area behind the dash? Am I going in from under down by the pedals or are people talking panel off for ease of access? There is a small panel down to the left of the parking brake where my stereo is plugged into but from what Ive read the grey wire I need to cut is up by the side mirror control and head adjustment dial. Can anyone explain how to access back there so I don't break the dash pulling on the wrong stuff :cheers:
  22. Jan 4, 2018 at 6:33 PM
    #382
    eledobleu
    Orlando, FL
    The purple and black wire are the wires that needed to be swapped
  23. Jan 4, 2018 at 6:35 PM
    #383
    eledobleu
    Orlando, FL
    Its behind the mirror controls and headlight level adjustment. Just pry the dash parts apart as they only clip on.
  24. Jan 5, 2018 at 7:57 PM
    #384
    Atlas87
    Atlas87 New Member
    2015 Tundra SR5 4x4
    Thank you!
    Currently doing the install but Ive got a question about my harness if anyone can let me know.
    Also I'm not sure if my harness was missing some labels but I'm not sure which connector is what regarding the high beam, ballast, and the third?
  25. Jan 5, 2018 at 8:00 PM
    #385
    JoeOndish
    Low Beam (Red/Black)
    High Beam (White)
    LED (Green)
    Atlas87[QUOTED] likes this.
  26. Jan 5, 2018 at 8:13 PM
    #386
    Atlas87
    Atlas87 New Member
    2015 Tundra SR5 4x4
    Awesome, thank you very much!
  27. Jan 8, 2018 at 5:28 PM
    #387
    boloson
    boloson New Member
    Ok so my drl's flickered a week & a half ago & shut off but when i turn on my headlights it was fine again. Today they flickered & shut off again. What do u guys think? Loose connection? I'm the one that had 1 of the wires come loose from 1 of the fasteners when i installed the lights a couple months back
  28. Jan 8, 2018 at 6:02 PM
    #388
    eledobleu
    Orlando, FL
    Must be a loose connection somewhere. Check connectors and secure pins in the connectors.
  29. Jan 8, 2018 at 10:40 PM
    #389
    Atlas87
    Atlas87 New Member
    2015 Tundra SR5 4x4
    I'm so happy with these new headlamps. Not only does it make my truck look brand new but the head turning :rofl::thumbsup: The color is just like my 5000K HIDs and Opt7 Flux X LEDs. Id say these are not as bright as my 55W HIDs but just as bright as Flux beam bulbs. After about a week the slight difference in brightness is no longer noticeable but the immediate on and off without the warm up is amazing. Also there is a visible difference when hitting the high beam unlike the Flux beams. :cheers: Thanks everyone for posting helpful tips and and to those who created the harness!
    So far no problems only with people stopping me to ask about the lights :cool:
    aperezsh likes this.
  30. Jan 8, 2018 at 10:51 PM
    #390
    Atlas87
    Atlas87 New Member
    2015 Tundra SR5 4x4
    I forgot to add I decided not to cut the grey wire and leave the purple unplugged after the re-pin. The amber DRL ignite when the parking break is released which I didn't snap a picture of yet.
