  1. Jul 16, 2025 at 5:46 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Seems to be working for me, but i just know how to use the ‘upload a file’ button. I know TS has a limit of 9 pics per post, but i dont know about here.
  2. Jul 16, 2025 at 6:00 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    I thought at first it was my data on my phone being a bad connection. But I tried at home last night on WI-FI and 5G and still wouldn't upload. I was initially trying a bunch of pictures but then tried one at a time and still not attaching. I might try adding them in a new post on the build instead of editing the post and adding them in. Maybe the edit button doesn't like adding the photos.
  3. Jul 16, 2025 at 6:00 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    As long as you’re adhering to Max file size and File type, there should not be an issue.
  4. Jul 16, 2025 at 6:07 AM
    Kalannar97
    Michael
    Hillsboro, TN
    I'm trying to add them in a new response right now. So far it is showing the loading animation in the right corner. But after it finishes, there is no picture. I remember someone mentioning a file sharing source to upload photos and enter them that way. But I can't seem to remember or find what it was.
  5. Jul 16, 2025 at 6:15 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    That works but in the future they may not work if that file sharing site goes tits up. We have many threads that have missing pictures due to for example asshole photobucket and their past policy. It's always best to upload here.
    shifty` likes this.
  6. Jul 16, 2025 at 6:15 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    On the tractor forum i visit my phones pics are too big, so i post em in a personal pm here, and that resizes them to fit at the tractor forum. Theres bound to be a way to resize them in-phone, but damned if i could figure it out.
    Kalannar97 likes this.
  7. Jul 16, 2025 at 6:42 AM
    Elam.Pingleton
    Elam.Pingleton 1st Gen 04 V-8 DC
    Elam
    Nashville Area
    2004 Tundra DC Limited
    IMG_5116.jpg I’m looking to do a timing belt kit install…how’s this list look?
  8. Jul 16, 2025 at 6:43 AM
    Booo on the non Aisin timing belt. Who knows what tensioners those are. I wouldn't trust it.
  9. Jul 16, 2025 at 6:58 AM
    Elam.Pingleton
    Elam
    Nashville Area
    I did read the big thread, and actually googled OEM AISIN kit and this is what came up, I’ll look more into into it and definitely use AISIN PARTS
  10. Jul 16, 2025 at 7:00 AM
    Summit and Rockauto have the legit Aisin kits. They are not expensive, and they come with the necessary hardware that is also OEM equivalent for the tensioners and bearings. Be sure to order the kit with all the tensioners and bearings.
  11. Jul 16, 2025 at 7:04 AM
    Elam.Pingleton
    Elam
    Nashville Area
    Thank you. I just found a reputable mechanic, and don’t have a clue when the last timing belt was done. I’ve got 244k on her and want to keep her in good shape. Ball joints are next
  12. Jul 16, 2025 at 7:06 AM
    Good plan.
    Dakillacore likes this.
  13. Jul 16, 2025 at 7:15 AM
    Dakillacore
    Georgia
    It's always been kind of a PITA uploading photos from mobile for me. You can't select multiple photos at once and can only upload one at a time. This may be the issue if you are trying to upload multiple photos at a time.
    Unless I am some troglodyte and can't figure it out but this has been my experience.
  14. Jul 16, 2025 at 7:16 AM
    Dakillacore
    Georgia
    You want to go ahead and do the water pump at the same time as the timing belt.
  15. Jul 16, 2025 at 7:17 AM
    Kalannar97
    Michael
    Hillsboro, TN
    So far, from my phone, I have been able to add 3 pictures uploading one at a time to the response posts. But as soon as I try to add the 4th one, it just keeps the loading icon going. The pictures say only about 1mb a piece, so they aren't huge file sizes either. I'll keep chugging away.
  16. Jul 16, 2025 at 7:18 AM
    It’s in the kit
  17. Jul 16, 2025 at 7:20 AM
    Elam.Pingleton
    Elam
    Nashville Area
    Yes sir!!
  18. Jul 16, 2025 at 7:44 AM
    It looks right, if the part number starts with TKT (Timing KIt), and ends with -021, then it's the right kit for the 2UZ-FE/V8. They also make a kit that ends with -001 which contains a bit less stuff, for slightly less money.
  19. Jul 16, 2025 at 8:13 AM
    Elam.Pingleton
    Elam
    Nashville Area
  20. Jul 16, 2025 at 8:13 AM
    Nope. Again, for these it’s OEM or die. With the timing belt, it’s the engine that will die. With the ball joints, it’s you that could die.
  21. Jul 16, 2025 at 8:16 AM
    BroHon likes this.
  22. Jul 16, 2025 at 8:18 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If you're adding files from a phone, sometimes after you upload them all you have to go and click more options to get the choice to attach them, like this:
    455h0le_dachshund likes this.
  23. Jul 16, 2025 at 8:18 AM
    Dakillacore
    Georgia
  24. Jul 16, 2025 at 8:24 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Thats not a bug, thats a feature. When i’m scrolling through my photo roll looking for something i dont want it to select 20 pics.
    and adding multiple pics at a time at TS always messes up the order.
  25. Jul 16, 2025 at 8:42 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    If i max out my charge controller for my solar setup, what happens to the extra power? Turns into heat? Running my fridge and a battery charger, so i’ve got the pixies moving.
  26. Jul 16, 2025 at 8:45 AM
    It gets reflected back into the atmosphere contributing to global warming. Thanks.
  27. Jul 16, 2025 at 8:48 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My charge controller is HOT.
    my lifes goal is to warm the earth enough to have beachfront property.
    im gonna have to get elon or nasa to bring some comets into the atmosphere, i’m at 1300ish ft.
    bmf4069 likes this.
  28. Jul 16, 2025 at 8:52 AM
    So you're basically saying you've opted to ignore everything we put into the megathread without outright telling us you ignored the megathread, eh? And now you're asking for parts advice, on something that's warned about in the megathread.
    Posting a picture of anything other than OEM LBJ is a great way to tell me you're ignoring all of our critical community input in the megathread. Dude. Go read it.
    And FYI, I know there are a lot of stupidshits out there saying "Sankei 555 is OEM". Let's be real. They got caught up in the in NHTSA mandatory recall for aftermarket lower balljoints a couple years ago too. Over 15,000 LBJ parts affected, along with several other brand names: NAPA, AC Delco, MOOG, Sankei, Tenneco. Why? They sourced some or all of the parts from the same freaking place. SAME SHIT DIFFERENT PILE. 555 IS NOT THE SAME AS OEM.
    OEM LBJ. Always. This isn't something people are just telling because they're elitist, we've just seen dozens and dozens of 1st gens killed by LBJ failures (so much an entire 20+ page thread exists on the subject, which again, is linked in the megathread!)
    (more info here)
  29. Jul 16, 2025 at 8:53 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    dc people… right?
    J/k i’ve been to vanderbilt, nashvillians cant read. Maybe we need emptylord to turn the megathread into an audiobook.
  30. Jul 16, 2025 at 9:01 AM
    Dakillacore
    Georgia
