What Size Tires do you have? 1ST GENS ONLY!
Discussion in '1st Gen Tundras (2000-2006)' started by lsaami, Dec 1, 2021.
What size tires do you have?
  1. stock size (245/75/16 or 265/70/17 or 17" equivalent)
    32 vote(s)
    21.2%
  2. +1 (265/75/16 - 265/70/17 or equivalent)
    52 vote(s)
    34.4%
  3. 33" (285/75/16 - 285/70/17 or 255/85/16 or equivalent)
    48 vote(s)
    31.8%
  4. 34" (285/75/17 - 305/70/16 or equivalent)
    11 vote(s)
    7.3%
  5. 35" (315/75/16 or equivalent)
    8 vote(s)
    5.3%
  6. "I don't have footwells" 35"+
    0 vote(s)
    0.0%
  1. Mar 31, 2025 at 9:23 AM
    #61
    mallcrawler06
    mallcrawler06 New Member
    What did you have to do to get those to fit?
  2. Mar 31, 2025 at 9:31 AM
    #62
    if I recall, the general consensus is they "fit", as in, they're fine as long as you don't turn or hit any bumps. i.e. they rub the shit out of everything, and will eat the hell out of the tires and your plastics at every pothole or speed bump. Be prepared to replace tires unless you drive everywhere without turning.
    But that member hasn't registered a login here since 2023, so they may not say. What I can tell you is, I don't believe there's a person in all my years here on this forum that's been able to cleanly tuck 35s without damage to truck and tires unless they cut into the firewall.
    If you really want to run 35s like that, you really need to read the "Suspension, wheel and tires..." section of this thread so you understand what you're up against: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    That community-managed thread essentially contains a decade of collective 1st Gen Tundra experience in the first two replies. It is there to help newbies avoid really stupid mistakes, because the rest of us already did it for you, to save you the $$ and pain.
    tl;dr - It's no small feat to run 35s, and there are several substantial consequences which aren't liited to rubbing/damage if you really feel like you need 35s for some reason.
  3. Mar 31, 2025 at 9:36 AM
    #63
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    455h0le_dachshund likes this.
  4. Mar 31, 2025 at 9:57 AM
    #64
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have 295/75r16
    They're basically a 33.5"x11.5" tire.
    I need to turn the wheels and torque the inner rear most LBJ bolt on each side to 90ft lbs, get a shorter 19mm 1/2" drive socket (and possibly a shorter torque wrench) to torque the center steering rack bolt to 122ft lbs, find a second set of hands to torque the two rear cam bolts to 96ft lbs, and adjust the toe. I'be been doing what I can when I can. But not having a helper is making go it slow. Still making strides. Hoping to take the truck to Juan at Toy Lex for the fine adjustments this week.
    I'll bring two 35" tires mounted on wheels on the tenth, we can play with if we have time, after doing your and my springs. But I don't plan to do the body lift until sometime after Jambo.
    The Black Mamba likes this.
  5. Jul 12, 2025 at 8:15 AM
    #65
    MYOTA67
    MYOTA67 New Member
    Joe
    Golden Colorado
    2005 Tundra DC 4x4 4.7L
    Been thinking about getting these tires but fear the will be so narrow and stuck inside the fender flares. Any other shots of this truck?
  6. Jul 12, 2025 at 8:18 AM
    #66
    Weird, @lsaami didn't include a 32.5" option (275/70r17)
    So I can't update my vote to the correct size.
  7. Jul 12, 2025 at 8:23 AM
    #67
    This aged well
  8. Jul 12, 2025 at 9:34 AM
    #68
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
  9. Jul 12, 2025 at 9:46 AM
    #69
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I realized I never did a follow up with the Kenda Klever RT 35x10.5R17 mounted
    Tlar25, khooiii, bmf4069 and 2 others like this.
  10. Jul 12, 2025 at 12:35 PM
    #70
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    My truck. I suspect the rims are what came on it (and need work, obviously).
    P265/70/R17
    Spare tire: P265/65/R17
    So I think my running tires are a bit bigger than what she came with.
  11. Jul 12, 2025 at 12:43 PM
    #71
    I never posted mine either it seems. 285/75/16 on 16x8 wheels with 4.5” back spacing.
    Tlar25, khooiii, bmf4069 and 4 others like this.
  12. Jul 12, 2025 at 2:48 PM
    #72
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    The "65" on my spare tire.....if I replaced all of my tires with P265/65/R17's....how much of a height change would that have?
    Conversely if I replaced my spare with a P265/70/R17----it would fit under the bed fine, right?
  13. Jul 12, 2025 at 2:51 PM
    #73
    About an inch difference. The larger size would fit as your spare.
  14. Jul 12, 2025 at 2:59 PM
    #74
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Wow! You guys know all the cool things! :)
    How big of a problem would running that spare cause being one is less in diameter?
    After fixing three flat tires last week I'm expecting more trouble!
    (Changed one tire and plugged another for a disabled motorist I met July 4 and a few days later plugged one of my trailer tires).
  15. Jul 12, 2025 at 3:01 PM
    #75
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That smaller spare wouldn't be ideal. Would be ok to get you to the tire shop at in-town speeds.
    Bought2Pull[QUOTED] likes this.
  16. Jul 12, 2025 at 3:11 PM
    #76
    You’d survive :anonymous:
  17. Jul 12, 2025 at 3:22 PM
    #77
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Nice looking rig. Are you still running stock gearing?
  18. Jul 12, 2025 at 3:40 PM
    #78
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Thanks. No, I'm running 4.56 gearing.
  19. Jul 12, 2025 at 5:13 PM
    #79
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    That's what my dad sai
    That's what I was thinking. Will try to replace it before long.
    What do you think an unused tire, that spent its 19 years under a bed, is worth on the second-hand market? I'll try and sell it.
  20. Jul 12, 2025 at 7:40 PM
    #80
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    $0-50. I tried to sell mine for a few months, finally gave it away.
  21. Jul 12, 2025 at 9:47 PM
    #81
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Probably will be my experience too. SMH :p
  22. Jul 13, 2025 at 7:47 AM
    #82
    Honestly, I think 265/70r17 really hits the sweet spot for these trucks for mixed on-road/off-road use.
    You get an inch of height over OEM, but with roughly the same width. If you go with an aggressive tread, you may get a little more than an inch. They're the same width, and they're less than 1.5" taller, so you shouldn't really rub much (if at all), even with stock alignment numbers. And when levelling the truck, the larger tire size makes your wheel/tire combo look far less emaciated.
    Kalannar97 likes this.
  23. Jul 14, 2025 at 10:41 AM
    #83
    bmf4069 Captain wtf
    I have 255/85r16(33x10x16) on mine with 1.25" spacers. I think they look OK.
    BroHon, Tlar25, khooiii and 2 others like this.
  24. Jul 14, 2025 at 11:46 AM
    #84
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    265/70R16
  25. Jul 14, 2025 at 12:21 PM
    #85
    Suwand28
    Suwand28 New Member
    Tony
    2002 Tundra AC SR5 V8 4WD
    Replaced steel stocks with BBS RD-T 17x8 on 285/70/R17 Nitto Terra Grapplers
    285/70/17. I don't run spacers and it only slightly rubs on full lock.
    Leveling kit in the near future.
    Redoak likes this.
  26. Jul 14, 2025 at 12:54 PM
    #86
    Scares me every time someone says, "leveling kit" on here. I'm always concerned they're going to make the mistake of buying strut spacers, or the garbage Rough Country sells, which is often advertised as "leveling kit".
  27. Jul 14, 2025 at 12:56 PM
    #87
    Suwand28
    Suwand28 New Member
    Tony
    Kinda new to trucks in general, was going to take it to a reputable shop and have it done. Any advice on what I should be avoiding?
  28. Jul 14, 2025 at 1:00 PM
    #88
    Oh, and here's something I posted elsewhere that shows how it's virtually impossible to visually tell the difference between 32.5" (275/70r17) and 33" (285/70r17) from 10ft away. Reposting here for posterity, since people seem to be convinced they "must go 33 or GTFO".
    Not apples-to-apples angles here, but here's 285/75r17 (32.9") versus 275/75r17 (32.5") on the same truck, same wheels, same lift. You'd see a slight width difference from behind, but honestly, that half inch (er, quarter inch top & bottom) of added tire diameter is negligible to me, visually.
    Wildpeak AT3W in 285:
    Mickey Baja Legend EXP in 275:
    Another angle with 285/70r17.
    And again with 275/70r17.
  29. Jul 14, 2025 at 1:02 PM
    #89
    [Avoid] Spacer lifts of any kind.
    Please do yourself a favor and read the "Suspension, wheel and tires ..." section found about midway thru the very 1st reply of this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    It'll prepare you for what you need to know.
    Get a quote from the shop before you get any work done, then run it by us over here. We can tell you if it's shit or not. Generally speaking though, that section is years of this forums' knowledge, condensed into about 2 dozen bullet points, and will help you avoid bullshit.
    Suwand28[QUOTED] likes this.
  30. Jul 14, 2025 at 1:12 PM
    #90
    Suwand28
    Suwand28 New Member
    Tony
    Just went through that post and yeah, that meme at the end is spot on! Thanks!
