  1. Jun 22, 2025 at 9:29 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    The wolf box does a really good job at not distorting the camera. It definitely is weird getting used to it, but I think its become one of those mandatory mods I'll do to every vehicle I own.
  2. Jun 22, 2025 at 9:42 AM
    No pics?
  3. Jun 22, 2025 at 12:01 PM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    2" spacer level 285/70/17 Falken Wildpeaks
    Got the sumo springs installed! Rode good on the way home from the mechanic. I'll have my dirtbike on a hitch carrier and camping gear loaded up for the 4th of July so we'll see how it carries the weight and rides then but they definitely don't feel too stiff. My old bump stops rusted off long ago and the Ubolts were so rusted they had to be cut off.
    Also swapped the passenger and driver seat belts. They are identical. Slow retracting solved!
  4. Jun 22, 2025 at 12:08 PM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    Also picked up a rooftop cargo box. Pretty tall but the extra space will be nice on road trips
    Dustdog, oscardog86, bmf4069 and 4 others like this.
  5. Jun 22, 2025 at 1:26 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Very nice. This was mine leaving the lumber yard. I really need to go ahead and do something with the rear
  6. Jun 22, 2025 at 2:18 PM
    Looks like it's handling things perfectly fine!
  7. Jun 22, 2025 at 3:43 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I think those blue Sumo Springs are about right for what you're planning. How much does the bike weigh? They were perfect for me with a topper, gear, and my camper trailer with ~300lbs tongue weight. But they didn't hold up to the 860lb slide-in camper.
    oscardog86 and 455h0le_dachshund like this.
  8. Jun 22, 2025 at 4:08 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Wow that’s great! My medium duty Deavers would be on the stops
  9. Jun 22, 2025 at 4:11 PM
    Voss
    2003 AC TRD 4x4
    Took her somewhere new this weekend. Used to primitive sites with no one around so it’s a little weird but different is good at timesIMG_1125.jpg IMG_1124.jpg IMG_1123.jpg
    I’ll be fishing for Halibut for breakfast. That’ll be a first off the coast too. Who said old dogs can’t learn new tricks lol
  10. Jun 22, 2025 at 4:17 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Fish for breakfast is something a nightshift vampire would do.
    Trust me.
  11. Jun 22, 2025 at 5:39 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    That's a cool spot by the beach, is it crystal cove area?
    Voss[QUOTED] and oscardog86 like this.
  12. Jun 22, 2025 at 6:50 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Let's see here......been pulling the trailer mowing yards. Heatwave is a bit oppressive but we are coping.
    Had to use 4wd Hi yesterday to back up a paved / graveled driveway. Went in and came out easily.
    Been using the Heat Shield window sun blockers for the front side windows. Those work pretty well!
    Managed to lose the upper screw cover for my driver's side climb-in bracket or whatever you call that. I grab it and pull myself up as I climb in.
    oscardog86 and FrenchToasty like this.
  13. Jun 22, 2025 at 10:15 PM
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    That’s one I haven’t got around to yet. Last time I was under the rear I noticed the hitch bar was rusting out like that on mine. Now I even have a part number.
  14. Jun 22, 2025 at 10:15 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Did the ol rear door-check upgrade. I used to think the rear doors just weren't designed to stay open, but eventually learned that they are supposed to.
    Seems like the old Toyota design with the friction fit door checks all wear out. Didn't know that older 1GTs had friction fit front door checks too!
    Anyways, grabbed the autotechnica pieces mentioned and swapped the roller cartridge onto the stock arms. About a 30 minute exercise per side, including removal, install, and reinstall of door panels.
    Also installed the reinforcing plates from fr33lace onto all four doors, a rear diff breather extension, and an electrical accessory tray under the hood.
    khooiii, shifty`, oscardog86 and 3 others like this.
  15. Jun 22, 2025 at 10:36 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Mine is pretty rusty also but able to pull a 4K pound load (so far). I'd like to remove it, sandblast, paint, put back on, or replace it. Where / how did you find a new one?
    Nevermind, found it. OEM still available. Hmmm.....do I really need a new hitch????
    04TundraTRD[QUOTED] likes this.
  16. Jun 23, 2025 at 5:00 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I can see a couple part numbers, but do you have all the part numbers to do this job in its entirety for anyone else it may help?
    Jack McCarthy and FrenchToasty like this.
  17. Jun 23, 2025 at 6:27 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    Well that was my whole weekend, was only able to do passenger side as well as front differential bushings. Not fun having to cut and melt out old bushings. My alignment is so far off now as well and I can’t get one for another week because I have to do the drivers side. Hopefully it will be okay.
    G_unit3000, BroHon, MooreKen and 5 others like this.
  18. Jun 23, 2025 at 7:02 AM
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    Could someone supply me with a factory part number for the 28mm front sway bar?
    Thank you!
  19. Jun 23, 2025 at 7:46 AM
    If that's what your truck had originally, you can look it up here: https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
    It'll be under the Transmission and chassis section, inside the Front spring & shock absorber sub-section of the diagrams. What I'm saying will make sense when you get to the site linked in that thread.
  20. Jun 23, 2025 at 8:01 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    New Denso Radiator (Jan 2025) cap leaking. So I noticed some antifreeze crusting on both sides of my cap and had a buddy of mine (who owns a radiator shop of all things) take a look at it. He took a look at the old cap and said it plunged ok but that it looks like there are a couple of small dings in it. For $10 he put on this 16PSI cap. I know the original is 88KPA (which I think = 12 PSI. I’m asking you guys if this is an issue? To me 4 PSI is no big deal but when dealing with/ such low pressure to begin with maybe it is. Anyone want to chime in?? I didn’t take a before but I did take an after.IMG_2234.jpg
    PNW15 and oscardog86 like this.
  21. Jun 23, 2025 at 8:05 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    That would make me a little nervous. Sometimes on older radiators the plastic tanks crack, but sometimes its the glue that holds the aluminum in. I guess i’d block off the radiator, leave it in the driveway at 1500rpm, and let it get hot, like hot hot. If it can handle a bit more heat than normal, it oughtta be fine for a few years.
    MooreKen likes this.
  22. Jun 23, 2025 at 8:15 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Today I learned that there are different swaybars for these trucks.
    Makes sense I guess. When I had a 2nd gen Tacoma I procured an OR swaybar because it is thinner than the SR5/Sport swaybar.
    I wonder if I can procure a narrower swaybar for my Tundra....
  23. Jun 23, 2025 at 8:28 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    I don’t trust AI but I think I answered my own question. This was AI response to my question “
    AI Overview
    A 16psi radiator cap is commonly used on Toyota 4.7L V8 engines, particularly in models like the Land Cruiser and Sequoia. For example, the 1998-2007 Toyota Land Cruiser 4.7L V8 and the 2008-2019 Toyota Sequoia 4.7L V8 both utilize a 16 psi radiator cap
    Sirfive[QUOTED] likes this.
  24. Jun 23, 2025 at 8:54 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I wasnt worried about the engine, my concern was with the radiator, how many sq.in. Is the extra 4psi ‘pushing’ on?
  25. Jun 23, 2025 at 9:13 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Note that the nut you see rusted to the bolt was tack-welded to the hitch. I used some old nuts from my stash to replace them so I don't have part numbers for those
    Items Qty Price
    Rear Bumper Reinforcement Sub-Assembly #2
    Part Number: 52043-0C010
    1 $252.19
    Rear Bumper Arm Sub-Assembly Right Hand
    Part Number: 52015-0C010
    1 $89.00
    Rear Bumper Arm Sub-Assembly Left Hand
    Part Number: 52016-0C010
    1 $89.00
    Bolt with Washer
    Part Number: 90119-12311
    4 $10.88
    BOLT, W/WASHER
    Part Number: 90119-A0003
    2 $8.34
    Bolt with Washer
    Part Number: 90119-A0073
    6 $19.02
    Bolt with Washer
    Part Number: 90119-A0047
    6 $9.30
    Bolt with Washer
    Part Number: 90119-A0048
    4 $5.08
  26. Jun 23, 2025 at 9:18 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    My plan is to drive like normal but keep a close eye on things for a while. Here are the radiator dimensions, etc…IMG_0859.jpg
  27. Jun 23, 2025 at 10:01 AM
    NickB_01TRD
    KY
    I'm pretty sure the optional "TRD" cap is 16 PSI. Not sure who all was buying that or what the purpose really was but it does exist.
    MooreKen[QUOTED] likes this.
  28. Jun 23, 2025 at 10:16 AM
    M14 EBR
    It's NOT what my truck had originally, and that's why I am asking for help finding the part number.
  29. Jun 23, 2025 at 10:39 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I found a windshield sun shade for my truck. I didn't have any luck locally so I ordered one that's made for a 3rd gen tacoma (2016-2023). Fits perfectly.
  30. Jun 23, 2025 at 10:41 AM
    Heat shield has custom ones that fit perfect
    G_unit3000, bmf4069 and PNW15 like this.
