New PLZ stereo install
Discussion in '1st Gen Tundras (2000-2006)' started by Dracko, Jun 18, 2025.
  1. Jun 18, 2025 at 9:49 PM
    Dracko
    Dracko [OP] New Member
    2005 Tundra SR5
    Hoping for a little basic advice on installing a new head unit in my 2005 DBL cab SR5 from folks that have done this install. I read the thread about determining if you have an amp and I’m pretty sure I don’t because there isn’t one behind the back panel, rear storage or under the seat.
    So I’d like to confirm the Metra 70-1761 is the proper harness for this?…since I don’t need an amp bypass. Any write ups or diagrams on which wire goes to which would be appreciated…I’m a total newb when it comes to audio stuff but I’ve done my fair share of wiring over the years.
    G_unit3000 likes this.
  2. Jun 19, 2025 at 5:17 AM
    bfunke
    bfunke Tundra Curmudgeon
    Search is your friend on this forum.
    PNW15, ATBAV8 and Dracko[OP] like this.
  3. Jun 19, 2025 at 5:23 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Good morning. Have you ever read through THIS THREAD?
    There's a section, "Audio, audio upgrades and cameras...", that can be found about 8 paragraphs down in the first post. Start there.
    shifty` and G_unit3000 like this.
  4. Jun 19, 2025 at 5:39 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  5. Jun 19, 2025 at 5:59 AM
    Dracko
    2005 Tundra SR5
  6. Jun 19, 2025 at 6:08 AM
    Dracko
    2005 Tundra SR5
    Yeah I did read through there, but hadn’t followed one of the hyperlinks. Looks like the Metra harness I plan to use is the right one. Little more digging and I’m sure I’ll find what each wire is for.
    Cheers.
  7. Jun 19, 2025 at 6:22 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    With those connectors it appears to be the basic DC SR5 6 speaker Audio but the drawing does not jive with actual conductors present.
    Edit.....seem to always forget about illumination conductors that don't show on Radio schematic....all conductors present and accounted for.
  8. Jun 19, 2025 at 8:19 AM
    Dracko
    2005 Tundra SR5
    Awesome thanks BubbaW that should be all I need.
    The Black Mamba and BubbaW like this.
  9. Jun 19, 2025 at 10:04 AM
    Dracko
    2005 Tundra SR5
    thanks again Bubba. Although I think I might be making this far more complicated than it needs to be. Now that I have my hands on the Metra adapters and the harness for the stereo, I see the wires are all same colors.
    So is it safe to assume I can just solder/heat shrink color to color and plug this unit in?
    I’ve done quite a bit of wiring, but never swapped a stereo before.
    KNABORES likes this.
  10. Jun 19, 2025 at 10:22 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Don't know if it's safe to assume anything unless the output pins of new HU match pin for pin with OEM harness and each one of those pins functions....make sense ?
    What type of new HU are you putting in ?
  11. Jun 19, 2025 at 10:29 AM
    Dracko
    2005 Tundra SR5
    It’s made by PLZ. I just watched a YouTube video they have QR coded in the instructions and the guy just matches the colors from PLZ harness to Metra harness.
  12. Jun 19, 2025 at 10:37 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Well, I reckon if it works you're good to go.....time will tell.
    Without seeing certain things, hard for me to know how you're able to go from 2 OEM connectors to the radio connector. Both of the OEM connectors have conductors you need. If you're convinced it'll work, go for it,
    Dracko[QUOTED][OP] and shifty` like this.
  13. Jun 19, 2025 at 12:04 PM
    Dracko
    2005 Tundra SR5
    Bit of a gamble but all seems to be working fine. Still need to sort out the mounting brackets.
    BubbaW[QUOTED] likes this.
  14. Jun 19, 2025 at 2:33 PM
    Dracko
    2005 Tundra SR5
    Fits in there pretty good. So far seems like a good setup, Apple CarPlay, back up camera AND a volume knob! Not 3 options that are easy to find these days, especially for under $200US. Will know its quality if it survives a few Canadian winters.
    Used Metra 70-1671 harness adapter and Metra 95-8202 trim kit.
    the trim needed a little work from the belt sander to fit nice.
    thanks to everybody that took the time to offer advice, this forum rules!
  15. Jun 19, 2025 at 4:17 PM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    Just here to comment you've got great taste in music
    Dracko[OP] likes this.
  16. Jun 19, 2025 at 4:36 PM
    Dracko
    2005 Tundra SR5
    Right on man, Sturg is the GOAT in my books
    Acatlin96[QUOTED] likes this.
  17. Jun 19, 2025 at 11:43 PM
    I’m not sure when or why the album artwork changed though
  18. Jun 20, 2025 at 4:18 AM
    Dracko
    2005 Tundra SR5
    I was wondering the same thing, I guess it was a 10 year anniversary vinyl release. Hopefully see a new album this year.
  19. Jun 20, 2025 at 4:30 AM
    Doubt we see another “Sturgill” album. Maybe the art work changed to signify that “Sturgill” is dead. Johnny Blue Skies passage du desir was the last Sturgill album released.
    Dracko[QUOTED][OP] likes this.
  20. Jun 20, 2025 at 8:34 AM
    bfunke
    He’s not dead. He released an album in 2024 and played on the Righteous Gemstones.
  21. Jun 20, 2025 at 8:44 AM
    Sturgill Simpson the performing artist is “dead”. He went under a different stage name for his last album. He said he would make 5 albums and quit. Dood and Juanita was number 5.
  22. Jun 21, 2025 at 11:13 AM
    That’s such a damn good album. Probably one of my top 10 favorite albums in the genre going back decades. If not in the top 5.
  23. Jun 21, 2025 at 11:14 AM
    And it’s not the one he won album of the year for oddly
  24. Jun 21, 2025 at 11:15 AM
    I don’t love the JBS stuff, doesn’t quite have the same edge to it. Feels like if Marty Robbins was a French beatnik or something.
  25. Jun 21, 2025 at 11:16 AM
    Yeah, that was stupefying.
  26. Jun 21, 2025 at 11:36 AM
    I was jammin some Sturgill when I installed my radio years ago also it seems. Sure like that the pre 2003 or so center bezel needs no trim.
    Dracko[OP] and shifty` like this.
  27. Jun 21, 2025 at 4:49 PM
    Dracko
    2005 Tundra SR5
    That does make sense about Sturgill being “dead”, we just saw him at Massey Hall in November and he was talking about getting back in the studio for another album. So that’s promising no matter the name he goes by.
    shifty` likes this.
  28. Jun 21, 2025 at 4:52 PM
    Dracko
    2005 Tundra SR5
    Oh ya that’s makes life way easier. That album still gets heavy rotation over here. .
  29. Jun 21, 2025 at 4:53 PM
    Dracko
    2005 Tundra SR5
    Haha with some heavy Allman Brothers vibes. The album grows on ya.
  30. Jun 21, 2025 at 5:10 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Only if it were early years....Duane and Gregg, Dickie Betts time frame.
