Interior drivers side door pull
Discussion in '1st Gen Tundras (2000-2006)' started by Mikes Tundra, Sep 24, 2023.
  1. Sep 24, 2023 at 7:44 AM
    Mikes Tundra
    Mikes Tundra [OP] New Member
    I have been able to find several places that are selling the tan and grey interior pull handles for the passenger door, but I can't find a tan pull handle(not the release) for the drivers side.
    Anyone have suggestions.
    Thanks
  2. Sep 24, 2023 at 8:48 AM
    I have a lot of ideas, and could even give you part numbers, but you've given zero info about your truck. So instead, here, look at the first few bullet points of this thread, and look up the exact part number: https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
    That will explain how to use the EPC-DATA site to get your VIN-specific color, for your cab type, and what not. After you plug in your VIN and click Search, go to the 'Body and Interior' section, then to the "FRONT DOOR LOCK & HANDLE" section.
    Under the picture is a link to "open the full size schematic". Click on the number pointing to the part you need. LH = left hand (driver), RH = right hand (passenger). If you need to confirm your part, search the part number on fleaBay for pics but DO NOT buy auto parts on fleaBay or scAmazon unless you like knockoff parts and/or cheap shit that'll break a few months or a year/two down the road. Learn from the experiences of others on the forum.
    While you're at it, you may want to read this: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    RustyMcTee and The Black Mamba like this.
  3. Sep 24, 2023 at 10:49 AM
    avoice217
    avoice217 New Member
    Justin
    2001 Red Tundra
    Hey Mikes Tundra, I've been there myself and totally understand the experience. I had an issue with the drivers side pull handle and went into some really deep research. Thankfully I was able to find one at a local junk yard. It wasn't exactly a mirror match with what I found online, but it did the primary job. The sad part is that the outer cover part doesn't fit the replacement, but it was already broken to begin with, so very easy to replace in the future. However I do agree with shifty in posting what kind of Tundra you have will go a long ways towards getting you the necessary help.
  4. Sep 24, 2023 at 11:32 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Lcyolada Interior Door Handle with Bezel, Gray, Front Inside Left Driver Side,for 2000-2006 Toyota Tundra | 692060C010B1,TO1352187,69278-0C010-B0 Inner Handle Door Part https://a.co/d/2oNF3SV
    Is this not what you’re looking for or am I missing something?
  5. Sep 24, 2023 at 12:50 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I think he means this (albeit for the the other side)
    Driver side p/n is 74640-0C010-xx, where xx = your interior color code.
    I just replaced my passenger side, and easily found the part at McGeorge (et al).
    The Black Mamba likes this.
  6. Sep 24, 2023 at 3:07 PM
    Ah, I call that the grab handle. Door pull for me is the little lever thingy on the door card that opens the latch.
  7. Sep 24, 2023 at 3:36 PM
    w666
    Maryland
    Well, now if he ever appears again he'll have both choices.
  8. Sep 24, 2023 at 4:56 PM
    RustyMcTee
    RustyMcTee New Member
    New England
    03 AC SR5 4x4 3.4L V6
    New frame in 2022 CB Radio Aluminum cap Bilstein 4600's
    I had luck with my local pick n pull place. Not a common part to grab. Just look around. Find one online. Shifty gave good advice.
  9. Sep 25, 2023 at 12:23 PM
    bfunke
    bfunke Tundra Curmudgeon
    Pull a part for that.
  10. Jun 15, 2025 at 5:14 PM
    mikhalljr12
    mikhalljr12 New Member
    2004 Tundra double cab sr5
    how do you find your paint code or interior code
  11. Jun 15, 2025 at 6:16 PM
    It’s on the sticker, driver side door jamb. Look on the actual door, not the b-pillar. Look for the “C/TR” field. C is the body color. TR is your trim color.
