  1. Jun 5, 2025 at 7:34 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I paid $131 shipped to get the part circled in blue, complete with cables and everything. The only thing I had to transfer over from my original latch assembly was the part in green.
  2. Jun 5, 2025 at 7:37 AM
    Inside the EPC, the Sequoia uses different INDEX numbers than the DC, but the part numbers are technically the same.
    Here is the difference for an '05 DC versus an '05 Sequoia, notice the part index numbers (in the colored boxes) are different, but the physical part numbers are identical - once again, you may only need the LATCH, not the ASSEMBLY, one is 3x more $$ than the other:
    Voss, jerryallday and AmericanKing06 like this.
  3. Jun 5, 2025 at 9:38 AM
    Torching the evidence of the great box building adventure
  4. Jun 5, 2025 at 2:03 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Uh oh, i seem to have found a map to my next money pit.
    I want a mazda az1. Or a kei van. Or dihatsu midget…i dont know what i want.
  5. Jun 5, 2025 at 2:08 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Subaru makes em too.
    I was looking the other day (out of curiosity) and finding one with a title is not easy.
    Tripleconpanna likes this.
  6. Jun 5, 2025 at 2:45 PM
    The VA has a few of them, and some vans, all manuals. Tiger trucks or something. I want a van with a mid mounted K24. With a whipple.
  7. Jun 5, 2025 at 2:48 PM
    des2mtn
    Shady Grove
    Tonto cover
    Y'all should just get a job at a college or stadium and get paid to drive one.
  8. Jun 5, 2025 at 2:54 PM
    We have one at work that the bed raises like a scissor lift
  9. Jun 5, 2025 at 3:08 PM
    des2mtn
    Shady Grove
    Tonto cover
    That's pretty cool. Can it be used as a dump bed too?
  10. Jun 5, 2025 at 3:10 PM
    I’m not sure, it definitely seemed like a landscaper type setup though. If I see it around I’ll ask
  11. Jun 5, 2025 at 3:20 PM
    des2mtn
    Shady Grove
    Tonto cover
    Yeah this one I looked up has both:
    https://www.youtube.com/shorts/mJ5jOWoWtx4
  12. Jun 5, 2025 at 4:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Honda acty with a k engine
    shifty` likes this.
  13. Jun 5, 2025 at 4:14 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This is the way.
    bmf4069[QUOTED] likes this.
  14. Jun 5, 2025 at 5:21 PM
    Grammar is important.
  15. Jun 5, 2025 at 6:46 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    What I found as odd after a got my tundra: They look like a midsize truck compared to todays modern trucks unless you're up close, or they're side by side; BUT I couldn't stand it and hd to pull a tape.....
    The interior measurements between the Tundra and a 2018 gmc double cab 4x4, are so close as to be negligible.
    The tundra has more ground clearance and is higher at the top of bed by about 6 inches at the tailgate. Top of tailgate height of gmc is 54. Tundra is 59.5.
  16. Jun 5, 2025 at 6:50 PM
    FGT is right sized.
  17. Jun 5, 2025 at 6:50 PM
    Redoak
    Redoak New Member
    Dave
    none
    I have been tentatively looking for left front (driver side) inside door handle and trim piece to replace one I broke.
    Also need clips that hold the passenger side exterior handle in place. It still good on front portion but back will pull away from the door.
    Where's the thread where I can find these?
  18. Jun 5, 2025 at 7:26 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Sit in a midsize truck and you will instantly be able to tell they're smaller than our best gen Tundras. Cramped AF compared to our extra room
  19. Jun 5, 2025 at 7:28 PM
    https://www.tundras.com/threads/howto-use-the-toyota-parts-system-to-find-order-parts.113808/
    1st couple bullets. Your part will be in the Body section. Then in front door or rear door subsection.
    Note a lot of color matched interior parts are gone now. Being replaced with tan/beige. Dunno why.
    Redoak[QUOTED] likes this.
  20. Jun 5, 2025 at 8:24 PM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    On the EPC it’s showing the tundra part number as 69304 but on ourismans Toyota website the numbers are the same for the sequoia part. Weird
  21. Jun 5, 2025 at 8:35 PM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    Hey I’m looking to remove my differential drop, if any has the part numbers to the shorter bolts or point me in a direction I could find them.
  22. Jun 5, 2025 at 8:35 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    My dad had a Suzuki Carry Kei truck, manual, 4x4 etc. it was pretty fun to drive, but oh so uncomfortable too. Sold it a couple years ago.
    They’re all over up here (with titles), start importing them to the south, might be profitable if there’s demand. I think they basically age out in Japan so there are a few importers bring them over when they hit a certain age.
    There are a number of Subaru Sambars around with body kits to look like a VW bus, kinda fun.
    JakeJake, Sirfive[QUOTED] and bmf4069 like this.
  23. Jun 5, 2025 at 8:57 PM
    des2mtn
    Shady Grove
    Tonto cover
    That's the exact part number that I bought from a different dealer for my driver's door. When I search on Lewis Toyota it says this:
    What came when I used that P/N is exactly what I was referring to in this post:
    2x 90080-11420 Bolt with Washer
    2x 90179-14063 Nut
    Stock63[QUOTED] likes this.
  24. Jun 6, 2025 at 1:19 AM
    This is why I don’t trust Toyota’s online parts system. My pics from the EPC show the part INDEX# is different but part number is identical. I’ve seen that semi-often in EPCs (electronic parts catalog - not referring to that website specifically). And it matches @des2mtn ’s reco too, unless I’m missing something.
    Stock63[QUOTED] and des2mtn like this.
  25. Jun 6, 2025 at 6:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  26. Jun 6, 2025 at 6:08 AM
    Never heard the original, so for me, this is the original now. It's not bad. Not an ICP fan in general. Had some Michigan buddies in college that loved those guys, way back when Bugz on my Nugz was their jam.
    Dakillacore and Sirfive like this.
  27. Jun 6, 2025 at 6:18 AM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    thank you very much for you help I think I’m just gonna go with the sequoia part and will see if it fits. My driver door is getting so bad I have to press the latch up with my finger so it can actually latch instead of slamming into the catch.
  28. Jun 6, 2025 at 6:21 AM
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    Thank you for your help as well, I’ve been having some frustrating experiences with the truck lately and this forum is a lot of help.
  29. Jun 6, 2025 at 7:58 AM
    I ran home to pick up a package left on my doorstep by UPS. Got my new filter for Donut. With any luck(not gonna happen) I can get the slave and filter put in today.
    Since I was already home and there's another foreskin on the job, therefore another work truck, I grabbed Ironman and drove him back. @FrenchToasty Tundra on call.
  30. Jun 6, 2025 at 8:14 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    the BMF headlight special.
    context: bmf drove around camp in sedona holding a flashlight out of his window because his headlights were dim & muddy.
