  1. May 23, 2025 at 3:11 PM
    Dirt Ferguson
    Dirt Ferguson New Member
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    start with the easiest stuff first: replace the clamp on the hose.
  2. May 23, 2025 at 3:14 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Word. Considering the amount of fluid it's lost in a week while being driven minimally, I think I'll replace the hose itself as well as the clamp on the other side.
    Just so I maybe don't have to check and fill the trans more than once.
    NUDRAT likes this.
  3. May 23, 2025 at 3:23 PM
    Dirt Ferguson
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    The hose itself could be the problem. A lot of designated A/T hose only has a temp rating in the mid 200s F. Gates makes an A/T hose with a temp rating above 300F.
    I learned this when I replaced the A/T hoses on my 80 series, so YMMV.
    oscardog86, PNW15 and G_unit3000 like this.
  4. May 23, 2025 at 3:49 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Also fair. It doesn't look like an OEM hose to me. So could be something odd like that. Although it has been quite cool here, I did work the truck loaded up for 2000 miles. So maybe this hose is just kinda old and tired and finally gave up, thankfully it waited, whatever is going on.
  5. May 23, 2025 at 4:29 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Taking advantage of the 15% off sale. Been ordering stuff from Serra Toyota left and right. I think this is a pretty good deal for all OEM front brake replacement (in my case upgrade to 13WL).
    oscardog86, Neo, G_unit3000 and 6 others like this.
  6. May 23, 2025 at 11:04 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    I keep debating whether or not to do that, especiallyyyy the rear whewww
    shifty`[QUOTED] likes this.
  7. May 24, 2025 at 7:44 AM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    bmf4069, Voss, oscardog86 and 8 others like this.
  8. May 24, 2025 at 8:05 AM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    I need to paint-match the cap first, I think.
    If i could pull off that rear wrap off tomorrow for a reasonable amount of money, I'd probably do it. It'd also reduce (or kill entirely) my need to paint-match the cap. I found Avery brand white vinyl wrap is a good paint match to the 056 Natural White trucks.
  9. May 24, 2025 at 8:19 AM
    455h0le_dachshund likes this.
  10. May 24, 2025 at 8:20 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Sorry. Wrong forum. My bad.
  11. May 24, 2025 at 8:22 AM
    Ah! Actually, now I'm wondering if this would work to add wireless CarPlay to our 2020 HiHy with the JBL system and smaller touchscreen.
    I've used the MagicLink (thanks @The Black Mamba ) to add wireless CarPlay to my already-CarPlay enabled radios, but I find the short delay between keypresses and action on the head unit using wireless CarPlay to be completely aggravating. And I've found it happens on nearly every vehicle I've used wireless CarPlay on (lots of complaints on the internet about this issue)
    Dakillacore and phabej[QUOTED] like this.
  12. May 24, 2025 at 8:25 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    What's a HiHy ! Sorry
  13. May 24, 2025 at 8:27 AM
    Highlander Hybrid
  14. May 24, 2025 at 8:29 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Doesn't the 2020 Toyota come with Android auto and Apple carplay already?
    If you just need wireless, there's a few options out there. One being AA wireless and the other one being the Motorola wireless via USB connector. Connects via Bluetooth. I have The AA wireless on my 2023 Sienna. It automatically connects a minute after I start the car. But I'm using Android.
  15. May 24, 2025 at 8:36 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
  16. May 24, 2025 at 5:01 PM
    AmericanKing06
    New Mexico
    7 hours later, new spindles, CV axles, and power steering rack. 20250524_130750.jpg 20250524_130741.jpg
  17. May 24, 2025 at 5:22 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    That's a good amount of work!
  18. May 24, 2025 at 8:02 PM
    Nicklovin
    Nicklovin Yap Yap
    CUrious how much that rear wrap would cost, a lotttt of red. Oooo that's good to know, gotta do something about the paint falling off my driver door below the window eventually
  19. May 25, 2025 at 5:09 AM
    In reality, a 6x5 sheet of Avery Dennison brand wrap runs around $100. You’d probably need a full sheet in red that size for each bedside, and 1x5 sheets run around $15. I’d probably need a 8x8 sheet (ish) to finish the remaining cap in white and could use the red leftovers for the cap also.
    You could go with another brand wrap like VViViD+ and maybe save 10-15% but Avery (IMO, I’m finding) is much easier to deal with stretching without heat. The youngest kid has been having me wrap his RC cars and let me tell you, body panels on real cars are light years easier to deal with than these little RC bodies, the ability of a wrap to handle stretching and actually grip without bubbling is very noticeable.
    Iur of pocket, to try and replicate the back-end paint on that video game car and color match the cap in wrap would probably be about $600-700 in product, I’m guessing. If I wanted a shop to do it, the math I typically find that fits for many things automotive is [LABOR = 2x PRODUCT COST], so If probably expect $1,200-1,400 in labor if I outsourced the work to a competent wrap shop.
  20. May 25, 2025 at 7:55 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Hopefully I don't regret it, but I'm chickening out on cam and crank seals as part of timing belt replacement. L cam rear cover has this stud that just wants to break when I try to turn it. Tried removing the can pulley to get access for vice grips but I can't seem to get it with a breaker bar and can holder tool.
    Crank has some rust on it that would have to be cleaned off. I think I trust the factory installed seals more than I trust my ability to install new ones.
    Voss and oscardog86 like this.
  21. May 25, 2025 at 7:59 AM
    I get your reticence on the bolt. And impact may get you there with mitigated risk?
    Two things, common mistakes to avoid.
    1. Be careful not to pinch your cam position sensor wires with the water pump during install.
    2. Be sure to route the crank position sensor harness/loom BEHIND the pulley bracket during reassembly.
  22. May 25, 2025 at 8:06 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Thanks, I'll have a think about it while cleaning the water pump surface. I went as far as putting the impact on the bolt before second guessing whether that was a good idea
  23. May 25, 2025 at 8:16 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Now I just have to not fuck up the rest of it
  24. May 25, 2025 at 8:38 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Well this is not ideal
    Voss, oscardog86 and Jack McCarthy like this.
  25. May 25, 2025 at 8:57 AM
    Jack McCarthy My work anxiety is my morning alarm clock
    Ouch!
  26. May 25, 2025 at 10:18 AM
    Ooof. But hey! I see in the background you got the cam off!
  27. May 25, 2025 at 10:31 AM
    Dustdog
    Dustdog New Member
    01, 05 AC 4wd
    stockers
    20% off low range offroad...I ordered 6112s!
    bmf4069, Voss, oscardog86 and 2 others like this.
  28. May 25, 2025 at 10:46 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Yup. Just got back from buying some shiny new drill bits... Fortunately it seems like its just this side. Every other bolt came out nicely. I'm pretty sure this one is cross-threaded, possibly the seals were done in '06 and maybe it was cross-threaded then?
  29. May 25, 2025 at 12:22 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Drilled it out and tapped new threads. Used the stud from the pass side to test. Not the best threads in the world but good enough for what they need to do. There's a chance I'll need to cut down the threads of the new stud a little as I was afraid of drilling too deep
    Voss, oscardog86, G_unit3000 and 2 others like this.
  30. May 25, 2025 at 12:33 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I got the Tundra out for it's first 4x4 of the season. I need to remember it's not the Tacoma. It doesn't fit down these roads as well, and the longer wheelbase means I lose traction a bit more. Still pretty capable, though.
    I didn't even want to try this "road". The area is popular with utv's and people are making their own roads unfortunately.
