Best headlight halogen light bulb option vs upgrade?
Discussion in '1st Gen Tundras (2000-2006)' started by Halsted, May 13, 2025.
  1. May 15, 2025 at 3:20 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    ahh my bad bro.
    I bought a set of cheap bulbs long ago and they melted the hell out of the plugs from drawing way more voltage than they were listed. Clearly i'm over-sensitive lol
  2. May 15, 2025 at 5:24 PM
    Rich L.
    Rich L. This too shall pass
    Pacific NW
    '06 SR5 AC V8 4WD
    I installed an upgraded wire harness with relays, new Depo housings and Osram halogen bulbs.
    Light output is MUCH better than Silverstars with stock wiring and old housings. The beam pattern of the aftermarket Depo housings is mediocre. I will say the LED drop-in users don't like my Hi beams when I flash 'em.
    G_unit3000 and DarkMint like this.
  3. May 15, 2025 at 6:39 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    This is the real best answer. You don't need all that LED swap BS. Keep this shit simple. Im using these osram 62204SBP bulbs with the cheap harness attachment, going on 4 years now no issues. They have a much brighter-than-standard beam with a nice cutoff. 2 new headlight housings and still the same bulbs. Front-end collision and still the same bulbs. 10/10 can vouch.
  4. May 16, 2025 at 12:49 PM
    Halsted
    Halsted [OP] New Member
    2004 Tundra 4WD V6 AC Manual
    Do you have to run a new harness to the battery? I'd prefer to avoid more spaghetti under the hood if I can.
  5. May 16, 2025 at 12:55 PM
    shifty` All my rowdy friends have settled down
    I've heard a couple of folks on here say they've been happier with the mini projectors output more than any other bulb, including those running bright bulbs and the upgrade harness.
    G_unit3000 and Halsted[OP] like this.
  6. May 16, 2025 at 1:01 PM
    DarkMint
    Ben
    Yes. It's incredibly simple though. But if you'd rather disassemble and reconstruct and bake two headlight housings and then buying a boutique LED bulb because you're avoidant of one tube of harness wiring, it sounds like you dont want it the easy way :D different strokes
  7. May 16, 2025 at 1:02 PM
    You don't need to do all that. The miniprojectors, you just pop out the reflector cup and the projector bulbs pop right in. Best I can tell, the output is at least 2x brighter and more focused than any high-power bulb and wire harness is going to get you.
    Miniprojectors cost less than the high-power bulbs and harness.
    Halsted[OP] and G_unit3000 like this.
  8. May 16, 2025 at 1:08 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    No blinding whatsoever - How do I know - no one has flashed me in over 5 years of use - we are talking 4 different vehicles.
    They are Identical in shape and size as OEM so yes Plug and Play. Yes they make all types fogs Hi Lo beams and some kits that include all of them for a specific vehicle. Light is bright white shooting further and wider than OEM - alot for some vehicles to make them Safe again - Luck all.
    Rodtheviking and G_unit3000 like this.
  9. May 16, 2025 at 1:40 PM
    DarkMint
    Ben
    how do you take off the reflector without disassemble? Just jigger around in there with a screwdriver and shake the removed piece out of the socket hole?
    also, colights i saw were ~$60
    Osram+harness= $42
  10. May 16, 2025 at 1:43 PM
    DarkMint
    Ben
    doesnt look like the reflector will fit through the socket hole. Is housing disassembly and reassembly easier than I am thinking than the plug-and-play solution I can vouch for?
  11. May 16, 2025 at 1:54 PM
    Yes.
    It's all covered in this thread: https://www.tundras.com/threads/amazing-1st-gen-headlamp-upgrade.127384/
    All headlight upgrades for our trucks are covered in this reply: https://www.tundras.com/posts/3143834/
    All of that info is covered in the lighting section of the community megathread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    A few people on here were able to get new housing pair for under $50, mini projectors under $30, and be out the door at $80 with new housings and lights. It'll vary from model to model, trucks with the corner teardrop light (parking lights) cost more IIRC. But generally speaking, no backing. Just unscrew that reflector cup, and carefully extract without cracking any of the plastic rim. It took me about 10 minutes per housing to a full retrofit on brand new housings.
    G_unit3000 likes this.
  12. May 16, 2025 at 2:07 PM
    DarkMint
    Ben
    one of those links says you also need a "grounding mod" although it sounds like many of you aren't doing that.
    I guess it's of similar difficulty to swapping to osrams and plugging in a cheap harness. It's still cheaper than mini projectors though although $80 aint too shabby
  13. May 16, 2025 at 4:00 PM
    Not to shabby, and I know folks who refuse to make the cutover. It's possible the lifespan on the mini projectors may be as short as 2-3 years, but it also seems like when they fail, the half-ass light output they barf up is still better than a traditional halogen, so ... it's a tough call!
  14. May 16, 2025 at 4:03 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    ^^^ I literally spent about 2 months playing around with this including using the high output osrams. I didn't even bother with pics because the colight still was brighter.
  15. May 16, 2025 at 6:26 PM
    Halsted
    The video at least has him taking the headlights out and really going to war with that deflector cup. People are getting that thing out without taking the headlight out?? I’ll admit I didn’t read all 16 pages but I did read a bunch, and didn’t see that.
  16. May 16, 2025 at 6:31 PM
    It literally took me under 10 minutes per housing to do the work, and I was taking lots of pics along the way which ate up a couple of minutes, I feel like I covered it fairly well here: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1584#post-3139813
    I personally used the tools you see there: Screwdriver to remove the one screw, then held the reflector and cut it with tin snips to reduce its size and slide it out.
    The important part, which is clearly warned about in that video, is you CANNOT shove your cutty implements into the hole. Treat it like that Milton Bradley game "Operation". DO NOT break off these two tabs because you bump them with whatever you're cutting with, like dude did in the video. If you do it's not the end of the world, but just avoid it, you're better off.
    tvpierce and G_unit3000 like this.
  17. May 17, 2025 at 9:14 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    With all due respect to Thomas Edison, incandescent lighting, while groundbreaking for its time, is ridiculously outdated -- it's literally 1800s technology. 90+% of the energy that goes into an incandescent bulb is "wasted" generating heat. Less than 10% is emitting light.
    On top of that, the US DOT standard for headlights is the worst in the world. Every manufacturer that sells vehicles in other markets has to create a dumbed-down version of their headlight technology to sell in North America. So anything we can do to improve the performance of our woefully inadequate OEM lighting is a giant leap forward. IMHO. :)
  18. May 17, 2025 at 9:23 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    These are the same ones I’m using and they have been on the truck for more than a year. Light output is great and they don’t blind oncoming drivers. They DO have fans but the fan is inside the headlight assembly which helps warm the outside headlight housing to keep headlights clear of snow similar to a halogen headlight bulb. Installing them is the same as a halogen bulb.
  19. May 17, 2025 at 10:14 AM
    Halsted
    I see, so you started with new headlights and took the deflector out with the headlights off the truck. I thought you were saying you got that deflector out with the headlights still on the truck! Impressive.
    Kind of torn. I'd like to do the mini projector upgrade, but don't want to have to take the headlights out (and apparently the blinker too, if the video is any indication), and these LED lights seem to have a lot of reports that they don't blind people. I don't want to be that guy.
  20. May 17, 2025 at 10:39 AM
    #50
    Takes 2 mins to take the headlight housings out. Remove the two fasteners for the blinker. Slap-push the blinker housing forward and out while standing next to front tire. With that out, you just have I think three bolts and the housing lifts right out? It's a brainless exercise, hardest part is slapping that blinker housing forward. DO NOT pry the blinker housing out, it's unnecessary and puts your paint at risk.
  21. May 17, 2025 at 11:41 AM
    #51
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You won’t be disappointed in those LED bulbs. The pattern is the same as stock with vast improvement in light output annd absolutely do not blind oncoming drivers. I’ve never been flashed once. Easy to install and nothing to modify. I live in a rural area and these have been a great upgrade and the best bang for the buck.
  22. May 17, 2025 at 11:55 AM
    #52
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    If my mini projector LEDs had to be replaced yearly, I'd still run them. Definitely a big improvement over stock halogens and regular LEDs.
    KNABORES and shifty` like this.
  23. May 17, 2025 at 1:15 PM
    #53
    Halsted
    Appreciate all the advice!
    Ruggybuggy[QUOTED] likes this.
  24. May 17, 2025 at 5:59 PM
    #54
    Ditto. I'm definitely ordering another pair soon and may just proactively replace them every 24 months.
    KNABORES and G_unit3000[QUOTED] like this.
