Another Keyless Entry Question Thread...
Discussion in '1st Gen Tundras (2000-2006)' started by 1stGenObsessed, May 5, 2025.
  1. May 5, 2025 at 4:56 PM
    1stGenObsessed
    1stGenObsessed [OP] New Member
    Just bought and drove this '04 AC from Texas back to CT, didn't come with fobs and trying to add them.
    The RS3200 programming procedure works so I must have that system, but I bought these remotes that have been linked on here a lot with FCC ID BAB237131-056, no response from the truck. I did clear all the fobs already and replaced the battery in one of the ones I bought, still nothing.
    Am I missing something? I was thinking maybe buy an OEM fob which according to this thread is p/n 08191-00922 but I feel like this should've worked? Is there a way to check what FCC ID I need to be sure or are all RS3200s BAB237131-056 and I got bad fobs?
    KNABORES and G_unit3000 like this.
  2. May 5, 2025 at 5:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    There's two types of RS3200 remotes and you have to make sure you get the right one or it won't program. Easiest way to do this is buy one of each and send back the one that doesn't work.
    The two remotes are identical except one has a red led on top and the other doesn't
    G_unit3000 likes this.
  3. May 5, 2025 at 5:33 PM
    1stGenObsessed
    Weird that makes a difference, do we have individual part numbers for either? These were the no-LED fobs so I guess I need the LED one
    w666 likes this.
  4. May 5, 2025 at 5:43 PM
    I ran down the part number at one point.
    Did you read the community megathread yet, "keys" section? You know you need to issue the command to ERASE all previously existing remotes if it won't take the new ones, right?
    My guess is, the memory is full, and it won't take another key because you haven't cleared the old fobs out yet. Not an uncommon issue.
  5. May 5, 2025 at 5:46 PM
    1stGenObsessed
    The only P/N I've seen is 08191-00922 and both LED and non-LED versions come up when you search it hahah. Might just have to order it and see what happens.
    I did already remove all keys, it locked/unlocked 5 times like it should. And yup read that megathread before I picked er up
    Sirfive and 455h0le_dachshund like this.
  6. May 5, 2025 at 5:51 PM
    This is all I can tell you: https://www.tundras.com/threads/key-fob-replacement-2002-tundra.55779/page-9#post-3353208
    That's tied to my '06 AC which also has the RS3200 system.
    But seriously, I got used OEM ones from fleaBay and one (or two?) from a local junkyard on the cheap, they keep them behind the counter over here. Worked great. I don't trust anything new, unopened from scAmazon or fleaBay, you'd be a fool to do so.
  7. May 5, 2025 at 6:08 PM
    1stGenObsessed
    Fair enough, the dealer is cheaper then ebay funnily enough so I just ordered one there. Zero indication if it's the LED version or not but I'm thinking it is
    455h0le_dachshund likes this.
  8. May 5, 2025 at 6:10 PM
    In that case, here's the other thing I can tell you about fobs.
    Ignore the links on those, it links out to scAmazon. Bottom line is, the dealer will be able to tell you right I think.
  9. May 6, 2025 at 2:00 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    All I know is that the one WITH the LED worked for me, and the one WITHOUT the LED did not.
  10. May 6, 2025 at 5:54 AM
    This is another good thread with internals and fob troubleshooting instructions: https://www.tundras.com/threads/keyless-entry-issues-solved.148105/
    Here's a picture of both styles, with the FCC ID on rear, I should probably edit that thread I just linked with this pic.
    With LED (ending -056) worked for me, and I was able to program the middle one (starting G043) to mine as well. And the last one, ending in "BBX", we have confirmation from another 2005 AC owner it supposedly worked for his truck, and also a 2006 DC owner, and another DC owner, and even another DC owner, but the part number traces back to a RAV4 I think? And it comes in some interesting variations like so.
    G_unit3000 and 455h0le_dachshund like this.
  11. May 9, 2025 at 11:51 AM
    1stGenObsessed
    08191-00922 was the ticket, it's the one with the LED. Works great
    G_unit3000 and shifty` like this.
  12. May 9, 2025 at 11:53 AM
    Curious, what's the FCC ID on the rear?
  13. May 9, 2025 at 11:54 AM
    1stGenObsessed
    BAB237131-056
  14. May 9, 2025 at 11:55 AM
    Wild. So the OEM part with that FCC ID worked, but scAmazon-purchased aftermarket ones wouldn't?
  15. May 9, 2025 at 11:57 AM
    1stGenObsessed
    Yup. Same FCC ID on both, Amazon one didn't have the LED is all
  16. May 9, 2025 at 11:58 AM
    Bizarre. Technicall with same FCCID, should be the same internals. I did notice while tearing down mine, the one w/o LED on the plastic shell actually did have LED on the circuit board. But ... yeah, time to return to scAmazon :rofl:
  17. May 9, 2025 at 12:38 PM
    1stGenObsessed
    Oh interesting, maybe the LED doesn't matter it's just a terrible part. Yep those were returned the second they didn't work lol
    G_unit3000 and w666 like this.
