HVAC blower fan upgrade
Discussion in 'General Tundra Discussion' started by Jowett, Dec 29, 2023.
  1. Apr 18, 2025 at 8:18 PM
    #391
    bflooks
    bflooks New Member
    Metrowest MA
    Just received shipping information. Pretty accurate in timing.
    OldGuy03 likes this.
  2. Apr 18, 2025 at 9:31 PM
    #392
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Mine shipped today too
    bflooks and OldGuy03 like this.
  3. Apr 27, 2025 at 4:17 AM
    #393
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I LOVE interchangeable parts!!
    French Avocado likes this.
  4. Apr 27, 2025 at 4:19 AM
    #394
    Corndog123
    Sam
    Tennessee
    The bearings aren't shielded?
  5. Apr 27, 2025 at 5:12 AM
    #395
    Jowett
    Jowett [OP] New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    While I have not checked the superseded part numbers, the old 60390 has a bushing for the lower shaft to rotate on. Some Sienna owners with the same brushless fan type (different part #) show it still has the bushing. They have gone so far as to replace it with a ball bearing… Time to pop open the newer LC version and see what’s in there.
  6. Apr 28, 2025 at 12:31 PM
    #396
    Kamyoda17
    Kamyoda17 New Member
    British Columbia
    ‘21 sr5 off-road
    Bilstein 5100s. 285/70r18
  7. Apr 29, 2025 at 1:35 PM
    #397
    Masterputzer
    Masterputzer New Member
    2021 Sequoia Limited
    I Just did this upgrade on my Sequoia and the new motor would not run. Then, when I put the old motor back in it wouldn't run either. On the 2021, I can't see any clear indication of an AC fuse on either of the under hood or under dash fuse blocks.
  8. Apr 29, 2025 at 2:32 PM
    #398
    MadMaxCanon
    I guess I'm disconnecting the battery for this lol
    NewImprovedRon, OldGuy03 and RobertD like this.
  9. Apr 29, 2025 at 3:16 PM
    #399
    Jowett
    North Adams, MA
    Many on the way.
    The Sequoia is wired differently from the Tundra, + and - are reversed. Toyota changed the wire positions on the Sequoia so that motor would not be a direct swap into the Tundra, as it is already the brushless type. The second sentence in the first post makes note of this (just edited and made it the first). You will need to replace a fuse and unfortunately the new motor you have is likely no good. There was some discussion of this last year as another member attempted the swap.
    bulldog93, JMGmanAZ, OldGuy03 and 2 others like this.
  10. Apr 29, 2025 at 4:54 PM
    #400
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Whoa, I have no recollection of the incompatibility. Thanks for making the edit!
    After all the other things that are swap-able, not cool Toyota...
  11. Apr 29, 2025 at 5:21 PM
    #401
    Masterputzer
    Thanks Jowett,
    Now I just need to locate the fuse. I don’t see an AC fuse on either panel diagrams. Maybe they’re calling it something else.
    Thanks again!
  12. Apr 29, 2025 at 6:57 PM
    #402
    Jowett
    North Adams, MA
    Many on the way.
    @e30cabrio
  13. Apr 29, 2025 at 7:06 PM
    #403
    French Avocado
    Utah / Wyo
    bulldog93 likes this.
  14. May 2, 2025 at 12:04 PM
    #404
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Finally got mine in, I think this is the most air this old truck has ever pumped! Maybe I'll even reinstall the cabin air filter :rofl:
  15. May 2, 2025 at 1:02 PM
    #405
    bflooks
    bflooks New Member
    Metrowest MA
    Look at you, using the schwartz.
    Tripleconpanna and AxelsHumanDad like this.
  16. May 2, 2025 at 1:14 PM
    #406
    snivilous
    SW UT
    Excuse me sir you'll have to use a reference 20-30 years newer that I understand :rofl:
  17. May 2, 2025 at 1:21 PM
    #407
    RobertD
    Robert
    DFW, Texas
    I really wanted to comment that it's not that old. But its basically a 38 year old movie!!!! That is crazy
  18. May 2, 2025 at 1:38 PM
    #408
    snivilous
    SW UT
    Nearly a decade on me :D
    RobertD[QUOTED] likes this.
  19. May 2, 2025 at 1:41 PM
    #409
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    So....48?
    Tripleconpanna likes this.
  20. May 2, 2025 at 1:51 PM
    #410
    MadMaxCanon
    There's a cover under the glove box before you can get to the motor, is it screwed in or just push fit?
  21. May 2, 2025 at 2:05 PM
    #411
    bflooks
    bflooks New Member
    Metrowest MA
    better? :rofl:
  22. May 2, 2025 at 2:58 PM
    #412
    snivilous
    SW UT
    Nevermind, you and I are obviously nowhere near the same wavelength when it comes to communicating
  23. May 2, 2025 at 5:28 PM
    #413
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I swapped mine in a couple weeks ago. When I had them both out, I spun them by hand. The brushless one was definitely quieter, but I couldn't tell any difference once installed.
  24. May 2, 2025 at 9:11 PM
    #414
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :devil:
  25. May 2, 2025 at 9:14 PM
    #415
    Tripleconpanna
    Tabs...
    Here this illustrates it...
    https://youtu.be/GY8cVZwf-Vo?t=23
    RitcheyRch, Bowzer, Henry1jg and 6 others like this.
  26. May 4, 2025 at 9:32 AM
    #416
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    after looking into what made the fans brushless, there are aftermarket alternatives now that uses AC motors (brushless) that are direct replacements for trucks. QC is where the question is at hand I guess...so I bought 3, 3 days ago and at the time of this writing, i've tried out two of them.
    Bad:
    YEHERIT $48.99 This one sounded good, talked about fin balancing, had 4 weights spread out through the fins when I opened it. But at 1 click I didnt notice almost any air. Couple more clicks and it makes a rubbing noise, works well at full blast. Returned.
    Okay:
    YDYKPOWER $54.99 *edit* Got to test it out, there were A LOT of fin balancing weights on this unit. No noise but the power output was definitely lower than the GVPART4U and returned.
    Good:
    GVPART4U $55.99 This one i'm currently running, when holding in hands and turned on, you can feel the kick of the motor. It did have 1 weight on the fins although not advertised that they balance. I can feel the air throughout all ranges and blows decently strong at full blast. I don't notice any noise yet. Will it last for years? Idk...it does say 1 year warranty and tested to last 80,000 hours and one of the only fans that state its RPM of 3250.
    Anyone else buy an Amazon one that they recommend?
    It takes me less than 30 seconds to unplug the power cord and plug in new unit not mounted to test run the fan and see how initial impressions are. You can tell pretty quickly after trying a few units and OEM one that I had, if the blower is stronger or louder vs one another. I can confidently recommend the GVPART4U unit, I have zero affliation with them. Plus its amazon, easy to order and easy to return. Good Luck.
  27. May 5, 2025 at 9:12 AM
    #417
    seydou
    seydou Distinguished Member
    Seems like an awful lot of work to save $50, but TEHO. You might want to get an anemometer like another poster has done, so you can at least have some objective data.
  28. May 6, 2025 at 1:03 PM
    #418
    TunaDr
    TunaDr New Member
    2007 Tundra
    its only 3 screws and a plug, pretty simple in terms of working on it. how does the anemometer setup work? open all the vents and a particular setting (like all the upper main vents no foot vent) then measure from a single vent the air coming out? looks like Amazon has some cheaper readers in the $13 range.
  29. May 6, 2025 at 6:28 PM
    #419
    seydou
    I was also referring to the purchasing, receiving, installing, uninstalling and then repackaging and returning of the units, when the best case scenario was you'd save $50. Whatever, if you have the time, interest and motivation go right ahead. Not for me.
    In terms of gathering actual data, I would say to test at a few different spots and in a few different setups. Like front left, center, right, and back(if you have it) and on a few different speeds. First with OEM and then with each alternative. But you should probably include the toyota/Lexus replacement as well as the Chinese ones. Main thing would be to just be consistent. I don't think having a super accurate anemometer is crucial. Just gives you a hard data point.
  30. May 8, 2025 at 11:11 AM
    #420
    woods
    woods New Member
    2021 SR5 TRD Sport
    @Tripleconpanna thanks for posting that video! I managed with my hands and a leatherman. Took maaaybe 15 minutes, probably 10.
    I initially did this upgrade not for the little bit of more speed, but the noise and I was worried mine was gross from mice. Well it wasn't THAT gross, but there was piss and some poop pellets in there, and two acorns that have been spun around a few times I'd guess. Probably the noise.
