HVAC blower fan upgrade
Discussion in 'General Tundra Discussion' started by Jowett, Dec 29, 2023.
  1. Sep 20, 2024 at 2:15 PM
    #151
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Ok so if I’m reading this correctly…can also order the 050 and reverse the leads before install?
  2. Sep 20, 2024 at 3:33 PM
    #152
    Jowett
    Jowett [OP] New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    That appears to be the case.
    Shanet421[QUOTED] likes this.
  3. Sep 20, 2024 at 4:35 PM
    #153
    AZTundra
    Paul
    Phoenix, AZ
    I did. I tagged you back on post #108. :thumbsup:
  4. Sep 20, 2024 at 4:43 PM
    #154
    I remember now. Serra said mine is backordered with a 25 Oct ETA.
    AZTundra[QUOTED] likes this.
  5. Sep 21, 2024 at 9:17 AM
    #155
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Did you have to email them? I think i ordered the same time as you and haven't gotten anything from Fred Anderson.
  6. Sep 21, 2024 at 10:21 AM
    #156
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I did not have to contact them. My order had a status of "Processing" for the better part of a week, then it went to "Shipped", and I got an email from them with the tracking number.
  7. Sep 21, 2024 at 11:28 AM
    #157
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Serra Toyota is a great place to order parts from. They beat sparks every time.
    If you email them and ask for an eta typically they will bump up your order. That’s always been my experience.
    bulldog93 likes this.
  8. Sep 21, 2024 at 2:17 PM
    #158
    My ETA from them is 25 October.
  9. Sep 21, 2024 at 5:20 PM
    #159
    Thumper_6119
    All done. 20-30 minute job, depending on your age, contortionist skills, and flexibility. (It's an awkward position).
    Old and new
    Holy shit! My old blower must have been in much worse shape than I thought. The difference in the air flow/volume between the old unit and the new unit is substantial and undeniable (by no other measured assessment than myself and my post-hysterectomy-wife sitting in front of the vents, before and after the blower upgrade). Same goes for the rear vents (Crewmax). MUCH improved performance throughout.
    The new motor is virtually silent (the benefits of which are completely negated by the increased sound of the improved airflow through the ducts and vents).
    I am very pleased with this upgrade so far, and it was right on time for me to run across this thread. Kudos to OP and participating forum members.
    woods, e30cabrio, reywcms and 6 others like this.
  10. Sep 21, 2024 at 5:48 PM
    #160
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    My blower works close enough to new stock I can’t tell the difference. Buuuut it’s always been loud and lower airflow when comparing it to any other vehicle. Loud enough I regularly turn it down from the highest speed to have a conversation, even in Texas heat! This thread makes me want to do the swap just because!
    Thumper_6119[QUOTED] likes this.
  11. Sep 22, 2024 at 1:50 PM
    #161
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    I just finished replacing my blower motor as well and decided to take some measurements to see how much of an improvement in air flow and to see if it is true that the LC blower (87103-60560) is faster and smoother across fan setting range.
    To try and measure this I took some measurements before and after:
    • Used a HoldPeak 866B Digital Anemometer that claims accuracy to be +/- 5% (not sure if this is constant over its measurement range)
    • Started the truck, opened all vents, and waited five minutes
    • AC was set to recirculating and mode was top vents only
    • Measured vent speed at the driver's right side vent and the back seat right vent
    • I only measured once per fan setting, have other things to do, so sample size is n=1, make of that what you will
    • I did try and get a feel for the variance and it didn't seem too bad, mostly +/- 0.1 or 0.2 mph when I would take a repeated measurement
    • Took out Tundra blower, replaced with LC blower part number 87103-60560, redid measurements
    Again the caveat here is this isn't exactly super controlled, not a super accurate instrument, small sample size, doesn't try to quantify the uncertainty in measurement, or address likely variation across vehicles/blowers.
    Three graphs below show results, my takeaways:
    • Yes, LC blower is faster, particularly for backseat
    • In the backset at max setting, the increase was 18% - my guess is its so low to begin with anything will be a relatively large increase, but its really noticeable
    • Even up front its still an improvement, with a ~10% increase at max fan
    • The increase do appear smoother to some extent. On the driver's right side it seemed to stay more linear around 20% for each increase especially at fan speed 3 and 6 where the Tundra dropped more compared to previous speed. However this didn't seem to true in the back seat where the data looks noisy.
    Subjectively it feels faster and cooler. As far as quieter motor, well I usually keep passenger vents closed and only have driver and back open, if its set to top, its fast enough where the noise from a closed vent might be more annoying, but I usually set it to mix of top/floor which fixes that.
    Overall I recommend - super easy to swap and a noticeable improvement to me.
    RitcheyRch, woods, JMGmanAZ and 16 others like this.
  12. Sep 22, 2024 at 2:48 PM
    #162
    centex
    centex New Member
    You need a girlfriend if you are graphing fan speeds.
    Henry1jg, camron1039, grave and 11 others like this.
  13. Sep 22, 2024 at 6:04 PM
    #163
    nags
    nags New Member
    Just swapped mine and took before and after measurements with all vents closed other than the one.
    Before:
    After:
    Before and after photos taken with girlfriend standing next to me hence no fancy graphs.
    RitcheyRch, Henry1jg, woods and 14 others like this.
  14. Sep 22, 2024 at 6:16 PM
    #164
    TaquitoBandito
    Joel (AKA Bif)
    Was she standing a little closer to you on the "after"? - I noticed the air was a little hotter... ;)
  15. Sep 22, 2024 at 6:24 PM
    #165
    nags
    nags New Member
    I
    The temperature gauge on this must be in a weird location. It's not very accurate when testing the air speed as compared to a laser gauge or anything.
  16. Sep 24, 2024 at 8:28 AM
    #166
    Danimal86
    Daniel
    Sacramento, CA
    i finally reached out to Fred Anderson. I ordered on 9/7, part is on backorder with estimate of 9/30.
    Thumper_6119 and bulldog93 like this.
  17. Sep 24, 2024 at 8:45 AM
    #167
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Got my delivery info from Serra. Should be here on Friday.
    Thumper_6119 likes this.
  18. Sep 24, 2024 at 12:31 PM
    #168
    No updates on mine yet.
  19. Sep 24, 2024 at 1:50 PM
    #169
    bulldog93
    Jeff
    Did you receive any emails from them?
  20. Sep 24, 2024 at 2:39 PM
    #170
    AZTundra
    Paul
    Phoenix, AZ
    For what it’s worth I never got any email or shipping info on mine from Serra Toyota. They billed me when I ordered and then nothing until it finally arrived. Sounds like it’s different for everyone.
  21. Sep 24, 2024 at 3:23 PM
    #171
    No.
  22. Sep 24, 2024 at 5:44 PM
    #172
    bulldog93
    Jeff
    Weird.
    Weird. I ordered a couple of weeks after you did.
  23. Sep 24, 2024 at 6:16 PM
    #173
    I'll email them tomorrow.
  24. Sep 24, 2024 at 6:58 PM
    #174
    seydou
    seydou Distinguished Member
    Serra Toyota of Decatur:
    Purchased online 8/25
    Email invoice received from dealer 9/11
    Voice mail left for dealer 9/23
    Following two emails received today:
    The blower motor is on backorder and the invoice had to take place
    before you credit card authorization voided once that happens after 28
    days which is mandated by the card companies your order would cancel.
    Email is only way we handle online orders. So if you have any further
    needs respond to this email
    ETA 10/24
  25. Sep 25, 2024 at 5:43 AM
    #175
    nags
    nags New Member
    I guess I got lucky. I ordered from the local dealers website, they were the cheapest with a sale that was going on, and it was here within days.
  26. Sep 25, 2024 at 6:06 AM
    #176
    My local dealer here in Pinellas said that it wasn't even available any longer.
    nags[QUOTED] likes this.
  27. Sep 25, 2024 at 6:10 AM
    #177
    nags
    nags New Member
    Damn. I actually need a second one. I should order soon.
  28. Sep 25, 2024 at 6:20 AM
    #178
    Jowett
    North Adams, MA
    Many on the way.
    Dealers that may participate in these extra 25% off sales can be located through https://autoparts.toyota.com/ . Use the dealer locator in the upper right tool bar, not all dealers are part of this program. The goal is to find the closest dealer, as @nags did, that normally offers 20 - 30% off. Then, the on top of that additional 25% sale, and sometimes free shipping over a certain dollar amount (if they are not close enough for pick up).
  29. Sep 26, 2024 at 10:17 AM
    #179
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The end of my mess is new motor & fuse in, there is more volume from the new fan, I had to reverse the wires. The fuse is a bitch to replace, it got easier the 4th time. For a '13 Sequoia Limited, the PN is 82620-0300 but that is superseded by 82620-0C030
  30. Sep 26, 2024 at 10:26 AM
    #180
    bulldog93
    Jeff
    Did you have to purchase a new replacement blower? Also, is the one for the Sequoia brushless as well?
